Offline
Jr. Member
« Reply #30 on: July 20, 2012, 04:02:47 pm » |
I got the transistors, I got the 222A npn and KSP2907A pnp, I assembled the gates, so I have 2 "gates" , connected to the arduino, but still the arduino cant drive them. the VDD is external new 9v battery, when I take the Input and connect it to the vdd it drives the relay, but when I connect it to the arduino it wont drive it. do you have any idea why? Your solenoid is akin to "common cathode" LED arrays. The ground connection goes to ground (the cathode) and the two positive connections (anodes) get switched on and off. This is known as "high side switching" and should really be done using PNP transistors, not NPN as you have. Using PNP you basically end up with the original source schematic, but upside-down. Also, note that the switching is also inverted - writing a "HIGH" will turn off the transistor, and a "LOW" will turn it on. I usually couple an NPN with each PNP to act as an inverter (in fact, I usually use MOSFETs, not BJTs, but that's just me).
Logged
UK
Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
« Reply #31 on: July 20, 2012, 04:10:41 pm » |
You do have the external and arduino grounds connected, don't you?
Logged
Offline
Jr. Member
« Reply #32 on: July 20, 2012, 04:12:01 pm » |
I feel so stupid right now
Logged
Offline
Jr. Member
« Reply #33 on: July 20, 2012, 04:15:02 pm » |
works perfectly..
how much time do you think a circuit like that could hold on a 9v battery? If i'd use mos instead of npn it should not waste energy when its not used right?
Logged
UK
Offline
Edison Member
« Reply #34 on: July 20, 2012, 04:16:30 pm » |
Either BJT or FET will have some leakage current, so neither will last for ever.
It will last for quite some time when not actively driving the coils though.
Logged
Offline
Jr. Member
« Reply #35 on: July 20, 2012, 04:17:46 pm » |
I guess its more like weeks/months than years right?
Logged
United Kingdom
Online
Faraday Member
« Reply #36 on: July 20, 2012, 04:21:10 pm » |
works perfectly..
The leakage current of those transistors should be negligible, well under 1uA, so there should be no significant loss of battery capacity when the transistors are off. Did you remember to include a resistor in series with Q1 collector, as per my earlier post?
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
UK
Offline
Edison Member
« Reply #37 on: July 20, 2012, 04:21:43 pm » |
Depends on the battery, and how many times you fire the solenoids.
Logged
Offline
Jr. Member
« Reply #38 on: July 21, 2012, 01:47:04 am » |
works perfectly..
The leakage current of those transistors should be negligible, well under 1uA, so there should be no significant loss of battery capacity when the transistors are off. Did you remember to include a resistor in series with Q1 collector, as per my earlier post? Actually I didn't remember, today I added a resistor between Q1 and Q2, at first 10k, didnt work, 1k, didnt work, 330m, didnt work. removed all resistors, worked... I guess I misunderstood you? (Although I dont see anywhere else and the resistor between Q1 and Q2 makes sense..)
Logged
SW Scotland
Offline
Edison Member
Arduino rocks
« Reply #39 on: July 21, 2012, 02:05:33 am » |
How long will the battery last Measure the current, look up your battery AH rating, divide AH by current and there is your answer +- 50% You don't have a meter ? then why are you playing with electronics ?
Logged
United Kingdom
Online
Faraday Member
« Reply #40 on: July 21, 2012, 02:18:20 am » |
You need a resistor between the collector of Q1, and the junction of Q2 base and R2, to limit the collector current and power dissipation of Q1. A suitable value would be between 10 and 20 times the resistance of the solenoid.
Logged
Offline
Jr. Member
« Reply #41 on: July 21, 2012, 01:14:57 pm » |
You need a resistor between the collector of Q1, and the junction of Q2 base and R2, to limit the collector current and power dissipation of Q1. A suitable value would be between 10 and 20 times the resistance of the solenoid. Yes, I did connect it there. didn't work, how come It needs to be 10 to 20 times the resistance of the solenoid? to my knowledge the only reason to put the resistor there is to, as you said, limit the collector's current, what does the solenoid has to do with that?
Logged
UK
Offline
Edison Member
« Reply #42 on: July 21, 2012, 01:27:43 pm » |
Actually, is a resistor really needed?
You say it's to "limit the collector current and power dissipation of Q1", but the collector current is coming down through R2, not coming out of the base of Q2. Q1 is acting to pull the base of Q2 low - a resistor in there will form a voltage divider with R2 and not pull the base down enough.
The current through Q1 is controlled by the base current, which is limited by R1. The current through Q2 is whatever L1 requires.
I don't see what benefit an extra resistor would have, and I can see how it would stop it working.
Logged
United Kingdom
Online
Faraday Member
« Reply #43 on: July 21, 2012, 01:57:31 pm » |
Without a resistor there, you need to get R1 just right. Too low and Q1 will overheat; too high and Q1 will not supply enough base current to Q2. The problem is, the ideal value of R1 (in the absence of a resistor in series with the collector of Q1) depends on the hfe of Q1, which can vary widely between different transistors having the same part number. You say it's to "limit the collector current and power dissipation of Q1", but the collector current is coming down through R2, not coming out of the base of Q2.
No, it's mostly coming out of the base of Q2. Q1 is acting to pull the base of Q2 low - a resistor in there will form a voltage divider with R2 and not pull the base down enough.
Only if the ratio of R3 (the new resistor) to R2 is too high. The current through Q1 is controlled by the base current, which is limited by R1.
True; but the collector current of Q1 is the base current times the hfe, and the hfe can vary widely between different transistors of the same type. The current through Q2 is whatever L1 requires.
The collector current through Q2 is whatever L1 requires, provided that Q2 has sufficient base current. I don't see what benefit an extra resistor would have, and I can see how it would stop it working.
The purpose of the resistor R3 is to ensure that Q2 gets enough base current to saturate, but not so much that Q1 overheats. Including R3 will only stop the circuit working if the ratio R3:R2 is too high. You should choose R3 so that the base current into Q2 is around 1/10 to 1/20 of the current through L1 (hence R3 is 10 to 20 times the resistance of L1, because the voltages across L1 and R3 are very similar, and most of the current through R3 comes from the base of Q2). Then choose R1 so that the base current is at least about 1/50 of the chosen Q2 base current (I am assuming that Q1 has an hfe of at least 50). I would choose R2 to be about the same as R3.
Logged
UK
Offline
Edison Member
« Reply #44 on: July 21, 2012, 02:12:52 pm » |
Ok, so which way should it be connected?
Logged
