Author Topic: problems reading gps output  (Read 613 times)
Hello!
i'm trying to read gps(global sat et-332) tx output using arduino mega 2560
i've connected gps tx to arduino rx1
gps configured to work in nmea mode, if i connect it to pc - i get perfect nmea output
but when i when i run this code on arduino
  // initialize both serial ports:
  Serial1.begin(9600);
  // read from port 1, send to port 0:
  if (Serial1.available()) {
    char inByte = Serial1.read();
    Serial.write(inByte);
i get this
‰‰é9óæÌ¦&¦f³¦&æssssóæóææssS9ófóæS9sóæææfM™—ž=›æÌ¦æ&f³¦&æS¦&æÌÓ:>6NÆN>2"26F:>2NêN:N>2N2F&N6>FNÊN:.F*NÊNN>>>>V*Ê֛ù‰‰é9óæÌ¦æ¦Ì³¦&æS¦&æÌÓ>NÆN>2"26F:>"NêN:N>2N2F&N6>FNÊN:.F*NÊNN>>>>V*:ÊÖ
instead of NMEA
none of googled gps reading solutions are worked, i'm stuck smiley-sad
« Last Edit: July 14, 2012, 03:10:36 am by 1101 » Logged
I haven't used a GPS device before. But I do know that when talking over the Serial monitor you have to use the right baud rate. Perhaps 9600 baud is the wrong rate. Also you misspelled Serial in your code. Perhaps that may be causing the problem.
Hope this helps.
whwn i connect to pc using same baud rate - i get nmea sentences
misspelled? where? i'm using arduino mega, it has 3 serial's, i connect gps to serial1 rx
In void setup you have it as "Seriall.begin(9600);
You put an extra 'l', lol
dude, it's 1(one) smiley
Melbourne, Australia
Shannon Member
Lua rocks!
How have you connected it, hardware-wise?
From the datasheet I found:
Output TTL level , 0V ~ 2.85V
I'm wondering if, electrically, it is matching up.
Maybe the logic levels are inverted, the datasheet is a bit vague on that point.
i thought about it.
But how do i check it or how do i invert it?
Seattle
huh?
Hmm- I can't get the sheet to open from USGlobalsat.  But the board I have from them runs at 4800 baud, default- might be worth a quick try just to see...
t
nope
4800 gets almost same result
Shannon Member
Lua rocks!
Can you post a link to a datasheet that describes the requirements in detail? Like, logic levels, whether a 1 is 0V, 5V, -5V and so on?
Sounds like you have an RS232 level device connected to the TTL level Arduino.
Get yourself a MAX232 or equivalent circuit to do the appropriate level shifting.
-j
but i thought that arduino can understand rs-232
Seattle, WA USA
Seattle, WA USA
We can't help what you think. The FACT is that it can't.
