Topic: Keyboard from old cash register. (Read 2570 times) previous topic - next topic
Obakemono
I got a cash register machine from 1985, i've taken it apart to see what can a i use, and i would like to interface with the keyboard if possible. It have two layers with their corresponding bus, i think it should work like modern keyboards, one pin from one layer makes short with a pin from the other layer, but i haven't had any results yet.
┬┐Any advice or clue?
Photos, i've removed some keys experimenting.
Thx.
johnwasser
From the flex circuits it looks like a 4x8 matrix keypad.  The keypad library should help:
http://arduino.cc/playground/Code/Keypad
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Obakemono
Thanks, it headed me in the right direction.
Now i just need a way to hookup the flexible cables.
johnwasser
Can you remove the original connector from whatever board the keypad plugged into?
I find a propane torch to melt the solder and a sharp rap on a hard surface will nock most connectors off a board. :)
Obakemono
I managed to remove the original connectors with one like this.
Now i'm mapping the keys  :)
Thx.
