Topic: Multiple wireless temp. sensors displaying status on tablet PC (Read 7865 times) previous topic - next topic
OrangePower
I want  to build wireless temp. sensors so I can monitor temperature in different areas arround my house and display data to tablet PC.
I need advice regarding cheapest wirelesss temp. sensor confugiration and also for sending data to tablet PC.
I was looking at this for wireles temp. sensors:
http://jeelabs.com/collections/all
What do you think?
perhof
Building a wireless sensor network won't be very cheap but it can be loads of fun.
This is one approach to an Arduino based wireless network:
For a wireless sensor you probably want a temp sensor like the DS18B20.
You need a microcontroller (Arduino) that can read the values from the sensor and you need a wireless transmitter to send the sensor readings to your "hub".
The cheapest wireless transmitters and receivers around seems to be the OOK 433 units on the page you linked. They are apparently out of stock where you were looking but they are available from other sources at lower prices.
I've bought them from eBay and yesterday someone here recommended ElectroDragon (http://www.electrodragon.com/?product_cat=wireless-modules)
You might need an Arduino and a transmitter for each sensor. If some sensors are closer together they could share the same Arduino/transmitter.
You will only need one receiver for the hub that will collect the data from your sensors.
This will soon add up to a lot of Arduinos that are both too bulky and too expensive as temp sensors so you will probably need to build your own custom boards using ATmegas or ATtiny's. I don't know which of the Tinies that can handle the libraries for the wireless modules. Haven't used ATtiny myself.
There are several options for displaying the temperatures on the tablet. I don't know of a ready-made solution that doesn't require programming. Which options you have depends on what kind of tablet you have but you probably don't want to have the receiving Arduino connected directly to your tablet all the time. Do you?
If that's what you want that could be done by using processing for example but that requires Windows/Mac/Linux rather than iPad or Android.
If you add an Ethernet shield you can post the data to some web page that the tablet can read or you can even run a web server on the receiving Arduino.
A simple network based client/server application might work too.
If the tablet has Bluetooth that could be an option for communication between tablet and Arduino.
Use your imagination.
If you have no idea at all how to do any of it you have a big mountain to climb.
I'm currently playing with a PHP-based web solution for logging temperatures from my sensors to a database and graphing them using Gnuplot. Unfortunately I don't have anything finished to offer you.
OrangePower
I was thiking on conecting DS18B20 to JeeNode http://jeelabs.com/products/jeenode.
Multiple sensors on multiple Jeenodes or more sensors on one unit if sensors are closer together.
Base station would be on arduino ADK (I allready have it) with web service and ethernet shiled, so I can access data from enywhere.
perhof
They are a little bit more expensive than homebrew modules but is probably not a bad choice.
Never tried them.
If you want to run your sensors from batteries you may want to skip the voltage regulator and run directly from battery to decrease the power consumption.
