Topic: RTC modules - who's is "best"? (Read 13421 times) previous topic - next topic
lost_and_confused
And before you shoot me, Yes:  I know that is a loaded/silly question.
I live in Sydney (OZ) so it is more directed at the "locals".
I have two initial choices:  JAYCAR or Altronics.
JC sell Freetronics stuff and Altronics sell....  someone else's.
Both sell RTC modules.
Both have battery backups, NV RAM in the RTC chip.
Yes, it (maybe) depends on the project to the benefits of which, bit I would like to try and keep it as "easy as possible" to connect it to the Arduino.  So I2C bus, or the other one would be nice.   Though to date I have only dealt with the I2C type, but with a different IC.
Has anyone here used either and notice any "problems" with them?
Thanks in advance.
macegr
I make the ChronoDot: http://macetech.com/store/index.php?main_page=product_info&cPath=5&products_id=8
Freetronics has a similar module: http://www.freetronics.com/collections/modules/products/real-time-clock-rtc-module
I'd recommend something with the DS3231 or DS3232. Based on the experiences of thousands of ChronoDot users, the DS323x chips have a very high level of satisfaction regarding ease of use and accuracy in a wide range of conditions. DS13xx based modules...not so much.
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
RandallR
#2
Jul 16, 2012, 04:49 am Last Edit: Jul 16, 2012, 04:51 am by RandallR Reason: 1
RTC modules are several times more expensive than building your own.
I like the PCF8563.  It doesn't have RAM but it does have an alarm.  If you need RAM then I would go with DS1307.
These chips should be less than $1 (even in OZ).  You may need to buy 10 of them to get that price.  Otherwise, you are paying a lot to ship 1 or 2 chips.
Next you will need a 32K Hz crystal.  These are only about $0.10 each but you may need to buy over 25 to get that price.  However, you will have spares for all there RTC chips you bought.
If you want battery backup ( you probably do ), you will need a battery holder.  I think they are about $0.25 each in lot of 10 or so.
Add a little for resistors and a diode and your done.
Now for $1.50 or less you have an RTC that would cost you $5 or more as a module.
lost_and_confused
Thanks.
RandallR,
I can't find anyone who sells RTC chips near by.
Granted I was looking for the type NOT recomended by macegr, however:  They are hen's teeth to get where I am.
Granted the cost, but there is the "board" to put them on as well.
I am not begrudging (spelling?) what you say, but for the time, etc.
I'll keep looking.
macegr,
Thanks.  Info taken onboard.
Now I shall have to refine my search for people who have that type of RTC chip in stock.
lost_and_confused
Update:
This is a link for a supplier I found.
Far from $1/chip.
http://au.element14.com/jsp/search/browse.jsp?N=2101+203650&Ntk=description&Ntt=Real+Time+Clock+chip&Ntx=mode+matchall
but none of them are what were mentioned.
macegr
Obviously it looks suspicious coming from someone selling an alternative, but I've built my own RTC modules over the years and haven't had good results. That's why I was excited about the DS3231 and made a breakout board, actually. It's surprising tricky to get a crystal that matches the DS1307 precisely enough to get good accuracy at room temperature. And the PPM specification of the crystal is really important...if you want a system that drifts only a minute or two per month at room temperature, you should certainly expect to pay more than 10 cents for a crystal.
And of course, once you take your nicely matched non-compensated RTC module out of doors into the heat or cold, it all falls apart. They are optimized for climate controlled environments and it will start running fast or slow immediately. The DS323x built-in crystal and temperature compensation really shines in an outdoor environment. Of course, in an indoor environment it'll just run a lot better. I have one that was last synchronized at the beginning of March 2012 and it's only drifted about 10 seconds.
RandallR
The ones I got off ebay out of China.  The prices included shipping to the US.
I must confess that they do seem to drift a bit (3-5 seconds a day) and I have not gotten around to looking at improving the accuracy.  For the price, I can't squawk.
Something else that I am looking at.  I was reading the data sheet for the ATMega328 and it talks about using one of the timer registers as a RTC.  From what I can tell, you hang the 32K Hz crystal on pins 9 and 10 instead of the usual 16-20MHz crystal.  You can then get an interrupt every second.  You will need to write the interrupt handler and keep track of the time but you only need is the crystal.
Since you no longer have a crystal the system clock, you need to use the internal oscillator.  This can be configured up to 8MHz.  I have been playing with using the internal oscillator and it is not hard to do, but I have been breadboarding everything.
lost_and_confused
This is about the only other place which has the DS323x series RTC I can find.
http://www.futurlec.com.au/Mini_DS3232.jsp
Yes, I know it is a "kit" but .......
Shall look if they sell just the chip.
angusisthedevil
Or from same supplier buy the DS1307 mini board. Price is cheaper (not as many functions on board I guess) than buying one IC off from RS Components/element 14, etc.,and you get the board with it as well and crystal, etc, etc..
Lots of libs around for DS1307, easy to use, etc.
lost_and_confused
angusisthedevil
I looked at Element14/Farnell, but couldn't find that chip.
The "kit" from futurelec looks good.
Either/both look good.
macegr,
Their kits - alas - as a wee bit cheaper than "yours".
Even with "multi-buy" from you, with the postage and all.
Please don't be upset.
I am just thinking now which of the two to get.
But at that price, I guess a couple would not "kill me" as opposed to buying the discreet chips and building one looking at the price for the chips.
macegr
Haha, I know what I'm charging, and what my "competitors" charge. Pretty sure I'm the next cheapest option for this type of product, at least. Also, they have the DS3232 with NVRAM, but I have the DS3231SN with the industrial temperature range. It's just a simple breakout board...I even have the design files open source, so I'm not going to be upset if someone else makes something similar and people buy it. I still get a lot of business from the USA because Futurlec typically has to ship from Thailand.
angusisthedevil
Try RS Components then.
The freight will be as much as the part though probably.
Riva
#12
Jul 16, 2012, 10:21 am Last Edit: Jul 16, 2012, 10:23 am by Riva Reason: 1
From personal experience I suggest you avoid DS1307 unless time accuracy is not important. I have one and it looses about 7.5 seconds per day. I could order different crystals in the DS1307 to try and improve accuracy but that means more hassle and cost.
I also have several DS3231 and they are a lot more accurate at less than drift 2 seconds per month. I can also tweak the drift if needed by adjusting the ageing offset register using software but 2 seconds per month is good enough for me. Plus they have a readable temperature.
The DS323x range are more expensive than DS130x but in my mind worth the extra cost. To build your own is easy enough but once you add up the cost of the individual bits (IC, Breakout board, Pins, battery holder & battery) you may as well buy the pre-built modules.
Back to the original question between Jaycar & Altronics I would personally choose the Jaycar (freetronics) module as it appears to use a DS3232. The Altronics (sparkfun) module looks to use the DS3234. The DS3232 is a 2 wire interface and the DS3234 is 3 wire so one pin saved on the arduino.
Don't PM me for help as I will ignore it.
RandallR
From personal experience I suggest you avoid DS1307 unless time accuracy is not important. I have one and it looses about 7.5 seconds per day. ...
You get what you pay for.  10 times the price for 10 times the accuracy.
I haven't done it yet, but I am looking at handling the drift in software.  Add or subtract a second every few hours.
Riva
Quote
That's what I had to do in the end though as the project was a word clock (tells time to nearest minute) I only bother to adjust once per day at midnight. Drift is approx 7.5 seconds per day so at midnight I read the time, add 8 seconds, wait 0.5 seconds and then write the time back.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
