Topic: SD read and store (Read 4571 times) previous topic - next topic
mrquacks
Hello,
I'm pretty new to Arduino code, though I've been doing Java for a while... makes this a little confusing. What I'm trying to do is read single lines from an SD and then split the data based on various delimiters and store them. For each line, there's a keyword and several associated words, so I want to store the key in a HashMap and have the value be a Queue of the other words.
I found premade HashMap and QueueList libraries (which have worked for me thus far) but I've run into a problem.  I can successfully read the data and store the key in the table and I can store the other words into a QueueList, but I can't seem to store the QueueList with the key.
For example, in the following code (***note database is my HashMap variable name, and split is function I have for splitting strings), the print statements at the bottom (resp.pop()) all print out the correct thing. I've also checked the HashMap and they key is successfully stored, but when I try to print something like database.valueAt(key).pop(), it prints a blank line.
 Serial.println("Start");
 SD.begin(4);
 File file = SD.open("brain.txt");
 if (SD.exists("brain.txt")) {
   Serial.println("Exists.");
   Serial.println("boo.");
 char buff[500];
 memset(buff, 0, sizeof(buff));
 int idx = 0;
 while (file.available())
   char c = file.read();
   if (c != '\n' && c != '\r')
     buff[idx] = c;
     idx++;
   else {
     QueueList<String> resp;
     int rNo = 1;
     for (int i = 0; i < strlen(split(buff, ":", 2)); i++) {
       if (split(buff, ":", 2)[i] == '/') {
         rNo++;
     for (int i = 1; i <= rNo; i++) {
       resp.push(split(split(buff, ":", 2), "/", i));
     database[split(buff, ":", 1)] = resp;
     Serial.println(resp.pop());
     idx = 0;
I'm afraid the issue is something with passing values or whatnot, but I'm not sure.
Thanks for your help!
WizenedEE
Well, you have 2048 bytes of ram. The SD card library uses 512 bytes, and your buf arrays uses another 500. I'm guessing the other two libraries you're using also use up quite a bit. So, I think the problem is here:
You're going to need to give up some stuff to save memory when working on microcontrollers.
Eg:
You're going to need to get rid of buf and read one line at a time and find the delimiters in the stream.
Both resp and database seem to be storing huge amounts of things on the Heap little by little. This makes memory fragmentation run rampant. Get rid of them if at all possible.
PaulS
Posting code snippets only makes it very difficult to help you. How is database defined? what does the split() function do?
What does a sample line from your file look like? How many lines are there?
wildbill
Given your apparent memory needs, you might find it easier to use a Mega (assuming you're not already) to get more RAM. I assume you're concentrating on the config load piece for now; what will you be doing once you have this working (i.e. what is your project supposed to do) and is there any way to store that config data in a less heap intensive way?
mrquacks
Hey thanks for the replies.
I'm working on a Mega and have already bought a QuadRAM attachment which will add 512 kilobytes of RAM. This was just a testing sketch to see if I could properly read in data... the split function is the only thing I didn't include and it looks as follows:
char* split (char* str, char *delim, int index)
  char *act, *sub, *ptr;
  static char copy[100];
  int i;
  // Since strtok consumes the first arg, make a copy
  strcpy(copy, str);
  for (i = 1, act = copy; i <= index; i++, act = NULL)
    sub = strtok_r(act, delim, &ptr);
    if (sub == NULL) break;
  return sub;
I found it somewhere else on the arduino forum. As for one line of the txt file.. thats formatted like:
keyword:word1/word2/word3
The reading in is fine and the splitting is fine (from what I've tested). The storing is even fine--Just not when I try to call a specific QueueList out of the HashMap. The QueueList is found here: http://arduino.cc/playground/Code/QueueList and the HashMap was taken from http://wiring.uniandes.edu.co/source/trunk/wiring/firmware/libraries/HashMap/
If you think its a problem with RAM, the part should arrive today or tomorrow and I can continue debugging.  I was just wondering if you saw anything obviously wrong in the code. Ultimately, this will be used to store responses to certain actions (and there are a lot of them) for a stand alone Arduino board, so I thought this would be the easiest way to do that since it won't be connected to a computer.  Learning the limitations of a microcontroller is definitely something I should do, but really this project is more about a proof of concept in a limited amount of time than being extremely efficient. Thanks!
PaulS
Why are you using the thread-safe version of strtok() on a single-threaded processor?
What is it you expect split() to do? As I read it, it returns the last token in a string.
Assigning a pointer to point to the start of an array is silly. The strtok() function expects an array of characters that is NULL terminated.
The strtok() function is much simpler, having only two arguments.
mrquacks
Thanks for the quick reply. I just found that function somewhere on the Arduino forum and used it for testing.
I've rewritten the code as WizenedEE suggested and just split the input as each character comes in.  The following code is the updated version which at the end tells me how many response words were stored in the QueueList that is matched with each keyword in the HashMap and gives the right numbers.  Unfortunately, the actual things that are stored there are still gibberish.  That being said, if I pop() directly from the QueueList before it is put into the HashMap, the Strings are correct.
#include <SD.h>
#include <QueueList.h>
#include <HashMap.h>
#include <string.h>
HashMap<String, QueueList<String>, 50> database = HashMap<String, QueueList<String>, 50>();
  SD.begin(4);
  char buff[150];
  int idx = 0;
    char key[25];
    memset(key, 0, sizeof(key));
    while (file.peek() != '\n' && file.peek() != '\r')
      if (c != ':' && c != '/')
        buff[idx] = c;
        idx++;
      else {
        if (c == ':')
          strlcpy(key, buff, sizeof(key));
          idx = 0;
        else if (c == '/')
          resp.push(buff);
          idx = 0;
    file.read(); //toss new line character
    resp.push(buff); //push last response
    database[key] = resp;
    int N = resp.count();
    for (int i = 0; i < N; i++)
      resp.pop();
    idx = 0;
  for (int i = 0; i < database.size(); i++) {
    QueueList<String> test = database.valueAt(database.keys[i]);
    Serial.println(test.count());
void loop() {}
Is the limitation on RAM the reason gibberish is popped when the QueueList is drawn out of the HashMap? Still waiting on that part...
PaulS
You are creating a QueueList object on the heap. When the object goes out of scope, the storage space is reused. You are assigning that location to database[n], which should do a deep copy, but apparently does not.
I'd take a look at how the copy constructor for the HashMap class is implemented, if it is. If it isn't, that would explain the lack of a deep copy.
I think you are going to need to venture into the wonderful world of pointers and malloc() and free() (or new and delete).
mrquacks
That makes sense, PaulS--the code for the HashMap library is:
/* $Id$
|| @author         Alexander Brevig <abrevig@wiring.org.co>
|| @url            http://wiring.org.co/
|| @url            http://alexanderbrevig.com/
|| @contribution   Brett Hagman <bhagman@wiring.org.co>
||                 Timothy Trieu (add overloaded valueAt to accept
||                                key as an argument)
|| @description
|| | Implementation of a HashMap data structure.
|| | Wiring Cross-platform Library
|| @license Please see cores/Common/License.txt.
#ifndef HASHMAP_H
#define HASHMAP_H
//for convenience
#define CreateHashMap(hashM, ktype, vtype, capacity) HashMap<ktype,vtype,capacity> hashM
#define CreateComplexHashMap(hashM, ktype, vtype, capacity, comparator) HashMap<ktype,vtype,capacity> hashM(comparator)
template<typename K, typename V, unsigned int capacity>
class HashMap
  public:
    typedef bool (*comparator)(K, K);
    || @constructor
    || | Initialize this HashMap
    || @parameter compare optional function for comparing a key against another (for complex types)
    HashMap(comparator compare = 0)
      cb_comparator = compare;
      currentIndex = 0;
    || @description
    || | Get the size of this HashMap
    || @return The size of this HashMap
    unsigned int size() const
      return currentIndex;
    || @description
    || | Get a key at a specified index
    || @parameter idx the index to get the key at
    || @return The key at index idx
    K keyAt(unsigned int idx)
      return keys[idx];
    || @description
    || | Get a value at a specified index
    || @parameter idx the index to get the value at
    || @return The value at index idx
    V valueAt(unsigned int idx)
      return values[idx];
    || @description
    || | Get a value at a specified key
    || @parameter key the key to get the value at
    || @return The value at key
    V valueAt(K key)
      unsigned int idx = indexOf(key);
      return valueAt(idx);
    || @description
    || | Check if a new assignment will overflow this HashMap
    || @return true if next assignment will overflow this HashMap
    bool willOverflow()
      return (currentIndex + 1 > capacity);
    || @description
    || | An indexer for accessing and assigning a value to a key
    || | If a key is used that exists, it returns the value for that key
    || | If there exists no value for that key, the key is added
    || @parameter key the key to get the value for
    || @return The const value for key
    const V& operator[](const K key) const
      return operator[](key);
    || @description
    || @return The value for key
      if (contains(key))
        return values[indexOf(key)];
      else if (currentIndex < capacity)
        keys[currentIndex] = key;
        values[currentIndex] = nil;
        currentIndex++;
        return values[currentIndex - 1];
      return nil;
    || @description
    || | Get the index of a key
    || @parameter key the key to get the index for
    || @return The index of the key, or -1 if key does not exist
    unsigned int indexOf(K key)
      for (int i = 0; i < currentIndex; i++)
        if (cb_comparator)
          if (cb_comparator(key, keys[i]))
            return i;
          if (key == keys[i])
            return i;
      return -1;
    || @description
    || | Check if a key is contained within this HashMap
    || @parameter key the key to check if is contained within this HashMap
    || @return true if it is contained in this HashMap
    bool contains(K key)
        if (cb_comparator)
            return true;
          if (key == keys[i])
            return true;
      return false;
    || @description
    || @parameter key the key to remove from this HashMap
    void remove(K key)
      int index = indexOf(key);
      if (contains(key))
        for (int i = index; i < capacity - 1; i++)
          keys[i] = keys[i + 1];
          values[i] = values[i + 1];
        currentIndex--;
    void setNullValue(V nullv)
      nil = nullv;
  public:
    K keys[capacity];
  protected:
    V values[capacity];
    V nil;
    int currentIndex;
    comparator cb_comparator;
#endif
// HASHMAP_H
I don't think the constructor makes deep copies, so I tried using new and delete for the QueueList object, though I got the same result. Perhaps (more like probably) I did it wrong.
#include <SD.h>
#include <string.h>
  SD.begin(4);
  char buff[150];
  int idx = 0;
    char key[25];
    QueueList<String> *ptr = new QueueList<String>;
    ptr = &resp;
        buff[idx] = c;
        idx++;
      else {
        if (c == ':')
          idx = 0;
        else if (c == '/')
          resp.push(buff);
          idx = 0;
    delete ptr;
    idx = 0;
  QueueList<String> test = database.valueAt("%ha");
  while (!test.isEmpty()) {
    Serial.println(test.pop());
void loop() {}
Thanks
PaulS
    ptr = &resp;
You still have a QueueList on the heap. Then, you dynamically create another one, pointer to by ptr. But, then you discard the address where the dynamic memory allocation occurred, and point to the first QueueList on the heap. That memory just leaked, and you can never recover it.
Get rid of resp and the reassignment of ptr. Change all the "resp." strings to "ptr->".
mrquacks
#10
Jul 12, 2012, 10:58 pm Last Edit: Jul 13, 2012, 07:13 pm by mrquacks Reason: 1
I see. I read that syntax from a tutorial somewhere, but I've changed it to what you suggested.  It compiles, but still gives me the same output as before. I think the problem may be with the way I stored the QueueList into the HashMap. To get it to compile I did:
database[key] = *ptr;
But I'm not sure if that's the right syntax. Or maybe something else is wrong.
// keys can only be max 25 chars
#include <SD.h>
#include <string.h>
  SD.begin(4);
  char buff[150];
  int idx = 0;
    char key[25];
        buff[idx] = c;
        idx++;
      else {
        if (c == ':')
          idx = 0;
        else if (c == '/')
          ptr->push(buff);
          idx = 0;
    ptr->push(buff); //push last response
    int N = ptr->count();
      Serial.println(ptr->pop());  //testing
    delete ptr;
    idx = 0;
void loop() {}
mrquacks
So I've been testing but getting no where. Here is the txt file and the output I get, if that helps.
brain.txt
%ex:duration = _duration/defaultUser = _defaultUser/currentUser = _currentUser/prevUser = _prevUser
%ha:good/yay
For testing purposes, I only look at what was stored in the QueueList for %ha
Start
Exists.
good
yay
call out QueueList from HashMap
wa
My code is:
#include <SD.h>
#include <string.h>
  SD.begin(4);
  char buff[150];
  int idx = 0;
    char key[25];
        buff[idx] = c;
        idx++;
      else {
        if (c == ':')
          idx = 0;
        else if (c == '/')
          ptr->push(buff);
          idx = 0;
    delete ptr;
    idx = 0;
  Serial.println("\ncall out QueueList from HashMap");
void loop() {}
PaulS
I'd like to see a link as to where you got this library, to confirm something.
This looks to me like you are trying to create a HashMap instance of a templated class, where the instance uses a String, a QueueList (that is an instance of a templated class that takes a String) object,  and int argument.
I think the 2nd argument to the templated class needs to be a pointer to an type, not a type.
mrquacks
I got the HashMap from
https://github.com/krohling/ArduinoPusherClient/tree/master/HashMap
I would've gotten it directly from the person who made it, but I think there was a bug that this guy fixed so I used this version instead.
mrquacks
I'm still not exactly sure what you meant in the last post, but I tried adding a * after the QueueList<String> argument. Still got the same result though.
#include <SD.h>
#include <string.h>
HashMap<String, QueueList<String>*, 50> database = HashMap<String, QueueList<String>*, 50>();
  SD.begin(4);
  char buff[150];
  int idx = 0;
    char key[25];
        buff[idx] = c;
        idx++;
      else {
        if (c == ':')
          idx = 0;
        else if (c == '/')
          ptr->push(buff);
          idx = 0;
    database[key] = ptr;
    delete ptr;
    idx = 0;
  QueueList<String>* test = database.valueAt("%ha");
  while (!test->isEmpty()) {
    Serial.println(test->pop());
void loop() {}
