Topic: 2 digit 7 segment score keeping (Read 4352 times) previous topic - next topic
hadjisra
I have a foosball table and I wanted an electronic scoring system. Now, I figured that I would have an inferred led and receiver at each goal (maybe with a transistor not sure yet). I then have a 2 digit 7 segment display from; http://www.sparkfun.com/products/9481. Now I want it to keep score like 5:7, the game score would be five to seven. I also want it to stop when one of the numbers hits 10 resembling the end of the game with a while (1) {}. Now I have no idea how to go about programing this except for the inferred led part. Can some one help me maybe give me a simple sample sketch to get started.
Thanks,
(BTW I have no idea how to hook the led screen up either)
PaulS
On the page you link, there is a sample sketch. In that sketch, it details what pins on the display to connect to what pins on the Arduino.
Have you connected it that way? Have you tried that sketch? Why not?
hadjisra
#2
Jul 18, 2012, 11:55 pm Last Edit: Jul 19, 2012, 12:02 am by hadjisra Reason: 1
Well for some reason my computer says it can't open it so it moves it to a folder and I cant find that folder. It would be helpful if you could open it up and post the code online, if thats not to much trouble.
hadjisra
ok I found the sample code now how would I add the colon to the counting? I've tried to hook it up but I cant get it to work. Heres the sample code:
6-13-2011
Spark Fun Electronics 2011
Nathan Seidle
This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
4 digit 7 segment display:
http://www.sparkfun.com/products/9483
Datasheet:
http://www.sparkfun.com/datasheets/Components/LED/7-Segment/YSD-439AR6B-35.pdf
This is an example of how to drive a 7 segment LED display from an ATmega without the use of current limiting resistors.
This technique is very common but requires some knowledge of electronics - you do run the risk of dumping too
much current through the segments and burning out parts of the display. If you use the stock code you should be ok, but
be careful editing the brightness values.
This code should work with all colors (red, blue, yellow, green) but the brightness will vary from one color to the next
because the forward voltage drop of each color is different. This code was written and calibrated for the red color.
This code will work with most Arduinos but you may want to re-route some of the pins.
7 segments
4 digits
1 colon
12 pins required for full control
int digit1 = 11; //PWM Display pin 1
int digit2 = 10; //PWM Display pin 2
int digit3 = 9; //PWM Display pin 6
int digit4 = 6; //PWM Display pin 8
//Pin mapping from Arduino to the ATmega DIP28 if you need it
//http://www.arduino.cc/en/Hacking/PinMapping
int segA = A1; //Display pin 14
int segB = 3; //Display pin 16
int segC = 4; //Display pin 13
int segD = 5; //Display pin 3
int segE = A0; //Display pin 5
int segF = 7; //Display pin 11
int segG = 8; //Display pin 15
  pinMode(segA, OUTPUT);
  pinMode(segB, OUTPUT);
  pinMode(segC, OUTPUT);
  pinMode(segD, OUTPUT);
  pinMode(segE, OUTPUT);
  pinMode(segF, OUTPUT);
  pinMode(segG, OUTPUT);
  pinMode(digit1, OUTPUT);
  pinMode(digit2, OUTPUT);
  pinMode(digit3, OUTPUT);
  pinMode(digit4, OUTPUT);
  pinMode(13, OUTPUT);
  //long startTime = millis();
  displayNumber(millis()/1000);
  //while( (millis() - startTime) < 2000) {
  //displayNumber(1217);
  //delay(1000);
//Given a number, we display 10:22
//After running through the 4 numbers, the display is left turned off
//Display brightness
//Each digit is on for a certain amount of microseconds
//Then it is off until we have reached a total of 20ms for the function call
//Let's assume each digit is on for 1000us
//If each digit is on for 1ms, there are 4 digits, so the display is off for 16ms.
//That's a ratio of 1ms to 16ms or 6.25% on time (PWM).
//Let's define a variable called brightness that varies from:
//5000 blindingly bright (15.7mA current draw per digit)
//2000 shockingly bright (11.4mA current draw per digit)
//1000 pretty bright (5.9mA)
//500 normal (3mA)
//200 dim but readable (1.4mA)
//50 dim but readable (0.56mA)
//5 dim but readable (0.31mA)
//1 dim but readable in dark (0.28mA)
void displayNumber(int toDisplay) {
#define DISPLAY_BRIGHTNESS  500
#define DIGIT_ON  HIGH
#define DIGIT_OFF  LOW
  long beginTime = millis();
  for(int digit = 4 ; digit > 0 ; digit--) {
    //Turn on a digit for a short amount of time
    switch(digit) {
    case 1:
      digitalWrite(digit1, DIGIT_ON);
      break;
    case 2:
      digitalWrite(digit2, DIGIT_ON);
      break;
    case 3:
      digitalWrite(digit3, DIGIT_ON);
      break;
    case 4:
      digitalWrite(digit4, DIGIT_ON);
      break;
    //Turn on the right segments for this digit
    lightNumber(toDisplay % 10);
    toDisplay /= 10;
    delayMicroseconds(DISPLAY_BRIGHTNESS); //Display this digit for a fraction of a second (between 1us and 5000us, 500 is pretty good)
    //Turn off all segments
    lightNumber(10);
    //Turn off all digits
    digitalWrite(digit1, DIGIT_OFF);
    digitalWrite(digit2, DIGIT_OFF);
    digitalWrite(digit3, DIGIT_OFF);
    digitalWrite(digit4, DIGIT_OFF);
  while( (millis() - beginTime) < 10) ; //Wait for 20ms to pass before we paint the display again
//Given a number, turns on those segments
//If number == 10, then turn off number
void lightNumber(int numberToDisplay) {
#define SEGMENT_ON  LOW
#define SEGMENT_OFF HIGH
  switch (numberToDisplay){
  case 0:
    digitalWrite(segA, SEGMENT_ON);
    digitalWrite(segB, SEGMENT_ON);
    digitalWrite(segC, SEGMENT_ON);
    digitalWrite(segD, SEGMENT_ON);
    digitalWrite(segE, SEGMENT_ON);
    digitalWrite(segF, SEGMENT_ON);
    digitalWrite(segG, SEGMENT_OFF);
    break;
  case 1:
    digitalWrite(segA, SEGMENT_OFF);
    digitalWrite(segD, SEGMENT_OFF);
    digitalWrite(segE, SEGMENT_OFF);
    digitalWrite(segF, SEGMENT_OFF);
    break;
  case 2:
    digitalWrite(segC, SEGMENT_OFF);
    digitalWrite(segG, SEGMENT_ON);
    break;
  case 3:
    break;
  case 4:
    break;
  case 5:
    digitalWrite(segB, SEGMENT_OFF);
    break;
  case 6:
    break;
  case 7:
    break;
  case 8:
    break;
  case 9:
    break;
  case 10:
    break;
mattrek
Hi all,  dose any one have a breadboard template to build the score counter?
xl97
@ OP
does you 2 digit, 7-segment leds unit HAVE the colon in there?
most just have a period.. (not a colon)
skootles
I did something similar, a completely automated foosball scoreboard:
It uses a trip laser in the goal posts and an RF transmitter / receiver to communicate. You can see more pics / a video here:
http://www.reddit.com/r/arduino/comments/reh4h/arduinopowered_foosball_scoreboard/
hadjisra
Thanks for all the help but I meant it's a 4 digit total display but I use two digits with the colon in between. Sorry in that screwed some people up.
CrossRoads
Do you want the colon on all the time?
Connect: +5, 1K resistor, display pin 4. display pin 12 to Gnd.
Otherwise, instead of +5, connect to an arduino pin, like D13.
"how would I add the colon to the counting?"
Can't say, you haven't said what you want it to do.
CrossRoads
@mattrek,
"Hi all,  dose any one have a breadboard template to build the score counter?"
Not sure what you are asking for.
Did you mean a schematic diagram showing what gets connected? Did you want to use the same code & sparkfun display?
spcomputing
6-13-2011
Nathan Seidle
Datasheet:
7 segments
4 digits
1 colon
  //delay(1000);
//500 normal (3mA)
    switch(digit) {
    case 1:
      break;
    case 2:
      break;
    case 3:
      break;
    case 4:
      break;
    toDisplay /= 10;
    lightNumber(10);
  case 0:
    break;
  case 1:
    break;
  case 2:
    break;
  case 3:
    break;
  case 4:
    break;
  case 5:
    break;
  case 6:
    break;
  case 7:
    break;
  case 8:
    break;
  case 9:
    break;
  case 10:
    break;
The sketch does not appear to have the colon in it...?
Pins 4 and 12 (L1 and L2) on the 7-Segment display need to be powered.  You will need to other digital pins (PWM not needed) and set them to high in the sketch.
http://www.spcomputing.com
mattrek
@CrossRoads
Hi. Yes i meant a diagram of whats gets connected. Thanks XD
CrossRoads
Schematic to connect display per the code above.
I show resistors to limit current flow, your call as to whether to leave them on or not.
