Pages: 1 [2]   Go Down
Author Topic: starting the Windows media player from the UNO?  (Read 1311 times)
ottawa, canada
Where can I find info about "Hardware features" like the internal resistor, i guess it is not the only hardware feature on the board?
Start here: http://arduino.cc/en/Main/Hardware
Pick whichever board you have, and read all the details, even if you don't think you will use them (yet).
I still don't quite believe this but the documentation for 1.0 sounds like the pullups are *not* active for pinMode(INPUT). This would break a lot of my http://arduino.cc/en/Reference/PinMode
Seattle, WA USA
Seattle, WA USA
They are not active by default. They can be activated, using digitalWrite(). Or, the call to digitalWrite() is made for you if you use the type INPUT_PULLUP.
I think that the "disabled" in that sentence refers to the fact that there is now a call to digitalWrite() in the pinMode() function. It is called with HIGH or LOW based on the use of INPUT_PULLUP vs. INPUT.
A peak at the code confirms this. The digitalWrite() function isn't actually called, but the equivalent register manipulations occur.
Brampton, Ontario
I'm on windows 7, and the example code from here http://electronics.divinechildhighschool.org/Home/Arduino-Lessons/using-gobetwino-to-control-windows-through-arduino doesn't seem to work -iTunes doesn't even seem to open.
ottawa, canada
Whew, thanks.
Brampton, Ontario
Is there any reason that this doesn't work for Windows 7? I would really like to use Gobetwino.
Try, when you have uploaded the Sketch to the arduino, restart you Windows 7 with you Arduino connected to your PC. Then start the "Gobetwino".
I had the same problem, but after a restart of the PC, it seems that the computer and arduino had found each other.
I know it's sounds strange, but it works for me.
Pages: 1 [2]   Go Up
