Topic: Arduino fur industrial use? (Read 10338 times) previous topic - next topic
DiMedici
Hi all.
I have a general question on the Arduino.
Is it possible to use the Arduino for industrial use?
Is it reliable enough. Is it built to run 12 hours a day?
Is it also possible to built the Arduino in a product which is mass-produced?
If not:
Which possibilities do I have to turn the Arduino in a suitable device?
Thank you for answering!
CrossRoads
Yes
Yes
Yes - but:
More likely to be cost beneficial to build your own PCB with IO, etc, that meets your requirements.
For example, use a wallwart 5V power supply, delete the 7805 regulator, add IO connectors that are more secure than plug-in headers, etc.
Far-seeker
As an example of a more robust Arduino derivative, Rugged Circuits offers a version of the UNO with a number of modifications to decrease ESD susceptability, protect the I/O pins from shorts to ground and higher voltages than the stock UNO, and allow it to be powered with upto 24 VDC.  I don't think they went so far as to use industrial temperature (?40°C to 85°C) rated components, but since only the ICs and perhaps one or two other parts would need to be changed, it would be possible but somewhat more expensive per board to do so.
CrossRoads
#3
Jul 13, 2012, 10:09 pm Last Edit: Jul 13, 2012, 10:12 pm by CrossRoads Reason: 1
Can go broader on the temp even:
ATMEGA328P-PN, PDIP, 28P3 28,   1.8-5.5V, Industrial (B) (-40°C to 105°C)
I believe Mouser carries these, I looked it up a day or two ago.
Surface mount:
ATMEGA328P-AN   TQFP 32A 32   1.8-5.5 Industrial (B) (-40°C to 105°C)
ATMEGA328P-ANR TQFP 32A 32   1.8-5.5 Industrial (B) (-40°C to 105°C)
(I think difference may just be delivery packaging)
Would have to look at the other parts as well, or delete the niceties to improve calcutated MTFB (mean time between failures - fewer parts = fewer failures)
Far-seeker
Nice finds CrossRoads, thanks for sharing!
James C4S
Why would you put any device intended for prototyping into an industrial environment?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
n3qik
You could use the UNO as-is but it might be cheaper/better to build your own circuit board around the ATMEGA328P chip.
Oracle
I would be careful with that advice.  Modern switching wall warts should be fine, but if he gets a cheap, old linear based one, it could easily give 8V no load and fry his chips (yes, I made that mistake in my pic days).
CrossRoads
I'd with one like this, I use them a lot.
http://www.dipmicro.com/store/DCA-0520
http://www.dipmicro.com/store/KLDX-0202-A
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
