Topic: Problem with standalone atmega328 (Read 664 times) previous topic - next topic
pinata2501
Jul 17, 2012, 08:42 pm Last Edit: Jul 17, 2012, 08:57 pm by pinata2501 Reason: 1
Hello,
I try to make a standalone atmega328 on a breadboard.
I've followed those links:
http://www.arduino.cc/en/Main/Standalone
http://arduino.cc/forum/index.php/topic,114306.0.html
http://www.electronics-hobby.com/2011/07/07/stand-alone-arduino/
and others...
So I've uploaded the blinking led sketch on my arduino uno (r2) and make sure it worked.
The i've take off the atmega and put it on the breadboard following the instructions in http://www.arduino.cc/en/Main/Standalone.
But the led does not blink.
I've tried many times but still nothing.
What do I miss ?
Is it possible to do with an arduino uno or am I wasting my time ?
Thanks
johnwasser
Could be power noise because there aren't any bypass capacitors between +5 and Ground near the chip.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
CrossRoads
It's possible your switch is shorting reset to Gnd. Try removing the Gnd connection to the switch.
If that works, move your GND connection to the other side of the center-divider.
CrossRoads
It's also possible your LED is backwards. Try flipping it around. You want the short leg (that has flat spot on the lip of the LED) going to the resistor.
pinata2501
the switch and the led are ok.
It must be something else.
JoeO
The wiring looks good.
The possible causes are:
Open wire/s
5 Volts not present or too low - Bad regulator
328 pin bent under.
Reset switch not working.
Open resistor.
LED does not work.
Bad breadboard
You should be able to determine what problem it is using a volt meter.
pinata2501
ok i've found the problem.
Wrong capacitors with the quartz.
Thank you all for your answers
CrossRoads
Lack of attention to detail - will bite you every time.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
