Topic: how to refresh lcd properly (Read 6389 times) previous topic - next topic
lax123
i got a 20x4 lcd i2c and the following problem:
i have a sensor value first in the lcd and a counter next to that.
after some counts i got something like this in the display:
0.00__3
once the sensor value reaches 10 it becomes this:
10.00__3
but once the sensors value flips back to 0 it looks like this:
0.00__33
the lcd doesnt erase the 3/refresh the space _ once it goes back.
Could you tell me how to do that?
and can i make it somehow look like always _0.00 instead of 0.00 and moving all chars one space to the right after it reaches 10?
Abhisheik
I guess you are trying to make a Data Logger. I had a similar problem. Here is what i did.
Fix the position of the value and the counter on the LCD before you print the data to the LCD. In  your case it will be
lcd.setCursor(col,rows);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(val);
lcd.setCursor(5,0);
lcd.print(counter);
Quote
for this i added a trailing zero in case the value is less then 10. Use if-else statement
lcd.print("0"); \\ if value less then 10
lcd.print("");    \\ if value is more then 10
I am a beginner myself so i am sure this is a really crude method and lot of people will suggest more efficient coding but well , we all are learning ..aint we...
floresta
#2
Jul 16, 2012, 04:51 pm Last Edit: Jul 16, 2012, 05:02 pm by floresta Reason: 1
Quote
They already have ... many times.  Finding those posts is another matter.
Try this one: http://arduino.cc/forum/index.php?topic=94633.0
Don
lax123
thx a lot,
this is great:
http://liudr.wordpress.com/2012/01/16/sprintf/
well actually im always searching first, but sometimes its not that easy for me to find the right thing, when you get like 400 search results.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
