Topic: [HELP] Running 2 programs at once. (Read 4072 times) previous topic - next topic
Gin319
I just got the arduino, and basically, i'm going to make a program that controls a servo independently with a set or instructions, and reads values from a temperature sensor independently and does another action when a certain value is reached.
I'm planning to do this with one arduino, is this possible?
--Gin319
WizenedEE
Sure. You just have to make sure your main loop doesn't wait for anything -- essentially, no while loops.
Gin319
Will the delay command have any effect?
--Gin319
AWOL
It may well do.
But we can't see your code.
GoForSmoke
You might find this page helpful:
http://www.gammon.com.au/forum/?id=11425
especially look for the post on state machines.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
PaulS
It may well do.
I think you misspelled "Most definitely!".
Nick Gammon
It will delay execution.
More info:
Gin319
#7
Jul 12, 2012, 06:46 am Last Edit: Jul 12, 2012, 06:50 am by Gin319 Reason: 1
thanks for your replies.
Let's say that I want to control 2 LEDs independently, with different pin connections and effects.
WizenedEE mentioned something about the code being in the main loop. How do I make 2 independent loops?
I've given values for the pinouts for the second LED, so where do I put it in the code for an independent operation?
I got this code from the examples library in the Arduino software, and I added the new pinout on the second line of the code.
Regarding the delay, how do I program it without affecting eachother?
int led = 13;
int led0 = 9;
 pinMode(led, OUTPUT);
 pinMode(led0, OUTPUT);
 digitalWrite(led, HIGH);
 digitalWrite(led, LOW);
--Gin319
Arrch
You don't. You need to make your code work together within a single loop.
Look at the Blink Without Delay example.
Nick Gammon
http://www.gammon.com.au/blink
More info:
Gin319
Thanks for the link. I kinda understand how it works. Now let's say that I wanted to take temperature readings and then control a servo motor independently.
Using this code that I got from your link, can you please give me an idea on how to place it in this code?
Thanks.
// Which pins are connected to which LED
const byte greenLED = 12;
const byte redLED = 13;
// Time periods of blinks in milliseconds (1000 to a second).
const unsigned long greenLEDinterval = 500;
const unsigned long redLEDinterval = 1000;
// Variable holding the timer value so far. One for each "Timer"
unsigned long greenLEDtimer;
unsigned long redLEDtimer;
void setup ()
  pinMode (greenLED, OUTPUT);
  pinMode (redLED, OUTPUT);
  greenLEDtimer = millis ();
  redLEDtimer = millis ();
  }  // end of setup
void toggleGreenLED ()
   if (digitalRead (greenLED) == LOW)
      digitalWrite (greenLED, HIGH);
      digitalWrite (greenLED, LOW);
  // remember when we toggled it
  }  // end of toggleGreenLED
void toggleRedLED ()
   if (digitalRead (redLED) == LOW)
      digitalWrite (redLED, HIGH);
      digitalWrite (redLED, LOW);
  }  // end of toggleRedLED
void loop ()
  // Handling the blink of one LED.
  if ( (millis () - greenLEDtimer) >= greenLEDinterval)
     toggleGreenLED ();
  // The other LED is controlled the same way. Repeat for more LEDs
  if ( (millis () - redLEDtimer) >= redLEDinterval)
    toggleRedLED ();
/* Other code that needs to execute goes here.
   It will be called many thousand times per second because the above code
   does not wait for the LED blink interval to finish. */
}  // end of loop
--Gin319
PGT
void setup{
i=0;
s=0;
r=0;}
void loop {
if ( i % 5 == 0 )
   {  s=1-s;
      if (s<0){digitalwrite (relight,HIGH); } else {digitalwrite (redlight,LOW)};   // define redlight pin in setup
if ( i % 100 == 0 )
{  r=1-r;
    if (r<0){digitalwrite (greenlight,HIGH); } else {digitalwrite (greenlight,LOW)};   // define greenlight pin in setup
//delay below
for sure this programs runs to fast to see redlight blink you add delay or use higer numeber after the %    .. i % 5000
just another way of doing it, based on modulo calculation
Arrch
BIG Clue here:
PaulS
What does this mean. You have one computer and two jobs. How can you expect to do them independently? Doing one right after the other (read the temps; diddle with the servo; read the temps; diddle with the servo) makes sense. Doing the two tasks independently requires two Arduinos. Help me understand what independently means to you.
GoForSmoke
Maybe thermometer and servo are the independent parts?
Gin, loop() is your friend. Every time through can be 100 microseconds or less later, if your code doesn't hang things up. Inside loop() you can have a block of code that watches the sensor and the next block of code runs the servo. Each runs then loop() starts again and loop() is perpetually 'now'... but only if your code doesn't block.
