Topic: Arduino GPS Shield by iteadstudio.com (Read 76280 times) previous topic - next topic
numb3rs295
still no results after 20 minutes..this is what i get:
GPS Shield QuickStart Example Sketch v12
       ...waiting for lock...
is there anything to do with rx and tx pin? because both led in my arduino didn't turn on at all (if that is anything to do with this)
from my understanding of this webpage (http://arduino.cc/en/Reference/SoftwareSerial), if i used software serial i need to use pin other than 2 and 3, since "Not all pins on the Mega and Mega 2560 support change interrupts, so only the following can be used for RX: 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69" (quote from the web)
but i've changed 10 and 11 instead of 2 and 3, but still no effect...
the code you're using is for the GPS shield by iteadstudio.com
you're using another shield, try this code :
  6-8-10
  Aaron Weiss
  SparkFun Electronics
  Example GPS Parser based off of arduiniana.org TinyGPS examples.
  Parses NMEA sentences from an EM406 running at 4800bps into readable
  values for latitude, longitude, elevation, date, time, course, and
  speed.
  For the SparkFun GPS Shield. Make sure the switch is set to DLINE.
  Once you get your longitude and latitude you can paste your
  coordinates from the terminal window into Google Maps. Here is the
  link for SparkFun's location.
  http://maps.google.com/maps?q=40.06477,+-105.20997
  Uses the NewSoftSerial library for serial communication with your GPS,
  so connect your GPS TX and RX pin to any digital pin on the Arduino,
  just be sure to define which pins you are using on the Arduino to
  communicate with the GPS module.
  REVISIONS:
  1-17-11
    changed values to RXPIN = 2 and TXPIN = to correspond with
    hardware v14+. Hardware v13 used RXPIN = 3 and TXPIN = 2.
// In order for this sketch to work, you will need to download
// TinyGPS library from arduiniana.org and put them
// into the hardware->libraries folder in your ardiuno directory.
#include <SoftwareSerial.h>
#include <TinyGPS.h>
// Define which pins you will use on the Arduino to communicate with your
// GPS. In this case, the GPS module's TX pin will connect to the
// Arduino's RXPIN which is pin 3.
#define RXPIN 2
#define TXPIN 3
//Set this value equal to the baud rate of your GPS
#define GPSBAUD 4800
// Create an instance of the TinyGPS object
TinyGPS gps;
// Initialize the NewSoftSerial library to the pins you defined above
SoftwareSerial uart_gps(RXPIN, TXPIN);
// This is where you declare prototypes for the functions that will be
// using the TinyGPS library.
void getgps(TinyGPS &gps);
// In the setup function, you need to initialize two serial ports; the
// standard hardware serial port (Serial()) to communicate with your
// terminal program an another serial port (NewSoftSerial()) for your
// GPS.
  // This is the serial rate for your terminal program. It must be this
  // fast because we need to print everything before a new sentence
  // comes in. If you slow it down, the messages might not be valid and
  // you will likely get checksum errors.
  //Sets baud rate of your GPS
  uart_gps.begin(GPSBAUD);
  Serial.println("");
  Serial.println("GPS Shield QuickStart Example Sketch v12");
  Serial.println("       ...waiting for lock...           ");
  Serial.println("");
// This is the main loop of the code. All it does is check for data on
// the RX pin of the ardiuno, makes sure the data is valid NMEA sentences,
// then jumps to the getgps() function.
  while(uart_gps.available())     // While there is data on the RX pin...
      int c = uart_gps.read();    // load the data into a variable...
      if(gps.encode(c))      // if there is a new valid sentence...
        getgps(gps);         // then grab the data.
// The getgps function will get and print the values we want.
  // To get all of the data into varialbes that you can use in your code,
  // all you need to do is define variables and query the object for the
  // data. To see the complete list of functions see keywords.txt file in
  // the TinyGPS and NewSoftSerial libs.
  // Define the variables that will be used
  float latitude, longitude;
  // Then call this function
  gps.f_get_position(&latitude, &longitude);
  // You can now print variables latitude and longitude
  Serial.print("Lat/Long: ");
  Serial.print(latitude,5);
  Serial.print(", ");
  Serial.println(longitude,5);
  // Same goes for date and time
  int year;
  byte month, day, hour, minute, second, hundredths;
  gps.crack_datetime(&year,&month,&day,&hour,&minute,&second,&hundredths);
  // Print data and time
  Serial.print("Date: "); Serial.print(month, DEC); Serial.print("/");
  Serial.print(day, DEC); Serial.print("/"); Serial.print(year);
  Serial.print("  Time: "); Serial.print(hour, DEC); Serial.print(":");
  Serial.print(minute, DEC); Serial.print(":"); Serial.print(second, DEC);
  Serial.print("."); Serial.println(hundredths, DEC);
  //Since month, day, hour, minute, second, and hundr
  // Here you can print the altitude and course values directly since
  // there is only one value for the function
  Serial.print("Altitude (meters): "); Serial.println(gps.f_altitude());
  // Same goes for course
  Serial.print("Course (degrees): "); Serial.println(gps.f_course());
  // And same goes for speed
  Serial.print("Speed(kmph): "); Serial.println(gps.f_speed_kmph());
  Serial.println();
  // Here you can print statistics on the sentences.
  unsigned long chars;
  unsigned short sentences, failed_checksum;
  gps.stats(&chars, &sentences, &failed_checksum);
  //Serial.print("Failed Checksums: ");Serial.print(failed_checksum);
  //Serial.println(); Serial.println();
hope you it works ..
troyka_4484
I don't think I can help more   :~
but an advice, make sure that you're using your GPS outdoors, and that you're GPS have a clear view to the open sky!
george_seban
hai
as a biginer i am not having much idea about the initial settings required for the operation of GPS module (itead studio gps shield v1.1).
so could you please provide me the idea related to it...
chris4775
Hello, I return on this excellent post and "only one" article on this GPS  which I have just bought. I had difficulty to make it speak and it is thanks to you and especially to Paul that I heard the soft music of wefts come from the sky!!! Ouahh
I shall wish to make two observations and to put two questions.
Obs1: on a deck UNO, it is necessary to use pines 0 and 1 otherwise it do not work. P1=Rx; P2=Tx.
Obs2; it is impossible to download the shetch (all IDE) without creating of fault if pines 1 and 0 are connected. It is necessary to disconnect pine 0 and the download can take place. Mystery!! see pj
Question1: it is impossible to use the exitsI2C. I do not know why but it is boring to connect a LCD. What's going on?
Question2; I implemented the part necessary for the recording on SD by following the only usable link and offert:Gs_logger. I was not "thrown" but I did not know how to write the program.
Can you advise to me there above?
I made another sketch work which allows the employment of a LCD 12x2 and a display  delayed a part of wefts. I wait for one 20x4 to make better.
If it interests somebody!!!
I am French and it is mister Google who made the translation !!! Sorry !!!
Thank you
Nataly
Greetings, troyka 4484 and Paul'S. My name is Nataly from Venezuela.
I have the same gps shield by ITEAD STUDIO ver 1.1.
my question is:
in this image, where i have to put the correct jumper tx & rx ?
thanks for any help...
You can do it, If you want!
PaulS
The RX and TX jumpers define which Arduino pins are used to receive from (RX) or transmit to (TX) the GPS, from the Arduino.
If you don't need to talk to the GPS, put the TX jumper in a drawer. If you want the GPS connected to the hardware serial port, put the RX jumper in column 0. If you want to use SoftwareSerial to listen to the GPS, put the RX jumper in column 2,, 3, 4, 5, 6, or 7, and tell SoftwareSerial which pin you selected. Obviously, the RX jumper bridges the RX row and the unlabeled row.
Nataly
Pauls, I am using this code...
TinyGPS gps;
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
  Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
  Serial.println("by Mikal Hart");
  Serial.println();
  Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
  Serial.println();
  Serial.println("Sats HDOP Latitude Longitude Fix  Date       Time       Date Alt     Course Speed Card  Distance Course Card  Chars Sentences Checksum");
  Serial.println("          (deg)    (deg)     Age                        Age  (m)     --- from GPS ----  ---- to London  ----  RX    RX        Fail");
  Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
  bool newdata = false;
  unsigned long start = millis();
  // Every second we print an update
  while (millis() - start < 1000)
    if (feedgps())
      newdata = true;
  gpsdump(gps);
  float flat, flon;
  unsigned long age, date, time, chars = 0;
  unsigned short sentences = 0, failed = 0;
  static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
  print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
  print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
  gps.f_get_position(&flat, &flon, &age);
  print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5);
  print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5);
  print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
  print_date(gps);
  print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2);
  print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
  print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
  print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
  print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
  gps.stats(&chars, &sentences, &failed);
  print_int(chars, 0xFFFFFFFF, 6);
  print_int(sentences, 0xFFFFFFFF, 10);
  print_int(failed, 0xFFFFFFFF, 9);
  Serial.println();
  char sz[32];
  if (val == invalid)
    strcpy(sz, "*******");
    sprintf(sz, "%ld", val);
  sz[len] = 0;
  for (int i=strlen(sz); i<len; ++i)
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  feedgps();
  char sz[32];
  if (val == invalid)
    sz[len] = 0;
        if (len > 0)
          sz[len-1] = ' ';
    for (int i=7; i<len; ++i)
        sz[i] = ' ';
    Serial.print(sz);
    Serial.print(val, prec);
    int vi = abs((int)val);
    int flen = prec + (val < 0.0 ? 2 : 1);
    flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
    for (int i=flen; i<len; ++i)
      Serial.print(" ");
  feedgps();
  int year;
  unsigned long age;
  gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
  if (age == TinyGPS::GPS_INVALID_AGE)
    Serial.print("*******    *******    ");
    char sz[32];
    sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d   ",
        month, day, year, hour, minute, second);
    Serial.print(sz);
  feedgps();
  int slen = strlen(str);
  for (int i=0; i<len; ++i)
    Serial.print(i<slen ? str[i] : ' ');
  feedgps();
  while (Serial.available())
    if (gps.encode(Serial.read()))
      return true;
  return false;
and this jumper setting...
however, I only get this result...
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   167   0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   334   0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   501   0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   668   0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   1023  0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   1255  0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   1487  0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   1689  0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   1958  0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   2209  0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   2376  0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   2543  0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   2710  0         0
can you tell me in graphic, where put the correct jumpers?
and what code i have to add too.
PaulS
Do you want to use the hardware serial port (pins 0 and 1) to talk to the GPS OR to the PC? You can't use it for both.
Move the jumpers over two columns to the left, and use SoftwareSerial (on pins 2 and 3) to talk to the GPS.
The TinyGPS library includes, I believe, and example that uses NewSoftSerial. Just change that to SoftwareSerial.
Nataly
I want to try just the shield.
using the arduino serial monitor, get latitude and longitude.
Nataly
emmm, using the example> simple_test
i only see in the monitor serial... strange characters :S
/* This sample code demonstrates the normal use of a TinyGPS object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 3(rx) and 4(tx).
TinyGPS gps;
SoftwareSerial ss(3, 4);
  ss.begin(4800);
  Serial.print("Simple TinyGPS library v. "); Serial.println(TinyGPS::library_version());
  Serial.println();
  bool newData = false;
  unsigned short sentences, failed;
  // For one second we parse GPS data and report some key values
  for (unsigned long start = millis(); millis() - start < 1000;)
    while (ss.available())
      char c = ss.read();
      // Serial.write(c); // uncomment this line if you want to see the GPS data flowing
      if (gps.encode(c)) // Did a new valid sentence come in?
        newData = true;
  if (newData)
    float flat, flon;
    unsigned long age;
    Serial.print("LAT=");
    Serial.print(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 6);
    Serial.print(" LON=");
    Serial.print(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 6);
    Serial.print(" SAT=");
    Serial.print(gps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : gps.satellites());
    Serial.print(" PREC=");
    Serial.print(gps.hdop() == TinyGPS::GPS_INVALID_HDOP ? 0 : gps.hdop());
  Serial.print(" CHARS=");
  Serial.print(chars);
  Serial.print(" SENTENCES=");
  Serial.print(sentences);
  Serial.print(" CSUM ERR=");
  Serial.println(failed);
i am using now this jumper setting...
PaulS
Your jumpers are connecting the GPS to Arduino pins 2 and 3, not 3 and 4.
Nataly
thank you very much PaulĀ“s, the gps already working perfectly !!!!
PJ_123
Hello guys I have the same GPS Shield
I was hoping someone can help please,I want to Log the data to the on board SD slot on the GPS shield
But it doesn't seem to log the data to my SD Card  :smiley-fat:
Here is my code it is composed between a tutorial from Jerermy Blum and the Sample GPS code,and PaulS's advice :)
#include <SD.h>
#include <stdlib.h>
TinyGPS gps;
static char dtostrfbuffer[20];
const int chipSelect = 10;
int LED = 13;
//Define String
String SD_date_time = "invalid";
String SD_lat = "invalid";
String SD_lon = "invalid";
String dataString ="";
static void print_float(float val, float invalid, int len, int prec, int SD_val);
//Serial interfaces
   pinMode(10, OUTPUT);  //Chip Select Pin for the SD Card
   pinMode(LED, OUTPUT);  //LED Indicator
  //Connect to the SD Card
  if (!SD.begin(chipSelect))
    Serial.println("Card Failure");
    return;
  Serial.println();
  Serial.println();
    if (feedgps())
      newdata = true;
  gpsdump(gps);
  //Write the newest information to the SD Card
  dataString = SD_date_time + "," + SD_lat + "," + SD_lon;
  if (SD_date_time != "invalid")
    digitalWrite(LED, HIGH);
    digitalWrite(LED, LOW);
  //Open the Data CSV File
  File dataFile = SD.open("LOG.csv", FILE_WRITE);
  if (dataFile)
    dataFile.println(dataString);
    Serial.println(dataString);
    dataFile.close();
    Serial.println("\nCouldn't open the log file!");
  float flat, flon;
  print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5, 1); //LATITUDE
  print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5, 2); //LONGITUDE
  print_date(gps); //DATE AND TIME
  print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2, 0);
  print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2, 0);
  print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2, 0);
  print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2, 0);
  Serial.println();
  char sz[32];
  if (val == invalid)
  sz[len] = 0;
    sz = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  feedgps();
  char sz[32];
  if (val == invalid)
    sz[len] = 0;
        if (len > 0)
          sz[len-1] = ' ';
        sz = ' ';
    Serial.print(sz);
    if(SD_val == 1) SD_lat = sz;
    else if(SD_val == 2) SD_lon = sz;
    if (SD_val == 1) SD_lat = dtostrf(val,10,5,dtostrfbuffer);
    else if (SD_val == 2) SD_lon = dtostrf(val,10,5,dtostrfbuffer);
      Serial.print(" ");
  feedgps();
  int year;
  unsigned long age;
    char sz[32];
    Serial.print(sz);
    SD_date_time = sz;
  feedgps();
    Serial.print(i<slen ? str : ' ');
  feedgps();
      return true;
  return false;
Thanks in Advance!
AWOL
Did your source have italics in it?
Did you read the sticky thread at the top of this section?
jerseyguy1996
yes the code i attached worked...
now i am trying this TingGPS example
i tried both baud rates 9600 (it was used in the demo) & 38400 the baud rate give in the data sheet..
but all i get is stars....
here's my results :
Testing TinyGPS library v. 12
by Mikal Hart
Sizeof(gpsobject) = 115
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   173   0         0
**** **** *******  *******   **** *******    *******    **** ******* ****** ***** ***   0        0.00   ***   310   0         0
etc...
once again, thank you for your help, Paul  :)
I don't know if anyone pointed this out to you yet but the reason you are getting stars is because these functions print stars if the data that it gets is invalid:
  char sz[32];
  if (val == invalid)
  sz[len] = 0;
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  feedgps();
  char sz[32];
  if (val == invalid)
    sz[len] = 0;
        if (len > 0)
          sz[len-1] = ' ';
        sz[i] = ' ';
    Serial.print(sz);
      Serial.print(" ");
  feedgps();
  int year;
  unsigned long age;
    char sz[32];
    Serial.print(sz);
  feedgps();
The reason the data is coming up as invalid is because all it is receiving from the GPS is 0xFFFFFFFF which means the GPS is putting out data but it doesn't have enough satellite fixes to output valid data.  You can see that the UART is receiving information from the GPS because in your data above you can see the number of characters received go from 173 to 310.  Once the GPS gets I believe 4 satellite fixes it will start putting out valid data.  Are you testing this inside?  Check out this video tutorial....it will help a lot:
http://www.jeremyblum.com/2012/07/16/tutorial-15-for-arduino-gps-tracking/
Arduino Uno;
Mega328
