Loading...
Pages: [1]   Go Down
Author Topic: problems reading gps output  (Read 660 times)
Offline Offline
Newbie
View Profile
Hello!
i'm trying to read gps(global sat et-332) tx output using arduino mega 2560
i've connected gps tx to arduino rx1
gps configured to work in nmea mode, if i connect it to pc - i get perfect nmea output
but when i when i run this code on arduino
Code:
  // initialize both serial ports:
  Serial1.begin(9600);
  // read from port 1, send to port 0:
  if (Serial1.available()) {
    char inByte = Serial1.read();
    Serial.write(inByte);
i get this
Code:
‰‰é9óæÌ¦&¦f³¦&æssssóæóææssS9ófóæS9sóæææfM™—ž=›æÌ¦æ&f³¦&æS¦&æÌÓ:>6NÆN>2"26F:>2NêN:N>2N2F&N6>FNÊN:.F*NÊNN>>>>V*Ê֛ù‰‰é9óæÌ¦æ¦Ì³¦&æS¦&æÌÓ>NÆN>2"26F:>"NêN:N>2N2F&N6>FNÊN:.F*NÊNN>>>>V*:ÊÖ
instead of NMEA
none of googled gps reading solutions are worked, i'm stuck smiley-sad
« Last Edit: July 14, 2012, 03:10:36 am by 1101 » Logged
Offline Offline
Newbie
View Profile
I haven't used a GPS device before. But I do know that when talking over the Serial monitor you have to use the right baud rate. Perhaps 9600 baud is the wrong rate. Also you misspelled Serial in your code. Perhaps that may be causing the problem.
Hope this helps.
Logged
Offline Offline
Newbie
View Profile
whwn i connect to pc using same baud rate - i get nmea sentences
misspelled? where? i'm using arduino mega, it has 3 serial's, i connect gps to serial1 rx
Logged
Offline Offline
Newbie
View Profile
In void setup you have it as "Seriall.begin(9600);
You put an extra 'l', lol
Logged
Offline Offline
Newbie
View Profile
dude, it's 1(one) smiley
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
How have you connected it, hardware-wise?
From the datasheet I found:
Quote
Output TTL level , 0V ~ 2.85V
I'm wondering if, electrically, it is matching up.
Maybe the logic levels are inverted, the datasheet is a bit vague on that point.
Logged
Offline Offline
Newbie
View Profile
i thought about it.
But how do i check it or how do i invert it?
Logged
Seattle
Offline Offline
Newbie
ummm?
View Profile
Hmm- I can't get the sheet to open from USGlobalsat.  But the board I have from them runs at 4800 baud, default- might be worth a quick try just to see...
t
Logged
Offline Offline
Newbie
View Profile
nope
4800 gets almost same result
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Can you post a link to a datasheet that describes the requirements in detail? Like, logic levels, whether a 1 is 0V, 5V, -5V and so on?
Logged
0
Offline Offline
Faraday Member
View Profile
Sounds like you have an RS232 level device connected to the TTL level Arduino.
Get yourself a MAX232 or equivalent circuit to do the appropriate level shifting.
-j
Logged
Offline Offline
Newbie
View Profile
but i thought that arduino can understand rs-232
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
We can't help what you think. The FACT is that it can't.
Logged
Pages: [1]   Go Up
Print
Jump to:
