Topic: Increasing two different servo PWM's with different delay's (Read 4185 times) previous topic - next topic
flotilla
#15
Jul 12, 2012, 11:42 am Last Edit: Jul 12, 2012, 11:44 am by flotilla Reason: 1
Within one continous loop
every 60 seconds - increase servoA pwm by 4
every 120 seconds - increase servoB pwm by 3
I'm really curious why you want the motor to run faster and faster, instead of a constant speed. Every clock I own has a motor that runs at a constant speed. I can't help but think I am missing something.
Hi, Increasing the PWM is not increasing the speed, it is increasing the position of the motor around the 360 degrees, for example: on the minute hand
1600pwm is midnight 1604 is one minute past 1608- two minutes past and so on.  So adding 4 to the microseconds every minute is moving the servo by one minute on the clock, every minute.
The need for a different speed on the hour hand is due to it having to only cover 1/12th of the 360 degrees in an hour.  My maths above for the hour hand were wrong however.  It is actually 3 increments every 6 minutes, not every two.
The clock is for a theatre show where there are 6 scene changes in the show. At each scene change the stage crew press a button and the time zips to the next scene time then starts ticking away until the next button is pressed, moving it on to the next scene.
I will post the full code on a seperate post for anyone who is interested. It is not perfect and probably a little messy (I still class myself as a complete newbie to all this)  It works very well at the moment and keeps proper time to within a minute which is fine for my purposes.
PaulS
My apologies. For some reason, I had it in my head that you were using continuous rotation servos.
flotilla
My full code for community purposes and anyone who is interested.  Be gentle! I know there are probably easier ways to do this.
#include <Servo.h>
#include <SoftwareSerial.h>
Servo MinuteHand;
Servo HourHand;
// SWITCH PINS
byte setupAswitch = A0;
byte setupBswitch = A1;
byte setupCswitch = A2;
byte setupDswitch = A3;
byte setupEswitch = A4;
byte setupFswitch = A5;
byte ResetSwitch = 2;
//  SERVO PINS
int MinuteHandPin = 9;     // Control pin for servo motor
int HourHandPin = 10;
//  STORAGE VALUES
int MinutePulse; // Storage value for counting time, MinuteHand
int HourPulse; // Storage value for counting time, HourHand
long previousMillisA = 0;        // Millis Counter Store
long previousMillisB = 0;        // Millis Counter Store
long StepperAinterval = 60000; // 60 seconds break time between MINUTE movements
long StepperBinterval = 360000; // 6 minute break time between HOUR movements
byte mode; //
 Serial.begin(9600);         // connect to the serial port
 Serial.println("**********    SETTING UP CLOCK CIRCUIT    **********"); //saying how it is
//  SWITCH SETUP
pinMode      (setupAswitch, INPUT); // set up the various push switches
digitalWrite (setupAswitch, HIGH);  // turn on internl pullup
pinMode      (setupBswitch, INPUT);
digitalWrite (setupBswitch, HIGH);
pinMode      (setupCswitch, INPUT);
digitalWrite (setupCswitch, HIGH);
pinMode      (setupDswitch, INPUT);
digitalWrite (setupDswitch, HIGH);
pinMode      (setupEswitch, INPUT);
digitalWrite (setupEswitch, HIGH);
pinMode      (setupFswitch, INPUT);
digitalWrite (setupFswitch, HIGH);
pinMode      (ResetSwitch, INPUT);
digitalWrite (ResetSwitch, HIGH);
// SERVO SETUP
MinuteHand.attach(MinuteHandPin);  //Connects servo to relevent pin
HourHand.attach(HourHandPin);
// SET BOTH SERVOS TO 'MIDNIGHT'
MinuteHand.writeMicroseconds(1600);  /// SET to 12.00
HourHand.writeMicroseconds(1600);  /// SET to 12.00
// START MILLIS TIMER
//unsigned long CurrentMillisA = millis();  //Storage for Timer NOT SURE IF RIGHT ONE!!!
Serial.println("WAITING FOR INPUT");
if ( mode == 0 && digitalRead (setupAswitch) == LOW){ mode = 1;}
if ( mode == 0 && digitalRead (setupBswitch) == LOW){ mode = 2;}
if ( mode == 0 && digitalRead (setupCswitch) == LOW){ mode = 3;}
if ( mode == 0 && digitalRead (setupDswitch) == LOW){ mode = 4;}
if ( mode == 0 && digitalRead (setupEswitch) == LOW){ mode = 5;}
if ( mode == 0 && digitalRead (setupFswitch) == LOW){ mode = 6;}
if ( mode == 0 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 1 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 2 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 3 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 4 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 5 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 6 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 7 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
////PROGRAM VARIABLES/SERVO SETUPS
switch (mode){
case 0:  // Do Nothing and Wait for input
break;
case 1:  // Set Clock start position A
MinutePulse = 1600;  // sets the stored Minute value to match the time
HourPulse = 1600;   //sets the stored Hour value to match the time set
MinuteHand.writeMicroseconds(MinutePulse); // sets Time A min
HourHand.writeMicroseconds(HourPulse);  // sets Time A hour
Serial.print("HOUR PWM VALUE IS SET TO ");
Serial.println(HourPulse);
Serial.print("MINUTE PWM VALUE IS SET TO ");
Serial.println(MinutePulse);
delay (1000);
Serial.println("TICKING 1");
previousMillisA = 0; //Reset Millis Counter A
previousMillisB = 0; //Reset Millis Counter B
mode= 7;
break;
case 2:  // Set Clock start position B
delay (1000);
Serial.println("TICKING 2");
mode= 7;
break;
case 3:  // Set Clock start position C
delay (1000);
Serial.println("TICKING 3");
mode= 7;
break;
case 4:  // Set Clock start position D
delay (1000);
Serial.println("TICKING 4");
mode= 7;
break;
case 5:  // Set Clock start position E
delay (1000);
Serial.println("TICKING 5");
mode= 7;
break;
case 6:  // Set Clock start position F
delay (1000);
Serial.println("TICKING 6");
mode= 7;
break;
case 7: // Commence Time
if (MinutePulse >= 2495) mode = 10; //servo safety to stop it over-turning
if (HourPulse >= 2495) mode = 10;
// Serial.println(CurrentMillisA);
// Serial.println(CurrentMillisB);
 if(CurrentMillisA - previousMillisA > StepperAinterval) {
   previousMillisA = CurrentMillisA;
   MinutePulse = MinutePulse + 4;
 if(CurrentMillisA - previousMillisB > StepperBinterval) {
   previousMillisB = CurrentMillisA;
   HourPulse = HourPulse + 2;
case 9:  //  RESET THE PROGRAM
Serial.println("RESETTING & JOGGING");
MinuteHand.writeMicroseconds(1700); // Jogs the motor to ensure a 'midnight'
HourHand.writeMicroseconds(1700);
delay (1000);
MinuteHand.writeMicroseconds(1600); // Jogs the motor
MinutePulse = 1600;  // resets values
HourPulse = 1600;
Serial.print("HOUR PWM VALUE IS RESET TO MIDNIGHT");
Serial.print("MINUTE PWM VALUE IS RESET TO MIDNIGHT");
delay (1000);
mode = 0;
break;
case 10:  //  SERVO OVERREACH
Serial.println("******   BWEEP SERVO OVERREACH   *******");
Serial.print("SERVO OR PWM VALUE IS ");
delay (3000);
MinutePulse = 1600;  // resets values to midnight
HourPulse = 1600;
mode = 0;
break;
} // end switch
} // end loop
PaulS
These should be:
long StepperAinterval = 60000UL; // 60 seconds break time between MINUTE movements
long StepperBinterval = 360000UL; // 6 minute break time between HOUR movements
Good names. It is very easy to see what you are doing.
I'm not a fan of magic numbers. I'd do something like this:
// Set initial position for servos
#define MIDNITE 1600
MinuteHand.writeMicroseconds(MIDNITE);  /// SET to 12.00
HourHand.writeMicroseconds(MIDNITE);  /// SET to 12.00
That way, if you need to change the value (to 1601 or 1599, for instance), you only need to do it in one place.
Using a nested if test would be better:
if(mode == 0)
   if (digitalRead (setupAswitch) == LOW){ mode = 1;}
   if (digitalRead (setupBswitch) == LOW){ mode = 2;}
   if (digitalRead (setupCswitch) == LOW){ mode = 3;}
   if (digitalRead (setupDswitch) == LOW){ mode = 4;}
   if (digitalRead (setupEswitch) == LOW){ mode = 5;}
   if (digitalRead (setupFswitch) == LOW){ mode = 6;}
Again, a little restructuring here leads to more readable code:
if(digitalRead (ResetSwitch) == LOW)
   if(mode > 0 && mode <= 7)
      mode = 9;
(and a lot less of it...)
I don't see how cases 2 through 6 differ from each other. Can you point out what I missed?
flotilla
Thanks Paul, that is very helpful
These should be:
Just wondered what the UL is for? It seems to work fine without it.
One issue I do have however is that when Case 7 starts it is not always exactly 60 seconds before the first value is written to the motor, it seems to be random as to how long after pressing the switch to the first write, I am assuming it is something to do with the millis count not being zero when the case 7 starts to run.
After the first write it does stick strictly to the right timings for each motor so it is not too much of an issue and it is never seems to be more than a minute, Just a bit annoying.
Case 1-6 are all the same because the different 'start times' have not been entered yet. When I get the timings for the show these will all be set to different start points.
Thanks again for your help
PaulS
Unsigned Long. By default, literal constants are interpreted as ints. Since neither value IS an int, it is better to tell the compiler that the value isn't an int, by telling it what it is. That's what the UL on the end does.
Set PreviousMillsA and PreviousMillisB to CurrentMillisA, instead of 0, in the cases 2 to 6. This will ensure that nothing happens in case 7 until exactly 60 seconds has elapsed.
There is a lot of duplicate code in the 6 cases. Having a series of if/else if/else statements to handle the differences (future) would shorten the code considerably.
