Topic: High output variable voltage (Read 1 time) previous topic - next topic
Solid
Hello.
I have a question about a project that I am starting.
What I have
5 meters of led strip (http://www.sparkfun.com/products/10260)
14.4V power supply
What I need
I want to let the arduino to set 0-12V (variable voltage) to each R/G/B wire, by using external power supply.
Because the whole chain takes 6000 mA @ 12.0V
What I know
The PWM ports can only output 0-5V, and 60 mA per channel.
Can anybody direct me to the right direction, which components are best here?
Linear Regulators, Shift Register or what.
What is the easiest way?
PaulS
What I know
You might want to check this fact. The recommended upper limit is usually 40mA, with 20mA being recommended for long term use.
You can use a transistor to control each leg. Transistors can toggle at PWM speeds, and can control that amount of current.
AWOL
sp. "The PWM ports can only output 0 or 5V"
Solid
Whoops... thanks for the correction.
so a PWM pin set to 50% duty cycle, connected to transistor and external power supply, should give me 50% brightness on led strip ?
How do you hook up an transistor to external power supply?
JimboZA
.... like this
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Solid
Can these transistors, like BC546, hold up to 2A@12V ?
the datasheet says 100 mA / 500 mW.
Any other solution ?
JimboZA
You'll need to look at the datasheets for various transistors...
