I think this kind is a little easier to rework
http://www.ebay.com/itm/USB-2-0-to-TTL-UART-6PIN-CP2102-Module-Serial-Converter-MCU-Full-Speed-12Mbps-/110918874292?pt=LH_DefaultDomain_0&hash=item19d347b4b4
Cut the trace going to the Reset IO pin, add a wire to connect the pin to the DTR hole. (retrolefty work-up a while ago)
Depending on the "Arduino bits" you are programming, the 0.1uF cap may already be on the board (like a Promini), or it may not (your own design).
I put them on mine designs so I don't have to be concerned about the USB/Serial module having one.
