Topic: Arduino Webserver with Temperature Monitor / Control (Read 72058 times) previous topic - next topic
Kryten
#45
Jan 12, 2014, 09:33 am Last Edit: Jan 13, 2014, 08:25 am by Kryten Reason: 1
One small issue is that negative temperatures are shown as positive value.
Im currently having a temp of -4 deg C and the webserver shows 4 deg C.
Also: how can I modify to only have temp showing. I have done it on what you see but when I try to remove all with ths SSR's The web page won't load.
EDIT:
Could I just simply use signbit to add in a "-" ?
Kind of the same way as tou use the SSR bytes for on and off??
Aldeeb
#46
Jan 13, 2014, 09:20 am Last Edit: Jan 13, 2014, 09:23 am by Aldeeb Reason: 1
Reply to " elektrokan "
Your  problem is here
Code: [Select]
byte sensor1[8] = { 0x28, 0x61, 0x24, 0xC5, 0x03, 0x00, 0x00, 0x51};  // User Defined Temperature Sensor Address 1
Use the temperature example from the Onewire Library to find your DS18X20's address , then copy and replace the existing address with a new one.
prozorianu
Nice project !
How to edit the schetch to use ethernet shield based on wiznet5100 an DHT22 tmperature sensor  ?
daton
Please could you tell me here insert links to the library used to 28j60. thank you
daton
Please is this thread still alive? Could someone here insert links to the library used to 28J60? Thank you.
Chagrin
http://jeelabs.net/projects/ethercard/wiki
chetan0412
After uploading code i am not able to load page,
i have changed IP address as per my req.
need help
chiroskian
Hello i have a problem, in the web i only see 0°C and it never change.
I define the address of my DS1820 but it´s all the same.
Any idea about the problem? I´m using an Arduino Uno and Ethernet shield V1.1 .
Thanks!!
djkpap
hi guys i have arduino mega at mega 2560 and i cant compile this code.
i have this error
Arduino: 1.5.7 (Windows 8), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
web_control.ino:20:21: fatal error: OneWire.h: No such file or directory
compilation terminated.
i need this project
please help :smiley-red:
nmcfelix
i have this error
i need this project
Do you have OneWire Library installed?
djkpap
yes library instaled but i have ethernet w5100!!
attiny85
hi every one I'm new here. please I need this sketch for w5100 shield can some one edit it for me thanks :smiley-mr-green:
koukou41
#57
Aug 17, 2015, 02:31 am Last Edit: Aug 17, 2015, 02:34 am by koukou41
I want know whether Arduino Nano Clone is a USB Microcontroller or not? .Because I found a product in website named http://iteadstudio.com and the product name is Arduino Nano USB Microcontroller v3 (Clone version) .As you mentioned in your description the these words "Arduino" ,"Nano" and "Clone" words are containing in the product name Arduino Nano USB Microcontroller v3 (Clone version). If you mentioned the same product can you please tell me the prize you bought that part and from where you bought it. So I can compare it with the prizes in markets and buy the cheapest one
Dashquid
fatlossprofessional.co.uk
fatlossprofessional
mobilehelper
securetrip
whichpetcover
google
abc
facebook
craigslist
Useful sites listed above, I use most of them. EuropeGiant Classifieds is also a great one.
