Loading...
Pages: [1]   Go Down
Author Topic: Create Arudino UNO board  (Read 965 times)
Offline Offline
Newbie
View Profile
I want to develop my own Arudino UNO board following below Article.
http://www.instructables.com/id/How-to-make-your-own-Arduino-board/?ALLSTEPS
I cannot find interfacing for USB, any idea how this can be done ?
Thanks,
Ujjwal Soni
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Use a USB to TTL Serial cable or board, sometimes called an FTDI cable.
Logged
Offline Offline
Full Member
We were born naked, wet and hungry. And then things get worse!!!
View Profile
I would suggest you to use the UNO board to burn the program. You have too buy a FTDI breakout board which will cost you around 14-15$.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Other USB interface options are:
Mikroelectronika MIKROE-483
http://www.mouser.com/ProductDetail/mikroElektronika/MIKROE-483/?qs=%2fha2pyFaduiYF24RmhpFb%2fIWf1yag44MUlcjvQN8IKu%2fLeA1aA%252bcGO%252bFHzoFLaES
CP2102 modules found on e-bay.
Look for units that have holes along the side where some signals are brought out. You will do a simple mod to cut the RST trace going to the end header pin and wire the pin to the DTR hole instead. This will allow software resets during downloads.
Having USB interface capability can be very handy during sketch debugging.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Pages: [1]   Go Up
Print
Jump to:
