Topic: Photointerupter (Read 935 times) previous topic - next topic
xan213
Can someone tell me how to use this sensor  to measure rpm on a stepper motor. Specifically I would like to know how this sensor works and how to connect the 4 pins from the sensor to my arduino. I have attached the data sheet for a similar sensor (i think).
1.http://i1062.photobucket.com/albums/t494/xan213/100_5040.jpg
2. http://i1062.photobucket.com/albums/t494/xan213/100_5046.jpg
3.http://i1062.photobucket.com/albums/t494/xan213/100_5050.jpg
Carsten53T
I think that once you know how to connect and read the sensor, the rest will follow.
Quote
Where?
The 4 pins probably comes in pairs. Two of them is for the emitter (arduino +5 -> resistor -> arduino ground).
One of the other two is the output from the sensor .. but you'll have to look up what else. It's not unusual that the sensor can take a higher voltage than the +5 arduino.
Magician
#2
Jul 10, 2012, 11:22 pm Last Edit: Jul 10, 2012, 11:25 pm by Magician Reason: 1
Look at SFE: http://www.sparkfun.com/products/9299
there is data sheet, though may be not exactly the same, but don't think they differ much.
And more on software (advanced level ?) : http://www.sparkfun.com/products/9209
Carsten53T
Magician,
The photointerrupter you link to has 5 wires.
You'll be surprised at what you can find on the net:
http://www.datasheetcatalog.org/datasheet/fairchild/H21A1.pdf
