Topic: Wire in external power and still control power? (Read 664 times) previous topic - next topic
twinsfan1127
I don't know if this is feasible, but I have a very small 40mm fan which is rated at 12 V/0.07 A, and the Arduino really can't run it with 5 volts. I plugged it into a 9 volt battery and the power worked great.
How would I go about adding around 9 volts for the fan while still letting the board control the power (this is a temperature control system for my BBQ smoker with thermistors. )
Thanks
cmiyc
You need to look at voltage and current.  The fan needs 70mA at 12V.
You'll need to use a transistor to connect it to an Arduino.  Some how I suspect others have done this.  (https://www.google.com/search?q=control+12v+fan+with+arduino)
FYI.  Those small 9V batteries are lousy at running motors (like fans).  It'll only last 4 or 5 hours if the fan draws 50mA (de-rating since you aren't running at 12V).  You'll want to use a AC to DC 9V supply.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
JimboZA
My late father-in-law often mentioned a steam driven bbq spit design that he saw decades ago in a magazine (PM or similar I suppose). Alas he could never produce the design but was adamant that he had seen it, probably back in the 50s or so.
Since this is for a bbq, you could rig some kind of steam powered generator with the boiler tubes in the coals.....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
