Topic: Arduino or ARM (Read 11351 times) previous topic - next topic
arduinopi
I was wondering if I wanted to make a complex robot, what would be some pros and cons of using ARM over Arduino?
All of my projects --> http://www.frankmagazu.com/
Leon Heller
#1
Jul 11, 2012, 04:25 pm Last Edit: Jul 11, 2012, 04:27 pm by Leon Heller Reason: 1
Much higher performance, more I/Os, more peripherals, debugger, and more memory.
Leon Heller
G1HSM
PaulS
If you are building a spider type robot, a bunch of ARMS won't be very useful.
graynomad
I think an ARM would be better although it depends on how complex your robot will be. That said most current robots seem to do well with an AVR chip.
If you're willing to wait you can have both, an Arduino and an ARM if th eDue gets released.
_____
Rob
bperrybap
A brief list of pros/cons
Cons vs AVR
- larger code (but you tend to have more flash available)
- often higher cost
- 3v vs 5v outputs
- lower current outputs
- many existing libraries won't work
- less knowledge base on using "arduino" environment on non AVR chips.
Pros vs AVR
- 32 bit
- MUCH faster
- more RAM
- No more harvard architecture worries and having to deal with things like progmem etc...
If you want to use an Arduino environment you can use the Chipkit (MIPS processor)
or Maple (ARM) now rather than wait on the DUE.
The nice thing about the Chipkit development environment (mpide) is that it is designed to support
multiple processors.
So you can use both the AVR processors and the MIPS processors with the same single environment
and IDE.
The Maple uses its own IDE that is only for the Maple.
While not all the libraries work on the Chipkit or Maple as some of them are hard coded for AVR
(the DUE will have the same issues) it is available today vs ????? for the DUE.
--- bill
pYro_65
It also depends on how efficiently you can make use of the available resources. Your programming skills are a strong deciding factor as to what is suitable. If you still have a learning curve to get through ( c++, electronics, transport ( spi, i2c ) ) you will benefit yourself by using the easier system to use. A more complex system requires a greater background knowledge to use properly, by jumping in the deep end assumptions will start to creep into your design and may eventually ruin or degrade your original idea.
Forum Mod anyone?
https://arduino.land/Moduino/
cmiyc
If I was to throw a party, what would be better:  a big cake or some cookies?  Apples or oranges?
Without more details on what "complex" means, answering the question is an exercise in futility.  The Arduino is based on a Microcontroller.  It is good at controlling things.  Processors with an ARM-core (ARM doesn't sell silicon), are generally Microprocessors.  They are good at processing data.
Just as with my party question you first decide what you want the party to be first, then you decide what to get for it.
Leon Heller
#7
Jul 12, 2012, 10:37 am Last Edit: Jul 12, 2012, 11:16 am by Leon Heller Reason: 1
ARM designs both MPUs and MCUs. The NXP 28-pin LPC1114 is a typical MCU:
http://www.leonheller.com/LPC1114%20(DIP28)/PCB.jpg
Leon Heller
G1HSM
dxw00d
ARM didn't design the LPC1114, it just uses a licenced ARM core, a Cortex-M0.
graynomad
I love the fact the the LPCs are available in small packs, using a wide 28-pin is a little strange but at least it's a DIP.
______
Rob
Leon Heller
It is strange, given that they will be producing a SOIC version. The 0.3" DIP28 package that Microchip uses for the PIC32 is much nicer.
That version of the LPC1114 isn't generally available yet, I got some samples from a contact at NXP.
Leon Heller
G1HSM
Leon Heller
I didn't say that ARM designed the LPC1114!
Leon Heller
G1HSM
dxw00d
Sorry, you're right, you didn't.
JJC114
I just picked up on this topic and had a related question - if you don't mind -
Can you program PICs and ARM etc. using the Arduino language or do you use pure C++ or even Assembly?
Thanks
AWOL
The Arduino language is C++
PICs
That's fightin' talk in these parts, stranger.
