Loading...
Pages: [1]   Go Down
Author Topic: How do I measure voltage?  (Read 465 times)
Offline Offline
Newbie
View Profile
I am building a power supply using an LM317.  I have decided to use a potentiometer to control the voltage.  I want to include a 4 digit display to display the output voltage.  Any idea on how I can measure the voltage coming out of the LM317?  Keep in mind it will be more that 5 volts, so the analogRead function in an Arduino won't do the job.
Logged
New Jersey
Online Online
Edison Member
View Profile
Search the forum (or wikipedia) for voltage divider - then you can see how to use analogread to measure it.
Logged
Offline Offline
Newbie
View Profile
Did you not read what I wrote?  I said I can't use analogRead.
Logged
Ayer, Massachusetts, USA
Offline Offline
Edison Member
View Profile
WWW
If you were willing to settle for only 3 digits, and the LM317 will be producing less than 99v, this unit from yourduino might be useful.  However, I suspect you want more accuracy, and want to do it from electronics.  But if you wanted to save time: http://arduino-direct.com/sunshop/index.php?l=product_detail&p=247 (they also have green and blue lcds at a slightly higher price).
While I am at the beginning of learning about electronics, I'm not sure why you can't use a voltage divider, since it can reduce the voltage to within 5v that the Arduino can read (and then in the Arduino you multiply to get the actual voltage).  I can imagine you would need a ladder or some such if you need to deal with a wide range of voltages.
« Last Edit: July 18, 2012, 03:09:23 pm by MichaelMeissner » Logged
New Jersey
Online Online
Edison Member
View Profile
Quote
A voltage divider with suitably proportioned resistors will allow you to reduce the measured voltage into the 0-5v range to be usable by the ADC. Was there some other reason why analogread won't work for you?
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
No, you wrote
Quote
(it's up there, at the top of the page)
Of course, if you reduce the voltage to less than 5volts, there's no reason whatsoever not to use analogRead, unless you've run out of pins, but that's not what you said.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Well you can do this:-
http://tuxgraphics.org/electronics/200706/mini-digital-voltmeter.shtml
or buy one of these:-
http://handheldinstruments.eu/digital-indicators/standard-signals/gpv-220-digital-voltage-display-module/
or these
http://www.alibaba.com/showroom/lcd-voltage-display.html
Logged
Pages: [1]   Go Up
Print
Jump to:
