Offline
Newbie
« Reply #30 on: February 15, 2013, 12:50:35 pm » |
Speak French?
Logged
Offline
Newbie
« Reply #31 on: February 16, 2013, 11:13:47 am » |
Okay, so I have the code right here : #include "etherShield.h"
// please modify the following two lines. mac and ip have to be unique // in your local area network. You can not have the same numbers in // two devices: static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x24}; static uint8_t myip[4] = {192,168,1,15}; static char baseurl[]="http://192.168.1.15/"; static uint16_t mywwwport =80; // listen port for tcp/www (max range 1-254) // or on a different port: //static char baseurl[]="http://10.0.0.24:88/"; //static uint16_t mywwwport =88; // listen port for tcp/www (max range 1-254) //
#define BUFFER_SIZE 500 static uint8_t buf[BUFFER_SIZE+1]; #define STR_BUFFER_SIZE 22 static char strbuf[STR_BUFFER_SIZE+1];
EtherShield es=EtherShield();
// prepare the webpage by writing the data to the tcp send buffer uint16_t print_webpage(uint8_t *buf); int8_t analyse_cmd(char *str); // get current temperature #define TEMP_PIN 3 void getCurrentTemp( int *sign, int *whole, int *fract);
void setup(){ /*initialize enc28j60*/ es.ES_enc28j60Init(mymac); es.ES_enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz delay(10); /* Magjack leds configuration, see enc28j60 datasheet, page 11 */ // LEDA=greed LEDB=yellow // // 0x880 is PHLCON LEDB=on, LEDA=on // enc28j60PhyWrite(PHLCON,0b0000 1000 1000 00 00); es.ES_enc28j60PhyWrite(PHLCON,0x880); delay(500); // // 0x990 is PHLCON LEDB=off, LEDA=off // enc28j60PhyWrite(PHLCON,0b0000 1001 1001 00 00); es.ES_enc28j60PhyWrite(PHLCON,0x990); delay(500); // // 0x880 is PHLCON LEDB=on, LEDA=on // enc28j60PhyWrite(PHLCON,0b0000 1000 1000 00 00); es.ES_enc28j60PhyWrite(PHLCON,0x880); delay(500); // // 0x990 is PHLCON LEDB=off, LEDA=off // enc28j60PhyWrite(PHLCON,0b0000 1001 1001 00 00); es.ES_enc28j60PhyWrite(PHLCON,0x990); delay(500); // // 0x476 is PHLCON LEDA=links status, LEDB=receive/transmit // enc28j60PhyWrite(PHLCON,0b0000 0100 0111 01 10); es.ES_enc28j60PhyWrite(PHLCON,0x476); delay(100); //init the ethernet/ip layer: es.ES_init_ip_arp_udp_tcp(mymac,myip,80); // initialize DS18B20 datapin digitalWrite(TEMP_PIN, LOW); pinMode(TEMP_PIN, INPUT); // sets the digital pin as input (logic 1)
void loop(){ uint16_t plen, dat_p; int8_t cmd;
plen = es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf);
/*plen will ne unequal to zero if there is a valid packet (without crc error) */ if(plen!=0){ // arp is broadcast if unknown but a host may also verify the mac address by sending it to a unicast address. if(es.ES_eth_type_is_arp_and_my_ip(buf,plen)){ es.ES_make_arp_answer_from_request(buf); return; }
// check if ip packets are for us: if(es.ES_eth_type_is_ip_and_my_ip(buf,plen)==0){ return; } if(buf[IP_PROTO_P]==IP_PROTO_ICMP_V && buf[ICMP_TYPE_P]==ICMP_TYPE_ECHOREQUEST_V){ es.ES_make_echo_reply_from_request(buf,plen); return; } // tcp port www start, compare only the lower byte if (buf[IP_PROTO_P]==IP_PROTO_TCP_V&&buf[TCP_DST_PORT_H_P]==0&&buf[TCP_DST_PORT_L_P]==mywwwport){ if (buf[TCP_FLAGS_P] & TCP_FLAGS_SYN_V){ es.ES_make_tcp_synack_from_syn(buf); // make_tcp_synack_from_syn does already send the syn,ack return; } if (buf[TCP_FLAGS_P] & TCP_FLAGS_ACK_V){ es.ES_init_len_info(buf); // init some data structures dat_p=es.ES_get_tcp_data_pointer(); if (dat_p==0){ // we can possibly have no data, just ack: if (buf[TCP_FLAGS_P] & TCP_FLAGS_FIN_V){ es.ES_make_tcp_ack_from_any(buf); } return; } if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){ // head, post and other methods for possible status codes see: // http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<h1>200 OK</h1>")); goto SENDTCP; }
Logged
Offline
Newbie
« Reply #32 on: February 16, 2013, 11:21:48 am » |
if (strncmp("/ ",(char *)&(buf[dat_p+4]),2)==0){ plen=print_webpage(buf); goto SENDTCP; } cmd=analyse_cmd((char *)&(buf[dat_p+5])); if (cmd==1){ plen=print_webpage(buf); } SENDTCP: es.ES_make_tcp_ack_from_any(buf); // send ack for http get es.ES_make_tcp_ack_with_data(buf,plen); // send data } } } } // The returned value is stored in the global var strbuf uint8_t find_key_val(char *str,char *key) { uint8_t found=0; uint8_t i=0; char *kp; kp=key; while(*str && *str!=' ' && found==0){ if (*str == *kp){ kp++; if (*kp == '\0'){ str++; kp=key; if (*str == '='){ found=1; } } }else{ kp=key; } str++; } if (found==1){ // copy the value to a buffer and terminate it with '\0' while(*str && *str!=' ' && *str!='&' && i<STR_BUFFER_SIZE){ strbuf[i]=*str; i++; str++; } strbuf[i]='\0'; } return(found); }
int8_t analyse_cmd(char *str) { int8_t r=-1; if (find_key_val(str,"cmd")){ if (*strbuf < 0x3a && *strbuf > 0x2f){ // is a ASCII number, return it r=(*strbuf-0x30); } } return r; }
uint16_t print_webpage(uint8_t *buf) { char temp_string[10]; int i=0; //char *temp_string="100"; uint16_t plen; getCurrentTemp(temp_string); plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n")); plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<center><p><h1>Welcome to Arduino Ethernet Shield V1.0 </h1></p> ")); plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<hr><br><form METHOD=get action=\"")); plen=es.ES_fill_tcp_data(buf,plen,baseurl); plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("\">")); plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<h2> Current Temperature is </h2> ")); plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<h1><font color=\"#00FF00\"> ")); while (temp_string[i]) { buf[TCP_CHECKSUM_L_P+3+plen]=temp_string[i++]; plen++; }
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR(" °C</font></h1><br> ") ); plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=hidden name=cmd value=1>")); plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=submit value=\"Get Temperature\"></form>")); plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</center><hr> <p> V1.0 <a href=\"http://www.nuelectronics.com\">www.nuelectronics.com<a>")); return(plen); }
void OneWireReset(int Pin) // reset. Should improve to act as a presence pulse { digitalWrite(Pin, LOW); pinMode(Pin, OUTPUT); // bring low for 500 us delayMicroseconds(500); pinMode(Pin, INPUT); delayMicroseconds(500); }
void OneWireOutByte(int Pin, byte d) // output byte d (least sig bit first). { byte n;
for(n=8; n!=0; n--) { if ((d & 0x01) == 1) // test least sig bit { digitalWrite(Pin, LOW); pinMode(Pin, OUTPUT); delayMicroseconds(5); pinMode(Pin, INPUT); delayMicroseconds(60); } else { digitalWrite(Pin, LOW); pinMode(Pin, OUTPUT); delayMicroseconds(60); pinMode(Pin, INPUT); }
d=d>>1; // now the next bit is in the least sig bit position. } }
byte OneWireInByte(int Pin) // read byte, least sig byte first { byte d, n, b;
for (n=0; n<8; n++) { digitalWrite(Pin, LOW); pinMode(Pin, OUTPUT); delayMicroseconds(5); pinMode(Pin, INPUT); delayMicroseconds(5); b = digitalRead(Pin); delayMicroseconds(50); d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position } return(d); }
void getCurrentTemp(char *temp) { int HighByte, LowByte, TReading, Tc_100, sign, whole, fract;
OneWireReset(TEMP_PIN); OneWireOutByte(TEMP_PIN, 0xcc); OneWireOutByte(TEMP_PIN, 0x44); // perform temperature conversion, strong pullup for one sec
OneWireReset(TEMP_PIN); OneWireOutByte(TEMP_PIN, 0xcc); OneWireOutByte(TEMP_PIN, 0xbe);
LowByte = OneWireInByte(TEMP_PIN); HighByte = OneWireInByte(TEMP_PIN); TReading = (HighByte << 8) + LowByte; sign = TReading & 0x8000; // test most sig bit if (sign) // negative { TReading = (TReading ^ 0xffff) + 1; // 2's comp } Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
whole = Tc_100 / 100; // separate off the whole and fractional portions fract = Tc_100 % 100;
if(sign) temp[0]='-'; else temp[0]='+'; if(whole/100==0) temp[1] =' '; else temp[1]= whole/100+'0'; temp[2]= (whole-(whole/100)*100)/10 +'0' ; temp[3]= whole-(whole/10)*10 +'0'; temp[4]='.'; temp[5]=fract/10 +'0'; temp[6]=fract-(fract/10)*10 +'0'; temp[7] = '\0';
Logged
Offline
Newbie
« Reply #33 on: February 17, 2013, 01:04:13 pm » |
why dont use DallasTemperatureControl library?
Logged
Offline
Newbie
« Reply #34 on: February 17, 2013, 06:12:41 pm » |
Dallas's librairy?
Logged
Offline
Newbie
« Reply #35 on: February 19, 2013, 12:50:48 pm » |
Dallas's librairy?
Yes, why don't use Dallas's library?
Logged
Offline
Newbie
« Reply #36 on: February 19, 2013, 08:17:40 pm » |
what's that I juste done a quick google's search, but nothing interrested....
can you explain what's that?
Logged
Dubuque, Iowa, USA
Offline
Edison Member
« Reply #37 on: February 19, 2013, 11:37:55 pm » |
There's an Arduino library for "one wire" devices like the DS18B20. http://playground.arduino.cc/Learning/OneWire
Logged
Offline
Newbie
« Reply #39 on: April 22, 2013, 09:05:04 am » |
Hi everybody! I'm newbie and I want to make similar project. But I use Wiznet W5100 Ethernet Shield... So my question is how to change the code for the Arduino Ethernet Shield? Сan anybody help me?
Logged
Offline
Newbie
« Reply #40 on: April 30, 2013, 03:31:49 pm » |
Hi, this code is really nice! I modified it a little bit to be used with LM35DZ. Now I need to implement the basic authentication (otherwise everybody can enter my home system and switch on my heater!!!) but I am completely lost!!! Could someone help me please? thanks!
Logged
Dubuque, Iowa, USA
Offline
Edison Member
« Reply #41 on: April 30, 2013, 05:30:05 pm » |
The client will make a request to your Arduino, typically with no authorization. GET /foo HTTP/1.0 Host: foo.bar.com Your arduino should respond with a request for authorization 403 Forbidden The client will redo its request with credentials GET /foo HTTP/1.0 Host: foo.bar.com Authorization: Basic base_64_encoded_username_password Your arduino can either decode the base64 encoded string or simply perform a match against a known base64 encoded string. An example of a an encoded Header, using the username "username" and password "password" separated by a colon in the standard format of "username:password" would look like: Authorization: Basic dXNlcm5hbWU6cGFzc3dvcmQ= In each instance there will be additional HTTP headers present, such as "User-Agent:" or "Accept:", but what I have above are the only important ones. Putting that more simply, for any request that you receive you should verify that there is an Authorization: header and that the encoded string contains a proper username/password. Continue processing the request as usual if so. If not, reply with a 403 Forbidden response.
Logged
Offline
Newbie
« Reply #42 on: May 01, 2013, 02:24:37 pm » |
Hi, could you help me to integrate it in my code? I am really a newbie... Thanks!
Logged
