Topic: Extra long headers for shields? (Read 6756 times) previous topic - next topic
skootles
Jul 19, 2012, 06:40 pm Last Edit: Oct 22, 2012, 03:05 pm by skootles Reason: 1
EDIT: Found them. 6-pin version and 8-pin version.
Hey all, I need some advice here.
I just got my first Arduino shield back from the fab and I'm pretty excited about it. I had grabbed some headers that were advertised as "long" and "stackable arduino headers" but I've found that they're too short (10.5mm). When I put my shield on top of an Arduino Uno the board presses against the top of the USB port. This is a problem because it can cause a short on my shield. Here's a photo:
The only other shield I own is an ethernet shield and its headers are really long (14mm). When I put it on my Uno, it has no problems touching the USB jack:
I found some extra-long headers at a local shop but they were so expensive - $1.10 to $1.20 for ONE 6 or 8-pin header. Adding these to the shields will add about $5 to the final cost, which sucks.
Is this a regular problem for people who design shields? Are there any places online I can get these "extra-long" headers? I tried looking around but found nothing conclusive. Should I include these extra-long headers when I sell them, should I include the "long" ones knowing they'll be too short for people, or should I let people buy their own headers completely?
MichaelMeissner
Adafruit offers them a bit cheaper, though with shipping you probably should combine with other orders: https://www.adafruit.com/products/400.
I wish they were more common.
skootles
Those don't say how long they are, and they're also male headers. I found these ones from Adafruit but they're too short (10.5mm, like in my first photo). I wouldn't be totally opposed to using male headers, just as long as they're long enough.
graynomad
#3
Jul 20, 2012, 12:30 am Last Edit: Jul 20, 2012, 12:37 am by Graynomad Reason: 1
Have a look at the Samtec SSW/SSQ series. They have tails up to 14.83mm long.
According to my data sheet the 8-pin version would have the part # SSW-1-8-24-F-S, but I can't find that at Mouser et al so I may have the number wrong because I have found them before.
EDIT: Here's the data sheet www.robgray.com/temp/SSW-SSQ_TH.pdf
______
Rob
liuzengqiang
You have not found this yet?
http://dipmicro.com/store/HDR06X1FL
Jameco price is too high!
skootles
Those ones are still only 10.5mm long. Actually, this is where I get the majority of my components, they're cheaper than almost everywhere else.
I ended up revising my design to not go over the USB or power jacks on the board, so I have no problem with using the shorter headers now.
liuzengqiang
If you use EAGLE, add the shape of the Arduino connectors in a keepout layer. BTW, they have 10-pin female headers too, for UNO R3
ArduinoQandA
these look like they would work https://www.adafruit.com/products/85
