Topic: NEED OF HELP!!!! CAN I USE MY 5VOLT CNC OUTPUT AS SENSOR! (Read 917 times) previous topic - next topic
rexcobey1
I'm newbie about electronic and i don't know if i can used my cnc out that gives 5volts as sensor?
Here is what would like to make.
i have a cnc oxygen fuel machine that have a solenoid valve that hook up in cnc out. when my cnc machine trigger to open the solenoid valve the output give 5 volts to open that valve.
my question is can i use this 5volt as sensor to arduino uno.
Thanks
johnwasser
If it's a signal that switches between (near) 0V and (near) 5V you can read it with a digitalRead(). Make sure that the signal ground is connected to the Arduino ground.
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
rexcobey1
Sorry but i don't get it. please give more details because i don't know where to put the positive 5volts.
Thanks
rexcobey1
johnwasser thanks i finally get it and try and its working the only problem now is the code, i think there is something wrong about my code.
if there is somebody out there that can help me...
thanks
johnwasser
It will be hard to help unless you show your code.
fkeel
http://embodimentlabs.tumblr.com/
http://paulstrohmeier.info/
Grumpy_Mike
#6
Jul 14, 2012, 07:23 pm Last Edit: Jul 15, 2012, 05:38 pm by Grumpy_Mike Reason: 1
Two knocks for yes and one knock for no.
It looks like the spirit world is your only hope if you don't post your code because only they will be able to see it and see your error.
MarkT
Thanks
I wonder where the freewheel diode is for that solenoid valve?  It may be that somewhat more than 5V is appearing on that output as a result.  I'd suggest taking the precaution of connecting the solenoid valve output to the Arduino pin via a 10k resistor - it will then be safe against moderate over-voltage pulses.
[ I won't respond to messages, use the forum please ]
