Topic: Timer on Attiny85 (Read 2608 times) previous topic - next topic
Erni
I am trying to teach myself something about timers, by reading this
http://deans-avr-tutorials.googlecode.com/svn/trunk/Timers/Output/Timers.pdf
I have an example (for Atmega16), and used it on a Attiny85.
The sketch  blinks a LED on Pin 0 every second, and it works.
But when i think about there are some strange thing I don't understand.
1. When I change the prescaler to 16384 it dosnt change the blinkrate ?
Code: [Select]
TCCR1 |= ((1 << CS13) |  (1 << CS12)| (1 << CS11)| (1 << CS10)); // Prescaler @ 1024 Table 12.5
2. I set OCR1A=7812; , but isn't OCR1A a 8 bit register ?
Code: [Select]
void setup(){
 DDRB |= (1<<PB0); //Set pin PB0 as output
TCCR1 |=(1<<CTC1); //Start timer 1 in CTC mode Table 12.3.1
TCCR1 |=(1<<COM1A0); //Timer1 in toggle mode Table 12.4
TCCR1 |= ((1 << CS13) |  (1 << CS11)| (1 << CS10)); // Prescaler @ 1024 Table 12.5
OCR1A=7812; //CTC Compare value
void loop(){
Coding Badly
Which core are you using?
Erni
I am using this core, Arduino 0021 and a pololu programmer.
The Attiny @ 8MHz
http://arduino.cc/forum/index.php/topic,51984.0.html
Coding Badly
#3
Jul 20, 2012, 07:32 pm Last Edit: Jul 20, 2012, 07:35 pm by Coding Badly Reason: 1
Some things...
• Timer 1 on the ATtiny85 family is different than all the other timers I've seen.  Code from another processor is unlikely to work without modifications.
• For the ATtiny85 family, the Tiny Core uses timer 1 for millis.  You can change that (for all projects) by modifying this macro...
http://code.google.com/p/arduino-tiny/source/browse/trunk/hardware/tiny/cores/tiny/core_build_options.h#107
• As far as I can tell, timer 0 is the same across all processors.  I suggest leaving millis on timer 1 and using timer 0 for your experiments.
• When manipulating registers, do not assume they are already set to a specific value.  For example...
[font=Courier New]  TCCR1 |= ((1 << CS13) |  (1 << CS12)| (1 << CS11)| (1 << CS10)); // Prescaler @ 1024 Table 12.5[/font]
...what if CS13 through CS10 are already 1?  Or this...
[font=Courier New]  TCCR1 |=(1<<COM1A0); //Timer1 in toggle mode Table 12.4[/font]
...what if COM1A1 is already 1?  You should first initialize all the relevant registers to a known value (like zero) then manipulate them.
Erni
Quote
I certanly will
Quote
You should first initialize all the relevant registers to 0
I see the point, and I will do that too, although I don't see that often in the tutorials.
Thank you for your help, it is not easy for me to understand the attiny datasheet, at least not at the stage I'm  on now.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
