Topic: RF Transmitter and Receiver WRL-10535 and WRL-10533 (Read 14545 times) previous topic - next topic
steven6282
You buy it on a board instead:
http://www.sparkfun.com/products/691
http://iteadstudio.com/store/index.php?main_page=product_info&cPath=7&products_id=53
Lol thanks, I actually found the board version on sparkfun after I posted that, but wasn't going to pay 20 dollars for it on a board, however $5.50, that I can probably swing :)
pwillard
 9V's batteries are horrible...   High Cost/Low Current.
You would do well to buy a $15-$20 radio control 9.6V rechargeable (usually comes with a charger too).
Docedison
And the same module here for $2.75 US (this price is typical of many vendors on Ebay) 5.50 Ea should be for a pair... Check it out.
http://www.electrodragon.com/?product=storage-container-set.
I recently bought 6 of those devices and a USB Receiver "Dongle" for $9.95... "Free Shipping"... Too ? $22.00 Ea... Yeah I'll Bet... that they would love to sell a bunch at that price, oh yeah and the Features on the $22.50 board are built into the Chip. All of the nRF24XX series Ic's have those features... They're part of what drove the original design and that was an inexpensive Chipset that could co-exist with all the other ISM stuff as well as Microwave Ovens @ 2450 Mhz and most capable of 1000 watts or more @ ~ 2450 mhz as the ovens use a "Power Oscillator" (A Klystron of Magnetron tube) neither of which has any external frequency control (Oscillating Frequency is set by internal cavity dimensions primarily).
Doc
--> WA7EMS <--
steven6282
Doc
That $2.75 one doesn't look like the + model that sales for $5.50 at the other place.  The + model adds a few features including a slower transmit speed for increased range and less power usage.
However you are correct they are cheaper on ebay http://www.ebay.com/itm/2PCS-Arduino-NRF24L01-Wireless-Transceiver-Module-/270977894613?pt=LH_DefaultDomain_0&hash=item3f178a88d5 is a + and 4.10 for 2 of them, so only $2.05 each free shipping.
Although I'd probably buy this one instead: http://www.ebay.com/sch/i.html?_sacat=0&_nkw=nrf24l01&LH_PrefLoc=1&_sop=15  a little bit more expensive but it's located in the US, so would get here 3 times quicker lol.
Stigern
So, I'm testing the RF434, with VirtualWire. And is there a way to make it translate what it recieved into a text? Instead of hex codes for each letter.
I'm from Norway!
CrossRoads
Sure, just translate the hexcodes into letters. Translation is available at asciitable.com
Say you get 1 character at a time:
    // mapping from incoming character to font_array or other commands: \ + = < >
    // invalid characters are not defined and are ignored
    switch(incomingByte){
    case 0x20:
Serial.print(" ");
      break;
    case 0x21:
Serial.print("!");
break;
    case 0x2d:
      Serial.print("-");
      break;
    case 0x2e:
      Serial.print(".");
      break;
    case 0x2f:
      Serial.print("/");
      break;
    case 0x30:
      Serial.print("0");
      break;
    case 0x31:
      Serial.print("1");
      break;
// etc.
Stigern
#36
Oct 09, 2012, 07:09 pm Last Edit: Oct 09, 2012, 07:13 pm by Stigern Reason: 1
Thanks!
But I've ran into another problem, the VirtualWire library is hard to understand.
I'm using a DHT11 to measure the temperature, now getting the readings from the DHT11 is easy, getting em shown in the serial monitor is easy.
Problem comes when I want to send the readings using VirtualWire, thats hard :P Or I'm sure I'm missing something...
This is my code:
Problems starts in "char *msg = char(DHT11.temperature);" it seems.
// transmitter.pde
// Simple example of how to use VirtualWire to transmit messages
// Implements a simplex (one-way) transmitter with an TX-C1 module
// See VirtualWire.h for detailed API docs
// Author: Mike McCauley (mikem@open.com.au)
// Copyright (C) 2008 Mike McCauley
// $Id: transmitter.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
double A0= 373.15/(273.15 + celsius);
double SUM = -7.90298 * (A0-1);
SUM += 5.02808 * log10(A0);
SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
SUM += log10(1013.246);
double VP = pow(10, SUM-3) * humidity;
double T = log(VP/0.61078);   // temp var
return (241.88 * T) / (17.558-T);
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
double a = 17.271;
double b = 237.7;
double temp = (a * celsius) / (b + celsius) + log(humidity/100);
double Td = (b * temp) / (a - temp);
return Td;
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN 2
#include <VirtualWire.h>
int tempsend;
char tempconv;
char fuck;
   Serial.begin(9600);  // Debugging only
   Serial.println("setup");
   Serial.println("DHT11 TEST PROGRAM ");
   Serial.print("LIBRARY VERSION: ");
   Serial.println(DHT11LIB_VERSION);
   Serial.println();
   // Initialise the IO and ISR
   vw_set_ptt_inverted(true); // Required for DR3100
   vw_setup(2000); // Bits per sec
    Serial.println("\n");
 int chk = DHT11.read(DHT11PIN);
 Serial.print("Read sensor: ");
 switch (chk)
   case 0: Serial.println("OK"); break;
   case -1: Serial.println("Checksum error"); break;
   case -2: Serial.println("Time out error"); break;
   default: Serial.println("Unknown error"); break;
 //Serial.print("Humidity (%): ");
 //Serial.println((float)DHT11.humidity, 2);
 Serial.print("Temperature (oC): ");
 Serial.println(DHT11.temperature);
   digitalWrite(13, true); // Flash a light to show transmitting
   vw_send((uint8_t *)msg, strlen(msg));
   vw_wait_tx(); // Wait until the whole message is gone
   digitalWrite(13, false);
   delay(2000);
Since it complains I can't do "'int' to 'char*'", I tried to set a char() conversion first. But then it complains about this "'char' to 'char*'". So I try to remove the * infront of MSG, but then I get the warning about a constant char...
I'm really confused here, anyone want to help me think this one out?
Sigh, I wish VirtualWire would have more examples showing how to send other values than 'const char'.
I'm from Norway!
CrossRoads
Change a couple of things:
Move these to the top of the sketch
#include <dht11.h>
Delete this unless your transmitter needs a Push to Talk switch (most don't)
put the data you want to send in an array
msg[ ]
then virtualwire will send the msg[] array out.
I can't tell what data type you want to send - DHT11.temperature is a float? thus 4 butes?
So put 4 byte in msg[0] thru msg[3] and let 'er rip.
Stigern
Hm, sorry for not understanding. But the value I'm sending could just be a normal int.
  int convert = DHT11.temperature;
  Serial.println(convert);
   char *msg[3] = convert;
    vw_send((uint8_t *)msg, strlen(3));
    delay(2000);
So after converting my float value to a int, it's basically the value of 23-25 around there. What do you mean by put 4 byte in msg[0] thru msg[3]?
Thanks for all the help so far! :)
I'm from Norway!
CrossRoads
I didn't know how many bytes of data  you were dealing with, so figured you had a float that was 4 bytes long.
I don't know what this does
I would personally do this:
msg[0] = highByte(convert);
msg[1] = lowByte(convert);
and then let virtualwire send the [msg] array out.  Or just grab the low byte if its always <=255
I'd have to look at my remote control code at home to see if
had to change to support that.
Stigern
Hm, got no compiling errors, but it won't send. Led 13 won't even light up, so it can't have gotten that far into the program :P
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN 2
double a = 17.271;
double b = 237.7;
return Td;
int tempsend;
char tempconv;
char fuck;
    Serial.println();
  switch (chk)
   char *msg;
    delay(2000);
I'm from Norway!
CrossRoads
Are you getting any of these?
  switch (chk)
is this doing anything now?
char *msg;
Stigern
#42
Oct 09, 2012, 08:55 pm Last Edit: Oct 09, 2012, 09:03 pm by Stigern Reason: 1
I'm getting the Ok. But I found an example on a blog:
http://genericnerd.blogspot.no/2012/07/arduino-sending-integers-over-rf-with.html
So I took it, and merged it with the DHT11.
Transmitter:
//   FILE:  dht11_test1.pde
// PURPOSE: DHT11 library test sketch for Arduino
//Celsius to Fahrenheit conversion
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN 2
// LED's
const int ledPin = 13;
// Sensors
int Sensor1Data;
//int Sensor2Data;
char Sensor1CharMsg[4];
double Fahrenheit(double celsius)
return 1.8 * celsius + 32;
//Celsius to Kelvin conversion
double Kelvin(double celsius)
return celsius + 273.15;
double a = 17.271;
double b = 237.7;
return Td;
  // LED
pinMode(ledPin,OUTPUT);
 // VirtualWire setup
  // Read and store Sensor 1 data
 Sensor1Data = DHT11.temperature;
 delay(2000);
 // Convert integer data to Char array directly
 itoa(Sensor1Data,Sensor1CharMsg,10);
 // DEBUG
 Serial.print("Sensor1 Integer: ");
 Serial.print(Sensor1Data);
 Serial.print(" Sensor1 CharMsg: ");
 Serial.print(Sensor1CharMsg);
 Serial.print("RawSensor: ");
 Serial.print(DHT11.temperature);
 Serial.println(" ");
 // END DEBUG
digitalWrite(13, true); // Turn on a light to show transmitting
vw_send((uint8_t *)Sensor1CharMsg, strlen(Sensor1CharMsg));
digitalWrite(13, false); // Turn off a light after transmission
delay(200);
// END OF FILE
Reciever:
Sensor Receiver
By Markus Ulfberg 2012-07-06
Gets a sensor reading 0-1023 in a char array
from RF Transmitter unit via VirtualWire
converts char array back to integer
// LED's
int ledPin = 13;
// Sensors
int Sensor1Data;
// RF Transmission container
 // sets the digital pin as output
 pinMode(ledPin, OUTPUT);
   // VirtualWire
   // Bits per sec
   vw_setup(2000);
   // Start the receiver PLL running
   vw_rx_start();
} // END void setup
void loop(){
   uint8_t buf[VW_MAX_MESSAGE_LEN];
   uint8_t buflen = VW_MAX_MESSAGE_LEN;
   // Non-blocking
   if (vw_get_message(buf, &buflen))
   int i;
       // Turn on a light to show received good message
       // Message with a good checksum received, dump it.
       for (i = 0; i < buflen; i++)
         // Fill Sensor1CharMsg Char array with corresponding
         // chars from buffer.
         Sensor1CharMsg[i] = char(buf[i]);
       // Null terminate the char array
       // This needs to be done otherwise problems will occur
       // when the incoming messages has less digits than the
       // one before.
       Sensor1CharMsg[buflen] = '\0';
       // Convert Sensor1CharMsg Char array to integer
       Sensor1Data = atoi(Sensor1CharMsg);
       // DEBUG
       Serial.print("Temp Outside: ");
       Serial.println(Sensor1Data);
       // END DEBUG
       // Turn off light to and await next message
Now it's working. :P Not sure I understand exactly how it parses the int over. I sure need to study arrays more. And just experiment with em.
I'm from Norway!
CrossRoads
Seems to be here:
  itoa(Sensor1Data,  Sensor1CharMsg,  10);
then sends it out
vw_send((uint8_t *)  Sensor1CharMsg  , strlen(  Sensor1CharMsg  ));
itoa is one of those C things that you have to know about to be able to look it up:
http://www.arduino.cc/playground/Code/PrintingNumbers
Stigern
So, there are many other functions other than those listed on Arduino.cc-Reference?
Thanks so much for the help :) I understand much much more than before I read your answers :D
I'm from Norway!
