Sydney
Big things come in large packages
« Reply #15 on: August 28, 2012, 09:58:46 pm » |
What you can do with Multiblink as it stands is blink one LED fast (say at 50 ms) and then another one slowly (say at 150ms) by creating a table of 2 elements.
What will happen is that on the third blink the second LED will light at the same time as the first. That is probably not what you are looking for,
There is a way to modify multblink to include the cycling a pattern and then adding in a delay at the end of the cycle. You could then define that one led will cycle 3 times at 50ms then delay 100ms before starting the cycle again. The second LED would not need this as it only goes off once. The change is relatively easy to do and I can help with that if I have described it correctly.
Sydney
« Reply #16 on: August 31, 2012, 10:56:10 pm » |
OK, so I modified MultiBlink to add the concept of looping in patterns. I think this does what you want from a flashing lights perspective, and I have a more flexible program to boot! Let me know how you go with this. Multi_Blink2.h // Multi_Blink2.h // // Blink lots of LEDs at diffreent frequencies simultaneously // // Header file is required to be able to define the structured types // #include <Arduino.h>
#ifndef MULTIBLINKH #define MULTIBLINKH
// State values for FSM #define MB_NULL 0 #define MB_LOW 1 #define MB_HIGH 2 #define MB_LOOP 3
#define LOOP_UNDEF 255
typedef struct { uint8_t activeVal; // state value for this state to be active (MB_* defines) uint16_t activeTime; // time to stay active in this state stay in milliseconds or loop counter uint8_t nextState; // If MB_LOOP this is the state to loop back/forward to } stateDef;
typedef struct { uint8_t ledPin; // Arduino I/O pin number uint8_t currentState; // current active state uint8_t currentLoop; // current position in the cycle stateDef state[4]; // the MB_* state definitions. Add more states if required uint32_t nextWakeup; // the 'time' for the next wakeup - saves the millis() value } ledTable;
#endif
Multi_Blink2.ino // Multi_Blink2 // // Blink lots of LEDs at different frequencies simultaneously, include delays and loops in patterns // // Marco Colli - September 2012 // // Demonstrates the way to carry out multiple time based tasks without using the delay() function // Demonstrates the use of structures (and structures within structures) // Demonstrates a data driven approach to programming to create compact, reusable code //
#include "Multi_Blink2.h" // type definitions
// Blink Table T - Modify this table to suit whatever the output requirements are // Add or delete lines as required to achieve the desired effects. // To add additional states the structure in the header file needs to be modified // ledTable T[] = //Pin St Lopp State 0 State 1 State 2 State 3 Wkup { { 3, 0, 0, {{MB_HIGH, 50, 0}, {MB_LOW, 100, 0}, {MB_LOOP, 4, 0}, {MB_LOW, 800, 0}}, 0 }, { 4, 0, 0, {{MB_LOW, 100, 0}, {MB_HIGH, 50, 0}, {MB_LOOP, 4, 0}, {MB_LOW, 800, 0}}, 0 }, { 5, 0, 0, {{MB_LOW, 800, 0}, {MB_HIGH, 50, 0}, {MB_LOW, 100, 0}, {MB_LOOP, 4, 1}}, 0 }, { 6, 0, 0, {{MB_LOW, 800, 0}, {MB_LOW, 100, 0}, {MB_HIGH, 50, 0}, {MB_LOOP, 4, 1}}, 0 }, };
// Self adjusting constants for loop indexes #define MAX_STATE (sizeof(T[0].state)/sizeof(stateDef)) #define MAX_LED (sizeof(T)/sizeof(ledTable))
void setup() { for (int i=0; i < MAX_LED; i++) { pinMode(T[i].ledPin, OUTPUT); T[i].nextWakeup = 0; digitalWrite(T[i].ledPin, LOW); T[i].currentLoop = LOOP_UNDEF; } }
void loop() { for (int i=0; i < MAX_LED; i++) { // check if the state active time has expired (ie, it is less than current time) if (millis() >= T[i].nextWakeup) { T[i].nextWakeup = millis() + T[i].state[T[i].currentState].activeTime;
switch (T[i].state[T[i].currentState].activeVal) { case MB_LOW: case MB_HIGH: // Write digital value digitalWrite(T[i].ledPin, T[i].state[T[i].currentState].activeVal == MB_HIGH ? HIGH : LOW); T[i].currentState = (++T[i].currentState) % MAX_STATE; break; case MB_LOOP: // loop back to specified state if there is still count left // first time in this state set the loop counter if (T[i].currentLoop == LOOP_UNDEF) { T[i].currentLoop = T[i].state[T[i].currentState].activeTime; }
// loop around or keep going? if (T[i].currentLoop-- > 0) { T[i].currentState = T[i].state[T[i].currentState].nextState; T[i].nextWakeup = 0; // do it immediately } else { T[i].currentLoop = LOOP_UNDEF; // set up loop counter T[i].currentState = (++T[i].currentState) % MAX_STATE; } break; default: // just move on - handles NULL and any stupid states we may get into T[i].currentState = (++T[i].currentState) % MAX_STATE; break; } } } }
« Reply #17 on: September 03, 2012, 05:52:28 pm » |
Hi Marco,
thanks for sharing your code. I have tried your first version of your Multiblink, I have created a doc.h called Multi_Blink.h and saved it in the same folder as Multi_Blink.ino, I have also created a folder and placed it in the Arduino Library folder. It was giving me this type of error 'leadTable does not name a type'. Then I have created a Multi_Blink2.h file, placed it in the same folder, closed everything, and it now works like a charm. Many thanks for sharing!
Best
F
« Last Edit: September 03, 2012, 05:59:37 pm by faeve »
« Reply #18 on: September 03, 2012, 06:22:05 pm » |
ok just wrote something simple.. you can ad more if lines if you have more leds, code is real short i guess it should work, not tested it. setup{ state1=false; state2=false; int pin1=1; int pin2=2; int x =0; PinMode(pin1,OUTPUT); PinMode(pin2,OUTPUT); }
// a short method using modulo function >> % <<
void loop(){ x++ if(x%3==0) {state1=!state1;digitalWrite(pin2,state2);} if(x%13==0) {state2=!state2;digitalWrite(pin2,state2);}
delay(.....) }
UK
« Reply #19 on: September 04, 2012, 12:09:43 am » |
If you like ( I do), you can use the IDE's auto format feature to help make your code more legible before you post it.
Seattle, WA USA
Seattle, WA USA
« Reply #20 on: September 04, 2012, 04:39:22 am » |
And that big key at the bottom of the keyboard? You know which one. Use it more often. Ditto for that big one on the middle row of characters, on the right.
UK
« Reply #21 on: September 04, 2012, 04:42:39 am » |
And scope. You need to pay more attention to scope. code is real short i guess it should work, not sp. "Code is real short I guess it should work. Not!"
« Last Edit: September 04, 2012, 05:19:38 am by AWOL »
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #22 on: September 04, 2012, 04:49:53 am » |
Shannon Member
Lua rocks!
« Reply #23 on: September 04, 2012, 04:51:46 am » |
That doesn't even compile, right? Read this before posting a programming question
« Reply #24 on: November 30, 2012, 06:42:02 pm » |
I have tried that code Marco_C and I like it. I don't really get most of it yet... But in these lines here ledTable T[] = //Pin St Lopp State 0 State 1 State 2 State 3 Wkup { { 3, 0, 0, {{MB_HIGH, 25, 0}, {MB_LOW, 25, 0}, {MB_LOOP, 3, 0}, {MB_LOW, 300, 0}}, 0 }, { 4, 0, 0, {{MB_HIGH, 25, 0}, {MB_LOW, 25, 0}, {MB_LOOP, 3, 0}, {MB_LOW, 300, 0}}, 0 }, { 5, 0, 0, {{MB_LOW, 250, 0}, {MB_HIGH, 250, 0}, {MB_LOW, 250, 0}, {MB_LOOP, 4, 1}}, 0 }, { 6, 0, 0, {{MB_LOW, 250, 0}, {MB_LOW, 250, 0}, {MB_HIGH, 250, 0}, {MB_LOOP, 4, 1}}, 0 }, {7, 0, 0, {{MB_LOW, 0, 0}, {MB_LOW, 500, 0}, {MB_HIGH, 500, 0}, {MB_LOOP, 4, 1}}, 0 }, };
I have fiddled with them somewhat. But I want the LED on pin 3 to do it's thing and it does..I have it flashing 3 times quickly and then wait, but I want it's mate on pin 4 to wait while it flashes then flash 3 times and then back to pin 3. They are a pair one flashes 3 times quickly then the other, on and off like that, but I can't get it work. They just flash together at the same time. How could I change it?
Also why is the loop in a different spot in two of the lines? (MB_LOOP)? I guess you can move it around to fit your LED state changes??
Thanks for the help ...
Andrew
Shannon Member
Lua rocks!
« Reply #25 on: November 30, 2012, 06:47:47 pm » |
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Sydney
« Reply #26 on: November 30, 2012, 07:54:38 pm » |
Here is the explanation: * MB_HIGH and MB_LOW are pretty obvious. They keep the LED on or off for the specified time. * MB_LOOP makes the pattern loop back to the nominated array element in the pattern for the specificed number of times. So the data { 3, 0, 0, {{MB_HIGH, 25, 0}, {MB_LOW, 25, 0}, {MB_LOOP, 3, 0}, {MB_LOW, 300, 0}}, 0 },
does this: 0 LED on for 25 ms 1 LED off for 25 ms 2 Loop back to element 0 and repeat it 2 more time (3 total) 3 LED off for 300 ms - this is just a delay while the 'other' LED does its thing So if we want to have a paired LED that works in tandem with this one we need to have the logic 0 LED off for 300 ms - this is just a delay while the 'other' LED does its thing 1 LED on for 25 ms 2 LED off for 25 ms 3 Loop back to element 1 and repeat it 2 more time (3 total) which provides to table entry { 4, 0, 0, {{MB_LOW, 300, 0}, {MB_HIGH, 25, 0}, {MB_LOW, 25, 0}, {MB_LOOP, 3, 1}}, 0 },
So if we look at them as a pair: { 3, 0, 0, {{MB_HIGH, 25, 0}, {MB_LOW, 25, 0}, {MB_LOOP, 3, 0}, {MB_LOW, 300, 0}}, 0 }, { 4, 0, 0, {{MB_LOW, 300, 0}, {MB_HIGH, 25, 0}, {MB_LOW, 25, 0}, {MB_LOOP, 3, 1}}, 0 },
You can see that the second MB_LOOP (pin 4) is in a different spot in the sequence and it loops back to a different place in the array. That is because we need to add the initial delay to the second LED while the sequence for pin 3 is executing.
« Last Edit: November 30, 2012, 07:59:08 pm by marco_c »
« Reply #27 on: December 01, 2012, 10:52:24 am » |
Thanks Marco. It is making more sense now. I will play around with it and see what I can get going. I learn a tidbit from each piece of code others write, so thank you. I am sure I will have other questions and I'll post them soon!! Thank you to everyone for their input so far. I'll try and remember the "code" thingy to make it easier for you to read. Andrew
« Reply #28 on: December 02, 2012, 03:17:07 pm » |
I am digging around in that code Marco, thanks. Now can I just load that into an ATTiny85? I think it will fit? Does most code work with the different chips?
I tried to just upload the code and it took it. But...the LED's stay on after they blink instead of stay off. I tried playing with some numbers in the table but no luck. Any ideas? (I say that but I am sure you already know...LOL)
Sorry for the noob questions, but I find you folks are very helpful!!
Andrew
« Last Edit: December 02, 2012, 03:39:37 pm by Antennas »
« Reply #29 on: December 02, 2012, 07:33:18 pm » |
Fairly easy: send a set of patterns to the leds and that pattern determines how fast they blink.
For example, if '1' means on and '0' means off,
0b11 -> both leds are on 0b01 -> bit 0 is still on, but bit 1 is blinking 0b10 -> bit 0 is blinking and bit 1 is blinking 0b00 -> bit 1 is blinking and bit 0 isn't.
A sequence like that will blink one led at 1/2 of the speed of the other led.
You can expand this approach to cover multiple leds at multiple speed.
