Topic: problems reading gps output (Read 2816 times) previous topic - next topic
1101
Jul 14, 2012, 10:08 am Last Edit: Jul 14, 2012, 10:10 am by 1101 Reason: 1
Hello!
i'm trying to read gps(global sat et-332) tx output using arduino mega 2560
i've connected gps tx to arduino rx1
gps configured to work in nmea mode, if i connect it to pc - i get perfect nmea output
but when i when i run this code on arduino
Code: [Select]
 // initialize both serial ports:
 Serial1.begin(9600);
 // read from port 1, send to port 0:
 if (Serial1.available()) {
   char inByte = Serial1.read();
   Serial.write(inByte);
i get this
Code: [Select]
??é9óæ̦&¦f³¦&æssssóæóææssS9ófóæS9sóæææfM???=?æ̦æ&f³¦&æS¦&æÌÓ:>6NÆN>2"26F:>2NêN:N>2N2F&N6>FNÊN:.F*NÊNN>>>>V*ÊÖ?ù??é9óæ̦æ¦Ì³¦&æS¦&æÌÓ>NÆN>2"26F:>"NêN:N>2N2F&N6>FNÊN:.F*NÊNN>>>>V*:ÊÖ
instead of NMEA
none of googled gps reading solutions are worked, i'm stuck :(
ebird97
I haven't used a GPS device before. But I do know that when talking over the Serial monitor you have to use the right baud rate. Perhaps 9600 baud is the wrong rate. Also you misspelled Serial in your code. Perhaps that may be causing the problem.
Hope this helps.
1101
whwn i connect to pc using same baud rate - i get nmea sentences
misspelled? where? i'm using arduino mega, it has 3 serial's, i connect gps to serial1 rx
ebird97
In void setup you have it as "Seriall.begin(9600);
You put an extra 'l', lol
nickgammon
How have you connected it, hardware-wise?
From the datasheet I found:
Quote
Output TTL level , 0V ~ 2.85V
I'm wondering if, electrically, it is matching up.
Maybe the logic levels are inverted, the datasheet is a bit vague on that point.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
1101
i thought about it.
But how do i check it or how do i invert it?
TobyB
Hmm- I can't get the sheet to open from USGlobalsat.  But the board I have from them runs at 4800 baud, default- might be worth a quick try just to see...
t
1101
nope
4800 gets almost same result
nickgammon
Can you post a link to a datasheet that describes the requirements in detail? Like, logic levels, whether a 1 is 0V, 5V, -5V and so on?
More info:
kg4wsv
Sounds like you have an RS232 level device connected to the TTL level Arduino.
Get yourself a MAX232 or equivalent circuit to do the appropriate level shifting.
-j
1101
but i thought that arduino can understand rs-232
PaulS
Quote
We can't help what you think. The FACT is that it can't.
