Topic: Mac OS mountain lion Not detect Arduino Serial Port (Read 20884 times) previous topic - next topic
HugoPT
Hello
Today I update my mac to the last version of Mac OS Mountain Lion.
The problem is now after open the IDE on Ports Menu it wont show the arduino Serial Port /dev/tty.USB0 as expected
Soo now I cant upload codes.
I also try to connect my ftdi232RL mini board and it is not displayed to in the IDE
Anyone else already upgrade to this version?
If I go to mac system info it shows this:
Code: [Select]
FT232R USB UART:
  ID do produto: 0x6001
  ID do fabricante: 0x0403  (Future Technology Devices International Limited)
  Versão: 6.00
  Número de série: A600JRD9
  Velocidade: Até 12 Mb/seg
  Fabricante: FTDI
  ID da localização: 0x04100000 / 2
  Corrente disponível (mA): 500
  Corrente necessária (mA): 90
Could it be a IDE problem or a Mac problem?
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
James C4S
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
HugoPT
Is there any way to see all tty.??? devices on the mac to see if it is recognesed?
On linux I can do something like tail -f /var/log/messages
Is there any similar command on mac?
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
James C4S
ls -l /dev/tty*
dmesg at the terminal
Console from the GUI (in Applications -> Utility Folder) contains all log files
System Profilier (Or System Report in [Mountain] Lion) available from Apple Menu -> About This Mac -> More Info / System Report
Yes lots of options.
HugoPT
Problem solved
It really need to install the FTDI drivers.
I found this tuturial and works great
http://geekscape.posterous.com/mac-os-x-17-lion-upgrading-ftdi-usb-serial-dr
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
igorfv
Problem solved
This solution is not working for me =(
jopiek
I did this and it works perfectly fine (Mountain Lion under a MBP Retina), alas is the port the lowest in the list (was always on top), but it works!
jopiek
Warning: the old crashing problem is introduced once again. So if you are sending Serial data don't disconnect the USB before closing the terminal or your mac will crash!!! For me this is the only way I can crash my mac in normal use b.t.w., I have never experienced it in other situations!
ericklil
Know this is an old thread but the title is popular with people with a similar issue and there are lots of them it seems.
What worked for me is to look in the /Library/Extensions/Java/Extensions I found a file RXTXcomm.jar in there (from 2006) I trashed it and re-started Arduino... success! took me many hours to find it. You may have to show hidden files in the finder which requires Terminal and the following command (defaults write com.apple.finder AppleShowAllFiles TRUE) when done replace TRUE with FALSE and you're back to normal.
Since your original post come up to the top of Google search I hope this works for others too.
voodoochemist
What worked for me when the USBmodem port stopped showing was pretty simple, but easy to overlook since the steps are specific. It requires getting the Arduino to reset by removing all power and allowing the Arduino port to reset when the IDE restarts:
1) unplug from the Arduino the power cable (if being used) and USB cable; all power needs to be removed from the Arduino
2) quit the IDE if it's running
3) re-attach the USB cable to the Arduino (***but don't attach the Arduino power cable yet***)
4) restart the IDE
Check the USBmodem port is now showing up as a menu option. If it is, now you can re-attach the power cable to the Arduino.
Hope this works for others... I thought this would work because my Mega had the problem. When I plugged in my Uno (after restarting the IDE) the USBmodem port appeared, however, when plugging the Mega in, the port disappeared. That's when I realized the problem was with the Mega and not my Mac drivers.
fr0zenst0rm
4) restart the IDE
Too bad, this doesn't work for me :-(
And sorry for diggin' in old threads!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
