Topic: Reading serial data from maxSonar ultrasonic rangefinder (Read 7330 times) previous topic - next topic
Goldthing
Hi all, just started with arduino and thought I would share this. There seems to be plenty on using the analog or pulse width outputs from the MaxSonar products but nothing about their serial use. This simple function reads the incoming serial data, converts it to an integer and returns the result.
A few things to note first.
     - The serial output on the MAxSonar is always enabled unless told otherwise. Attempting to hook it up directly to the serial port will cause communication problems between arduino and computer.
     - Serial data is inverted from the MaxSonar, to remove the need for extra circuitry I have used the very handy function in SoftwareSerial to flip the signal
     - This should work for all LV-EZ* and XL* modules, however the range returned will either be inches or centimeters depending on the type.
Code: [Select]
/* test function to Parse data from MaxSonar serial data
and return integer */
#include <SoftwareSerial.h>
#define txPin 3                                            //define pins used for software serial for sonar
#define rxPin 2
SoftwareSerial sonarSerial(rxPin, txPin, true);            //define serial port for recieving data, output from maxSonar is inverted requiring true to be set.
boolean stringComplete = false;
  Serial.begin(9600);                                      //start serial port for display
  sonarSerial.begin(9600);                                 //start serial port for maxSonar
  delay(500);                                              //wait for everything to initialize
  int range = EZread();
  if(stringComplete)
    stringComplete = false;                                //reset sringComplete ready for next reading
    Serial.print("Range ");
    Serial.println(range);
    //delay(500);                                          //delay for debugging
int EZread()
  int result;
  char inData[4];                                          //char array to read data into
  int index = 0;
  sonarSerial.flush();                                     // Clear cache ready for next reading
  while (stringComplete == false) {
    //Serial.print("reading ");    //debug line
      if (sonarSerial.available())
      char rByte = sonarSerial.read();                     //read serial input for "R" to mark start of data
      if(rByte == 'R')
        //Serial.println("rByte set");
        while (index < 3)                                  //read next three character for range from sensor
            inData[index] = sonarSerial.read();
            //Serial.println(inData[index]);               //Debug line
            index++;                                       // Increment where to write next
        inData[index] = 0x00;                              //add a padding byte at end for atoi() function
      rByte = 0;                                           //reset the rByte ready for next reading
      index = 0;                                           // Reset index ready for next reading
      stringComplete = true;                               // Set completion of read to true
      result = atoi(inData);                               // Changes string data into an integer for use
  return result;
Hope this helps someone out there. Thanks to everyone who posts their code, I would never have got anywhere without you.
AWOL
I don't understand the presence of the flag "stringComplete".
If I'm reading that correctly, "EZreadead" doesn't return (blocks) unless it has a complete reading, so the flag is redundant.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
rkguy
AWOL: I am looking to get the same information using TTL. Should I use a different approach than softwareserial?
I specifically ordered a maxbotix rangefinder that uses TTL logic, thinking that it would be easier to interface with the arduino UNO than RS-232 but I see no examples on how to communicate with it using TTL.
Should I post this as a new topic? My apololgies for digging up an old one.
AWOL
It should be just as easy using TTL, just keep in mind that unlike RS232, TTL is not normally inverted.
rjdelbulk
Thanks for this Goldthing.
Does anyone out there know how to get a serial (apparently the most accurate) mm resolution reading from a HRLV unit ?
Piano_Man
A couple of days ago, I was helping a user with support for this topic (remember I work for MaxBotix), and I noticed that by default when reading the 1mm resolution from the MB1013 if the target was under 1 meter in distance, the Arduino would only read 3 numbers.  As soon as the target was further than 1 meter, the Arduino would output all 4 numbers.
Attached is the code that I gave this end user for support with this topic.
The information given, is from my personal experience and does not represent MaxBotix Inc. in any way.
rjdelbulk
Hi all,
In order to get the above serial code to resolve 1mm resolution the array has to be changed to 5 characters (from four), otherwise the last digit is not stored (giving you unrounded cm results as opposed to mm results).
Change from:
to:
char inData[5];                                          //char array to read data into
AND...
Change from:
while (index < 3)
to:
while (index < 4)
Piano_Man
Thank you for the correction.  I will make that change in my code, I appreciate this.
rjdelbulk
What is the purpose of the line:
#define txPin 3
(And isn't the specific usage of #define outdated?)
I do not current have anything connected to Pin 3 and the code seems to work fine.
Piano_Man
It tells the Arduino that this pin may not be used.
I tried removing this part of the code, and I kept getting errors because it wasn't defined.   So to keep from having a headache, I just removed it.
if anyone has a better way to using the serial data connection, please let me know.
NeilClark
I have a HRXL-MaxSonar MN 7369 and I'm having a hard time to use its Pin 5 (Serial Output) to communicate with Arduino. I used a RS232 to TTL converter. When I used the code in the comment (File Name: http://forum.arduino.cc/index.php?topic=114808.0) the Sensor seems to override the commands in the code and immediately prints out the distance value without printing the other texts. It is also weird because sometimes it prints out the serial value : http://imgur.com/bUJGMee and sometimes it does not: http://imgur.com/EH743kB. (That is the output given by the code) And when i upload a blank code, it gives a continuous serial output data: http://i.imgur.com/p3HhP7D.png Can anyonr enlighten me with this?
Just new in Arduino and I would really appreciate all the help! Thanks in advance!
digitalaudiotape
Thanks so much to Goldthing for posting a solution to reading serial output from Maxbotix MaxSonar ultrasonic rangefinder/proximity sensors on Arduino boards. I am doing a project with the MB1200 XL-MaxSonar-EZ0, pairing it with a proprietary LED panel with a built in ESP8266 limited to only 2 digital input pins. It was godsend to find out it's possible to flip the signal with SoftwareSerial (as well as see the integer parsing code). Flipping the signal in software is soooo simple and so much better than buying a hardware signal inverter. It took an extended Google dive to find this post but I'm glad I did. I came across a handful of other threads on this topic that died before the problem was resolved.
To add to the discussion, I ran into some LED frame rate issues with the "sonarSerial.available()" calls stalling the code down to 1-2 Hz. I was able to get my frame rate back up by removing "sonarSerial.available()" completely as well as removing "sonarSerial.flush()". This makes for a lot of garbage data, but that's easy enough to filter out with a simple if statement ignoring any readings below 20 centimeters or above 1000 centimeters. These changes also make the range readings stutter a bit, but the irregular updates are still faster than the 1 reading per second I need anyway. Not the greatest software engineering, but this is just for an art project anyway ;).
