Topic: Measuring the weight of a beehive (Read 37927 times) previous topic - next topic
Clemens
#30
Mar 20, 2013, 12:42 am Last Edit: Mar 20, 2013, 12:46 am by Clemens Reason: 1
Lars, what resolution do you have with your scale? We had some ideas and came to the solution not to use an amp but instead an external ADC with a higher resolution than the 10bit Arduino, do you use an other board (e.g. the DUE has a 12 bits resolution)?, see http://hackerbee.com/2013/03/18/100-hive-losses-this-year/ or did we forget something? and a resolution of max load / 1024 is with the INA333 possible? I think it amplifies only the signal or does it do any digitalization?
LEGO-lars
Hi Clemens :) Thanks for the link. A lot useful information on that page.
You are right in that the arduino 10 bits of resolution is a bit low.
However, there is a way to increse the resolution of the ADC called oversampling. http://www.atmel.com/images/doc8003.pdf
In short, 16 10-bits sampeles are equal to one 12-bit sample.
In my scale, I have no problem to get a stable resolution of 0.1kg.
motiTheWonderDog
http://dl.dropboxusercontent.com/u/128833299/bees.htm
Uses 50kg Load Sensor PPSEN-10245 for weight monitoring.
Photo Interrupter GP1A57HRJ00F to count the bees going in and out of the hive.
toadstul
What has happen to this project?
Is there any farther progress?
LEGO-lars
Hi toadstul.
I have been quite busy with some other projects lately (and got a bit bored :smiley-red:), so nothing has been done on this project in the last 6 months.
However, before I took a break I was doing great progress.
I've got the PCB for the wireless scales manufactured. I've got the the power consumption low enough for the scale to work several seasons before battery change is necessary. I have made the base station with the GPRS-module, a wether station, and a solar panel.
I've also got the whole setup working on my workbench, and uploaded data to Cosm.com.
What remains is to make the actual scale that fits under the beehive.
I also have some problems with the wireless trancievers (probably due to a designflaw on the PCB :smiley-red:).
Then I have to make everything watertight.
On the computer side, I would like to download the data into a spread-sheet, and use some algorithms to calculate which beehive needs attention.
I plan to start up again this winter when I will have some more spare time.
I could probobly post some pictures and explanation of the current setup if there is any interest.
LEGO-lars
SirNickity
Measuring bee-hives?   :smiley-eek-blue:
NOPE.  Nope nope nope.  nope.... nope...
*shudder*  nope!
zagryl
Is there any particular reason you bother yourself with power consumption as you can put a car battery with a solar panel charger to rid yourself of power consumption problems.? It's not like you'll leave your bees to themselves for two seasons?  :)
Or am I missing something?
LEGO-lars
The two main reasons for the fiddling with the power consumption, is cost and flexibility. If this system turns out to work, I would like measure all our 200+ hives (my father works full time as a beekeeper). Therefor the cost of each weightscale is critical. Powering the each scale with 2 AAA batteries would be a lot cheaper then using a car battery and solar panel, even if I could power several scales from the same battery.
The second reason is flexibility. When the scale is completely wireless, everything can be hided under the hive with no wires lying everywhere to be tripped over. The hives are also moved a couple of times during the season (to get more honey), so rigging the system up and down have to be easy and fast.
A last benefit with my wireless modular system is that it is easy to add or remove modules from the network. The plan is to let the base station in every bee-farm auto detect the wireless scales without intervention from the user.
Lego-lars
odometer
toadstul
Hi LEGO-lars
Sorry about the delay of my answer(i was changing  isp)
What method did you follow to lower the power consumption?
What chip did you use to amplify the signal from the loadcell?
You say ''I plan to start up again this winter when I will have some more spare time. I notes that you are from Norway, I think you already have winter up there :P !! So please start again your project asap.
Pictures and explanation...?    of course there is interest !
On my side I have buy already tow arduino uno, tow loadcell 160kg, tow ina125, tow DS3231 rtc, tow DHT22/AM2302 Digital Temperature And Humidity Sensor, and i am waiting an  Arduino GSM Shield (antenna connector).
I plan to connect all these together and get daily reports of weight to my mobile. That will help me to know when the nectar flow stars or ends.
Clemens
#40
Nov 13, 2013, 09:54 pm Last Edit: Nov 13, 2013, 10:00 pm by Clemens Reason: 1
Power consumption can be done mainly by changing to an barebone Arduino setup, think the most cited article about this is http://gammon.com.au/power .
Quote
The initial outcome is that, to save power, forget about using a development board. Further savings (like reducing clock speed) would be overshadowed by the huge overhead of the voltage regulator and USB interface chip.
I think Lars used as OpAmp an INA333 as linked in an older posting above: http://bildr.no/view/1409684 and no additional ADC so there is really an option for better reading than 0.1 kg resolution.
I see this two options: Use an additional ADC plus OpAmp / PGA  or a chip who has both integrated, see my posting under http://forum.arduino.cc/index.php?topic=198139.0 - so you see, you are not alone. :-) you may also have a look at the Seeeduino Stalker who has a lot of build in (charger circuit, RTC, SD) http://www.seeedstudio.com/wiki/Seeeduino_Stalker_v2.3
LEGO-lars
Hi again :)
Here are some pictures of my project so far.
This is the wireless sensor node. The Atmega328 is running at 1 Mhz internal  ocilator. I am using a 32 khz clock-crystal connected to the xtal pins and timer 2, to make a the AVR work as a RTC.
To amplify the loadcell I am using the ina333 op-amp and no additional ADC, but with some oversampling and black magic, I get something that looks like 12 bits of resolution :)  As clements has pointed out, it is possible to use an external ADC, and probably get a better resolution. In my case I could not find anyone that works over the whole voltage span of two AAA batteries.
A P-channel mosfet cuts the power to the loadcell and op-amp when they are not needed.
This is the prototype for the base station. It is using the sim900BE GPRS-module, and have interface for a DHT22 temperature/humidity sensor, and a rain gauge. It also have a solar charge controller.
This is a prototype of the actual scale that fits under the bee-hive. The plan here is to only measure one side of the hive and expect the other side to be equal.  This would make the scale much easier to make, and I could use a smaller and cheaper loadcell. If this method is accurate enough, remains to be seen.
GoForSmoke
Just wondering how much the bees weigh and if there's times when they're all inside like at night.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
Clemens
A single bee has a weight of about  0.1 g. So a big hive has 3-4 kg bees. But most changing factor relating to weight is nectar flow and evaporation. Bees bring nectar to the hive with 80 % water. Honey has in the end under 20 % water. The difference must be reduced by the bees.
Gert_O
Hi Lego-Lars
Have you got at suitable loadcell for you bi-hive weight ?
I am very interested to here more about your project. Maybe we could help each other. I have acces to very cheap 120 kg full bridge single point loadcells In a month or so.
Is I possible to here more about you have build your hardware, and maybe a little about your software.
I am a be-keeper too, here in DK.
Sorry for my English, it's a little rusty!
