Topic: Alternate Wall Adapter? (Read 627 times) previous topic - next topic
twinsfan1127
I read online that the Arduino wall adapter has a 9 V, 650 milli amps output.
I have both an 8v, 650 mA, and a 9v, 400 mA wall adapter from other electronics. Would either or both of them be sufficent to at least run the Arduino?
Many thanks
jackrae
#1
Jul 11, 2012, 10:26 pm Last Edit: Jul 12, 2012, 10:35 am by jackrae Reason: 1
Yes - providing they are DC output and their off-load voltage doesn't exceed say 14 volts.
Most cheap ones will fail the off-load limit :  I have a 12 volt one which exceeds 20 volts off-load !!
Certainly the arduino will always present a load which will make an unstabilised wall-wart output drop  to the arduino spec of 12 volts but without knowing by how much, it's safer to avoid anything that exceeds 14 volts.
CrossRoads
I find these to work well
http://www.dipmicro.com/store/DCA-07510
7.5V, keeps the regulator cool too.
cmiyc
There is no such thing as an "Arduino wall adapter".  However, there are wall adapters that work with Arduino.
Current ratings are a matter of "source" and "drain".  The power supply current rating is the amount it can "source."  The load (whatever you attach to the supply) will draw from that source.  For example, the Arduino will draw around 40 or 50mA when powered through the barrel jack.  This means it will only draw up to 50mA from the source.
In theory, It doesn't matter what that 9V source is rated at, as long as it is more than 50mA.  In practice, you don't want to go way the amount of current you need, because regulators generally have a minimum load requirement, blah blah blah.  Don't go over 2A unless your project has a specific need.
You should be able to answer your own question now... :)
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
