Loading...
Pages: [1]   Go Down
Author Topic: switch on a led for 5 sec and turn off??  (Read 1268 times)
Sulaymaniyah-Kurdistan
Offline Offline
Jr. Member
View Profile
hi
please if you replay don't write any suggestion?? ok??---write the code
i want when you turn on the led after 5 sec turn off and doesn't turn on again????
thank for replay
« Last Edit: July 19, 2012, 09:21:17 am by zhirantaha » Logged
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
If you don't want our suggestions, what do you want?
Logged
Offline Offline
Jr. Member
View Profile
i need code
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Simple version:
Code:
  pinMode(13,OUTPUT); // LED output
  pinMode(2,INPUT); // Button input
  while(digitalRead(2)==LOW);
  digitalWrite(13,HIGH);
  delay(5000);
  digitalWrite(13,LOW);
More complex version:
Code:
  static unsigned char ledState = LOW;
  static unsigned char buttonState = LOW;
  static unsigned char lastButtonState = LOW;
  static unsigned long ledCameOn = 0;
  // If the LED has been on for at least 5 seconds then turn it off.
  if(ledState == HIGH)
    if(millis()-ledCameOn > 5000)
      ledState = LOW;
  // If the button's state has changed, then turn the LED on IF it is not on already.
  buttonState = digitalRead(2);
  if(buttonState != lastButtonState)
    lastButtonState = buttonState;
    if((buttonState == HIGH) && (ledState == LOW))
      ledState = HIGH;
      ledCameOne = millis();
Note: I haven't tested either bits of code, so do they work? Who knows! smiley
Logged
Offline Offline
Jr. Member
View Profile
by the way thank's smiley
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
You realise the simple version in reply #3 version doesn't actually meet your requirements?
@OP: If you only want code written for you and don't want to put in any effort, will you please post in "Gigs and Collaborations"?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
UK
Offline Offline
Edison Member
View Profile
WWW
It's hard to know what the requirements are from the brief few words the OP has written.
Logged
Offline Offline
Full Member
View Profile
start from the blinc example.. study it and read the reference
this is so simple that i think you shouldnt ask for a code example but do a little bit homework.
the more rewarding it will be when you have solved it.
hint try using an if statement... and a variable..
Logged
Offline Offline
Newbie
View Profile
Try not to be so demanding or angry. This is the simplest way to light an LED for five seconds then turn off permanently. It is just modified blink. I have tested it, so no worries. Enjoy.
int led = 13;
  pinMode(led, OUTPUT);
digitalWrite(led, HIGH);
  delay(5000);
digitalWrite(led, LOW);
Logged
ਪੰਜਾਬ
Offline Offline
Edison Member
WANTED! A Girl with LOVE for me and Arduino!
View Profile
WWW
it's soooooo00 cake!
Logged
"Real Men can Accomplish  Anything"
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Pages: [1]   Go Up
Print
Jump to:
