Topic: Arduino Mega2560 can't be programmed via USB (Read 28087 times) previous topic - next topic
raxz
Jul 19, 2012, 10:33 pm Last Edit: Jul 19, 2012, 10:51 pm by Ragnar Reason: 1
I received my new Arduino Mega2560 (already have had Uno R3 and Mega 1280). Problem is with programming. I just can't program it.
I have no problems programming my Uno or 1280. I also tried programming 2560 with Uno as ISP, but not working. I used the same method for Attiny85 and it works so Uno is working as a programmer.
I use OSX 10.7, Arduino 1.0.1
Errors I get:
Code: [Select]
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_ReceiveMessage(): timeout
What to do?
Louis Davis
Take a look at this issue: http://code.google.com/p/arduino/issues/detail?id=806
Edit your boards.txt file and change
mega2560.upload.protocol=stk500v2
To:
mega2560.upload.protocol=wiring
raxz
#2
Jul 19, 2012, 11:41 pm Last Edit: Jul 19, 2012, 11:42 pm by Ragnar Reason: 1
No, nothing. RX LED only blinks 1 time and keeps giving same error.
Same thing with Arduino 0023
Binary sketch size: 6,198 bytes (of a 258,048 byte maximum)
Louis Davis
Select Show verbose output during upload in Arduino preferences.
Post back with the upload output and maybe that will give us an idea of what might be happening.
magic_smoke
Quote
To:
@ Louis Davis
Thanks very much for this solution, my Arduino 2560 (early version) on XP Home Edition just stopped uploading and hanging. Com port was still in the tools menu, and serial monitor was still working but no uploading.
thanks again, been driving me nuts for ages
Zed's dead baby, Zed's dead
tothmane
hello,
i have a similar issue with my brand new mega 2560 rev3. i start uploading then i have this message :
avrdude: stk500v2_getsync(): can't communicate with device: resp=0x01
avrdude done.  Thank you.
when i take a look at my arduino board, i can clearly see that my program is not working, so i'm pretty
sure that the program haven't been uploaded right.
Please can i get some help ?
ah i forgot, i changed the "wiring" setting written above , but nothing :s
thanks you a lot !
mastermushi
#6
Dec 08, 2012, 01:47 pm Last Edit: Dec 08, 2012, 01:52 pm by mastermushi Reason: 1
Hello everyone!
I have just solved the programming issue thanks to this thread and want to share the experience.
Google does not have exact steps for the solution so I have decided to continue this conversation
In all "out of the box" arduino IDE I had the following error messages for Mega2560 board
Can't find programmer id "wiring"
But thanks to clever people above, I have found what to do.
1) Open boards.txt and find
2) Replace this string with
3) Save the file and restart IDE
4) In main menu Tools->Programmer please change AVR ISP MKII to AVR ISP
5) Program your sketches fellas!!!
bluenomad
I'm having the same problem.  I received my Mega2560 2 days ago. Until this afternoon, everything was working fine. Suddenly the same code that was uploading wouldn't upload any longer. I hadn't changed anything. I've read a bunch of threads, tried changing the AVRDUDE.EXE to an older version that someone posted on a different site, modified the boards.txt file to "wiring" as indicated here, tried using the ISP programmer vs the ISP mkII programmer and vice-versa- nothing works.  I can't upload any programs. They all do this same thing. Very strange since it was working just fine earlier...
Here's an output from my verbose upload after I reverted everything back to the original EXCEPT I kept the "wiring" setting in the boards.txt:
Binary sketch size: 3,496 bytes (of a 258,048 byte maximum)
C:\Users\Cameron\Desktop\arduino-1.0.1\hardware/tools/avr/bin/avrdude -CC:\Users\Cameron\Desktop\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cwiring -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\Cameron\AppData\Local\Temp\build1215771844599652454.tmp\MegaTEST.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Users\Cameron\Desktop\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM5
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude: wiring_open(): releasing DTR/RTS
avrdude: wiring_open(): asserting DTR/RTS
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
Any thoughts?
Thanks,
Cameron
ubuntu_user
#8
Mar 25, 2013, 09:37 pm Last Edit: Mar 25, 2013, 09:41 pm by ubuntu_user Reason: 1
The same issue with my Mega2560. Reproduced with IDE 1.0.1 and 1.0.4.
I'm disappointed. It seems Arduino is NOT so user-friendly as people say.
Too much headache for too much money... It is more convenient now to buy Raspberry Pi with ADC chip if needed.
Here is my boot log:
Code: [Select]
/home/user/bin/arduino-1.0.4/hardware/tools/avrdude -C/home/user/bin/arduino-1.0.4/hardware/tools/avrdude.conf -v -v -v -v -patmega2560 -cwiring -P/dev/ttyACM12 -b57600 -D -Uflash:w:/tmp/build7626980947593966222.tmp/TempMonDS18B20.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  7 2011 at 19:34:16
        System wide configuration file is "/home/user/bin/arduino-1.0.4/hardware/tools/avrdude.conf"
        User configuration file is "/home/user/.avrduderc"
        User configuration file does not exist or is not a regular file, skipping
        Using Port                    : /dev/ttyACM12
        Overriding Baud Rate          : 57600
avrdude: ser_recv(): programmer is not responding
retrolefty
Quote
Correct PC usb driver installed?
Correct comm port selected in IDE menu?
Does the PC acknowledge the USB connection when you plug the board in?
Lefty
Louis Davis
Can you post the sketch that you are trying to upload?
Make sure you don't have three or more exclamations points in a row "!!!", the bootloader will interpret that as an escape sequence and enter a special mode.
ubuntu_user
Driver is correct. I've tried both in Windows 7 and Ubuntu 12.04.
Port is correct: it can upload small sketch "TimeSetRTC" which is DS1307 example. But my sketch doesn't.
In log file you can see PC recognized port as /dev/ttyACM12.
ubuntu_user
It seems some kind of black magic!!! There is no any warnings in user's manual about limitations on "!!!" symbols!!!
It was my case anyway. Thanks for advice.
borcabar
Thanks Louis Davis, The triple sign !!! was my problem too.
dmilton2004
Hello everyone!
Thanks!! I just got a Mega2560 r3 and I thought it was defective. I am using v1.0.5 and it has been working great on my UNO r3. Now it works great on my new Mega! One thing I noticed is that once I changed the upload protocol from wiring to stk500v2, it works on either AVR ISP or AVR ISP MKII.
