Loading...
Pages: [1]   Go Down
Author Topic: is there any method to inculude live video streaming in html page  (Read 1001 times)
Peshawar
Offline Offline
Newbie
View Profile
i am working on home automaton project. i did every thing but i now need to see live streeming video on my browser page. like if i use web cam then how to connetc it to arduino or ethernet shield board.
i am using arduino mega with ethernet shield.
i think microcontroller will not support the video because its ram is not so big.
is there any alternative method.
Logged
Ayer, Massachusetts, USA
Offline Offline
Edison Member
View Profile
WWW
I would imagine you need to have the PC talk directly to the web cam directly for live streaming.  You may need a process on your pc, that combines the live feed from the web cam with the stuff from the Arduino (or just java/javascript in your browser).
Failing the ability of the PC to talk to the web cam, you likely will need to upgrade to a processor that can handle live video feeds.  Presumably ARM processors (mbed, beaglebone, raspberry-pi, etc.) have enough memory and processor speed to handle it, but I don't know from personal experience.
If you just need to overlay some simple text over the video feed, you could use a video shield such as http://nootropicdesign.com/ve/, and then have the PC accept composite video input, possibly through a TV card or frame grabber.
« Last Edit: July 17, 2012, 11:12:01 am by MichaelMeissner » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
As the arduino generally does not support video transmission, the most likely solution is to use an "IP cam" to supply the video to a web page. Look at the below page source code to see a method to put video in a control page. Note that the cam has a bad wire that causes the video to drop out in some positions.
http://web.comporium.net/~shb/wc2000-PT-script.htm
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Sussex UK / CT USA
Offline Offline
Edison Member
Forums forever
View Profile
WWW
As much as I love the Arduino, there are some projects which are better done with other hardware.
If you just want to see what's happening at a remote (but internet enabled) location, an IPcam is the way to go... there are many which have built in servers. You only need to leave the camera and the internet connection turned on. No PC needed.
Now... if you want to refine the CONTROL you have over the camera... position, on/off, etc., then you might have good cause to add an Arduino with an ethernet interface to the equation....
Logged
Pages: [1]   Go Up
Print
Jump to:
