Topic: [SOLVED]LCD Display doesn't work if Serial.begin() is executed (Read 2178 times) previous topic - next topic
Artifactx
Jul 19, 2012, 02:58 pm Last Edit: Jul 19, 2012, 08:22 pm by AWOL Reason: 1
Hello I just tested my new LCD display and it works fine.
The setup I'm using is this:
http://arduino.cc/en/Tutorial/LiquidCrystal
When I run the following code everything works as intended:
Code: [Select]
 lcd.begin(16,2);
 lcd.print("Hello World");
But if I add Serial.begin(9600); liked this, the display shows weird symbols and doesn't update anymore, why is that?
Code: [Select]
 lcd.begin(16,2);
AWOL
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Artifactx
Where is the rest of your code?
That is the code, just made a simple example to point out my problem.
dxw00d
That doesn't compile.
Quote
sketch_jul19a.cpp: In function 'void setup()':
sketch_jul19a:3: error: 'lcd' was not declared in this scope
Where is your lcd declaration?
Artifactx
Code: [Select]
#include <LiquidCrystal.h>
LiquidCrystal lcd(6,5,4,3,2,1);
  //Serial.begin(9600);
  lcd.begin(16,2);
  lcd.print("HELLO WORLD!");
That is the whole code it works fine as long as Serial.begin(9600) is out commented. But if I uncomment Serial.Begin it shows the odd symbols on the display.
AWOL
Code: [Select]
lcd(6,5,4,3,2,1);
1?
Wouldn't it have wasted a lot less time if you'd posted that at the start?
Artifactx
I am not sure what you mean about 1?
What is the sulotion?
Sorry if I'm asking a stupid question.
AWOL
dxw00d
Pins 0 and 1 belong to the hardware serial port. When you do Serial.begin(), it starts using the pins.
AWOL
Yes, and that's your problem, so move the pin that is connected to pin 1 on the Arduino.
