Topic: millis()/1000 counting away like crazy. (Read 819 times) previous topic - next topic
DrKarma
Hi all.
Using MEGA 2560 with LCD Keypad Shield.
Playing around with the sample code provided at http://www.dfrobot.com/wiki/index.php?title=Arduino_LCD_KeyPad_Shield_(SKU:_DFR0009)
Code: [Select]
//Sample using LiquidCrystal library
#include <LiquidCrystal.h>
This program will test the LCD panel and the buttons
Mark Bramwell, July 2010
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// Set up a bunch of arrays for future usage in matrix
String profileName[5];
String stepOneName[5];
int stepOneTemp[5];
int stepOneTime[5];
String stepTwoName[5];
int stepTwoTemp[5];
int stepTwoTime[5];
String stepThreeName[5];
int stepThreeTemp[5];
int stepThreeTime[5];
String stepFourName[5];
int stepFourTemp[5];
int stepFourTime[5];
String effectProfileName[2];
String effectHigh[2];
int selectedProfile = 0;
int tempLossInSystem = 0;
// read the buttons
int read_LCD_buttons()
adc_key_in = analogRead(0);      // read the value from the sensor
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
if (adc_key_in < 50)   return btnRIGHT;
if (adc_key_in < 195)  return btnUP;
if (adc_key_in < 380)  return btnDOWN;
if (adc_key_in < 555)  return btnLEFT;
if (adc_key_in < 790)  return btnSELECT;
return btnNONE;  // when all others fail, return this...
//HELP NEEDED HERE - START
// setupDefaultSteps();  // Populate with some default values
//HELP NEEDED HERE - STOP
lcd.begin(16, 2);              // start the library
lcd.setCursor(0,0);
lcd.print("Push the buttons"); // print a simple message
lcd.setCursor(9,1);            // move cursor to second line "1" and 9 spaces over
lcd.print(millis()/1000);      // display seconds elapsed since power-up
lcd.setCursor(0,1);            // move to the begining of the second line
lcd_key = read_LCD_buttons();  // read the buttons
switch (lcd_key)               // depending on which button was pushed, we perform an action
   case btnRIGHT:
     lcd.print("RIGHT ");
   case btnLEFT:
     lcd.print("LEFT   ");
   case btnUP:
     lcd.print("UP    ");
   case btnDOWN:
     lcd.print("DOWN  ");
   case btnSELECT:
     lcd.print("SELECT");
     case btnNONE:
     lcd.print("NONE  ");
void setupDefaultSteps()
profileName[0] = "1 step Light";
stepOneName[0] = "Strike temp.";
stepOneTemp[0] = 71;
stepOneTime[0] = 2;
stepTwoName[0] = "Sacc. rest";
stepTwoTemp[0] = 64;
stepTwoTime[0] = 75;
stepThreeName[0] = "Mash out";
stepThreeTemp[0] = 76;
stepThreeTime[0] = 10;
stepFourName[0] = "";
stepFourTemp[0] = 0;
stepFourTime[0] = 0;
profileName[1] = "1 step Medium";
stepOneName[1] = "Strike temp.";
stepOneTemp[1] = 73;
stepOneTime[1] = 2;
stepTwoName[1] = "Sacc. rest";
stepTwoTemp[1] = 67;
stepTwoTime[1] = 60;
stepThreeName[1] = "Mash out";
stepThreeTemp[1] = 76;
stepThreeTime[1] = 10;
stepFourName[1] = "";
stepFourTemp[1] = 0;
stepFourTime[1] = 0;
profileName[2] = "1 step Full";
stepOneName[2] = "Strike temp.";
stepOneTemp[2] = 75;
stepOneTime[2] = 2;
stepTwoName[2] = "Sacc. rest";
stepTwoTemp[2] = 69;
stepTwoTime[2] = 45;
stepThreeName[2] = "Mash out";
stepThreeTemp[2] = 76;
stepThreeTime[2] = 10;
stepFourName[2] = "";
stepFourTemp[2] = 0;
stepFourTime[2] = 0;
profileName[3] = "2 steps Light";
stepOneName[3] = "Strike temp.";
stepOneTemp[3] = 54;
stepOneTime[3] = 2;
stepTwoName[3] = "Protein rest";
stepTwoTemp[3] = 50;
stepTwoTime[3] = 30;
stepThreeName[3] = "Sacc. rest";
stepThreeTemp[3] = 64;
stepThreeTime[3] = 75;
stepFourName[3] = "Mash out";
stepFourTemp[3] = 76;
stepFourTime[3] = 10;
profileName[4] = "2 steps Medium";
stepOneName[4] = "Strike temp.";
stepOneTemp[4] = 54;
stepOneTime[4] = 2;
stepTwoName[4] = "Protein rest";
stepTwoTemp[4] = 50;
stepTwoTime[4] = 30;
stepThreeName[4] = "Sacc. rest";
stepThreeTemp[4] = 67;
stepThreeTime[4] = 45;
stepFourName[4] = "Mash out";
stepFourTemp[4] = 76;
stepFourTime[4] = 10;
profileName[5] = "2 steps Full";
stepOneName[5] = "Strike temp.";
stepOneTemp[5] = 54;
stepOneTime[5] = 2;
stepTwoName[5] = "Protein rest";
stepTwoTemp[5] = 50;
stepTwoTime[5] = 30;
stepThreeName[5] = "Sacc. rest";
stepThreeTemp[5] = 67;
stepThreeTime[5] = 45;
stepFourName[5] = "Mash out";
stepFourTemp[5] = 76;
stepFourTime[5] = 10;
When I have the following section commented out the "lcd.print(millis()/1000);" prints every second since start as it suppose to
Code: [Select]
But when I change like below to populate arrays in the function "setupDefaultSteps"  "lcd.print(millis()/1000);" prints like crazy.
Code: [Select]
Anyone know what I am doing wrong or why it behaves this way?
Br,
Magnus
majenko
In setupDefaultSteps(), how many profiles are you setting up?
When defining the arrays, how many slices are you allocating?
Answer those two questions and you may be part way to fixing your problem.
WizenedEE
What does print like crazy mean? What is it printing? Are you saying it's changing quickly?
DrKarma
Yes. Counts rapidly.
But advice that majenko gave fixes it (as below).
Code: [Select]
String profileName[6];
String stepOneName[6];
int stepOneTemp[6];
int stepOneTime[6];
String stepTwoName[6];
int stepTwoTemp[6];
int stepTwoTime[6];
String stepThreeName[6];
int stepThreeTemp[6];
int stepThreeTime[6];
String stepFourName[6];
int stepFourTemp[6];
int stepFourTime[6];
PaulS
Using the String class for strings that do not change is a waste of precious memory. Get out of that habit NOW!
