Offline
Newbie
« on: July 22, 2012, 12:36:53 am » |
hi, last week i received my new HCM5883L magnetometer breakout board , i connected it to arduino according to pin configuration that is SCL to pin 5, SDA to pin 4 with 5.6 k pullup resistor but i received just a raw data between 0 and 5 of x and y and the value of z is constant i-e -4096 ,and when i brought a magnet near to the sensor and move around, the value get high and then start fluctuate btw 0 and 5 . i m not getting what happened to this , whether the board is faulty or there is some other reason.i attached the screen shot of the serial monitor with code. plz if some one knows then help me .thanks in advance  /* HMC5883L_Example.pde - Example sketch for integration with an HMC5883L triple axis magnetomerwe. Copyright (C) 2011 Love Electronics (loveelectronics.co.uk)
This program is free software: you can redistribute it and/or modify it under the terms of the version 3 GNU General Public License as published by the Free Software Foundation.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with this program. If not, see <http://www.gnu.org/licenses/>.
// Reference the I2C Library #include <Wire.h> // Reference the HMC5883L Compass Library #include <HMC5883L.h>
// Store our compass as a variable. HMC5883L compass; // Record any errors that may occur in the compass. int error = 0;
// Out setup routine, here we will configure the microcontroller and compass. void setup() { // Initialize the serial port. Serial.begin(9600);
Serial.println("Starting the I2C interface."); Wire.begin(); // Start the I2C interface.
Serial.println("Constructing new HMC5883L"); compass = HMC5883L(); // Construct a new HMC5883 compass. Serial.println("Setting scale to +/- 1.3 Ga"); error = compass.SetScale(1.3); // Set the scale of the compass. if(error != 0) // If there is an error, print it out. Serial.println(compass.GetErrorText(error)); Serial.println("Setting measurement mode to continous."); error = compass.SetMeasurementMode(Measurement_Continuous); // Set the measurement mode to Continuous if(error != 0) // If there is an error, print it out. Serial.println(compass.GetErrorText(error)); }
// Our main program loop. void loop() { // Retrive the raw values from the compass (not scaled). MagnetometerRaw raw = compass.ReadRawAxis(); // Retrived the scaled values from the compass (scaled to the configured scale). MagnetometerScaled scaled = compass.ReadScaledAxis(); // Values are accessed like so: int MilliGauss_OnThe_XAxis = scaled.XAxis;// (or YAxis, or ZAxis)
// Calculate heading when the magnetometer is level, then correct for signs of axis. float heading = atan2(scaled.YAxis, scaled.XAxis); // Once you have your heading, you must then add your 'Declination Angle', which is the 'Error' of the magnetic field in your location. // Find yours here: http://www.magnetic-declination.com/ // Mine is: 2� 37' W, which is 2.617 Degrees, or (which we need) 0.0456752665 radians, I will use 0.0457 // If you cannot find your Declination, comment out these two lines, your compass will be slightly off. float declinationAngle = 0.0457; heading += declinationAngle; // Correct for when signs are reversed. if(heading < 0) heading += 2*PI; // Check for wrap due to addition of declination. if(heading > 2*PI) heading -= 2*PI; // Convert radians to degrees for readability. float headingDegrees = heading * 180/M_PI;
// Output the data via the serial port. Output(raw, scaled, heading, headingDegrees);
// Normally we would delay the application by 66ms to allow the loop // to run at 15Hz (default bandwidth for the HMC5883L). // However since we have a long serial out (104ms at 9600) we will let // it run at its natural speed. // delay(66); }
// Output the data down the serial port. void Output(MagnetometerRaw raw, MagnetometerScaled scaled, float heading, float headingDegrees) { Serial.print("Raw:\t"); Serial.print(raw.XAxis); Serial.print(" "); Serial.print(raw.YAxis); Serial.print(" "); Serial.print(raw.ZAxis); Serial.print(" \tScaled:\t"); Serial.print(scaled.XAxis); Serial.print(" "); Serial.print(scaled.YAxis); Serial.print(" "); Serial.print(scaled.ZAxis);
Serial.print(" \tHeading:\t"); Serial.print(heading); Serial.print(" Radians \t"); Serial.print(headingDegrees); Serial.println(" Degrees \t"); }
Logged
Offline
Edison Member
« Reply #1 on: July 22, 2012, 03:45:58 am » |
I have also problems with the returned raw data. But all raw x,y,z values change with a magnet, or with the earth magnetic file (if I rotate the breakout board).
Is only your raw z-axis changing with a magnet ? Can you add a link to the library and the breakout board ? Can you paste the output of the serial monitor in your message ?
« Last Edit: July 22, 2012, 03:48:08 am by Krodal »
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #2 on: July 22, 2012, 07:12:59 pm » |
Those pullups are going to +3.3V I hope....
Logged
Offline
God Member
« Reply #3 on: August 28, 2012, 09:18:29 am » |
Did you solve this problem ?
I have ordered one of these gadgets and I am worried about ruining it.
Do you need to have a resistor pair as a "voltage divider" when connecting a 3.3V I2C device to a 5V Arduino, or do you just use one pullup resistor connected to 3.3V, which would make it a pulldown resistor, I guess...
Logged
Offline
Edison Member
If you're not living on the Edge, you're taking up too much space!
« Reply #4 on: August 28, 2012, 10:01:18 am » |
Mine was difficult to calibrate. I couldn't figure it out, so I just used X,Z instead of X,Y for 2D. Seems Y was bad somehow, off by 50-100 degrees at times, combining X,Y. Rotate the unit 90 degrees to use X,Z.
Logged
If you fall... I'll be there for you! -Floor
Skype Brighteyes3333 (262) 696-9619
Offline
Newbie
« Reply #5 on: November 11, 2012, 05:22:41 am » |
Hello, I have a problem with HMC5883L magnetometer: card: Arduino 2009 Soft: HMC5883L_Example.pde
The sketch is loaded into the card (arduino) but in the serial monitor I have this:
Constructing new HMC5883L Setting scale to +/- 1.3 Ga Entered scale was not valid, valid gauss values are: 0.88, 1.3, 1.9, 2.5, 4.0, 4.7, 5.6, 8.1 Setting measurement mode to continous. Entered scale was not valid, valid gauss values are: 0.88, 1.3, 1.9, 2.5, 4.0, 4.7, 5.6, 8.1 Raw: 875 1795 883 Scaled: 805.00 1651.40 812.36 Heading: 1.16 Radians 66.63 Degrees Raw: 875 1795 883 Scaled: 805.00 1651.40 812.36 Heading: 1.16 Radians 66.63 Degrees Raw: 875 1795 883 Scaled: 805.00 1651.40 812.36 Heading: 1.16 Radians 66.63 Degrees Raw: 875 1795 883 Scaled: 805.00 1651.40 812.36 Heading: 1.16 Radians 66.63 Degrees Raw: -18176 -15872 322 Scaled: 805.00 1651.40 812.36 Heading: 1.16 Radians 66.63 Degrees Raw: 875 1795 883 Scaled: 805.00 1651.40 812.36 Heading: 1.16 Radians 66.63 Degrees Raw: 875 1795 883 Scaled: 805.00 1651.40 812.36 Heading: 1.16 Radians 66.63 Degrees
and so on.
What's happened ?
Thanx
Logged
Offline
Jr. Member
« Reply #6 on: November 18, 2012, 11:11:17 am » |
I use the standard "HMC5883L_Example.INO" and it seems to work but I still get the error: Entered scale was not valid, valid gauss values are: 0.88, 1.3, 1.9, 2.5, 4.0, 4.7, 5.6, 8.1 I have tried all those values but I always get this error and changing these numbers doesn't seem to make any difference to the readings. Why do I get this error?
Logged
Offline
Newbie
« Reply #7 on: December 23, 2012, 06:15:07 am » |
and so on.
What's happened ?
Thanx
I get the same errors. Any ideas to get this fixed?
Logged
Rapa Nui
Online
God Member
Pukao hats cleaning services
« Reply #8 on: January 28, 2013, 05:02:19 pm » |
..in HMC5883L.cpp change to: char* HMC5883L::GetErrorText(int errorCode) { if(errorCode == ErrorCode_1_Num) return ErrorCode_1; return "Error not defined."; //or "No error" ?? } Also such stuff like: int HMC5883L::SetScale(float gauss) { uint8_t regValue = 0x00; if(gauss == 0.88) { regValue = 0x00; m_Scale = 0.73; } else if(gauss == 1.3) { regValue = 0x01; m_Scale = 0.92; } else if(gauss == 1.9) { regValue = 0x02; .. is of course not to recommend, I would rather use int "gauss" values instead of floats there.. This library does not calibrate the sensor, so when you move a magnet around the values changes and stay off (and you may get wrong heading). Google for HMC58X3 v04 - that driver includes calibration.. https://launchpad.net/hmc58x3
« Last Edit: January 28, 2013, 05:17:57 pm by pito »
Logged
Offline
God Member
« Reply #9 on: January 28, 2013, 05:18:14 pm » |
I found three lots of code on the net for that device, and they all had obvious mistakes.
One was so bad, it had obviously never been attempted to actually use.
In the end, I wrote my own.
As for the magnet-waving around, these devices are intended to detect the very weak magnetic field of the earth. Waving a magnet around near them is going to impose a much larger magnetic field, possibly overload them, and cause problems with overflows in the readings. If you want to detect magnets, you need to turn the sensitivity of the device down.
You need to calibrate the device by setting the offset and scaling factor for each axial direction, so that the magnitude of the apparent field vector remains approximately constant no matter which way you orient the device.
Logged
Rapa Nui
Online
God Member
« Reply #10 on: January 28, 2013, 05:25:22 pm » |
I've got the sensor today  and I am quite surprised that moving a magnet (ie in 3-5cm distance) around does change the values PERMANENTLY  (when the sensor stays in a fixed position). Currently looking how to degauss the sensors (it shall include "automatic degaussing")..
« Last Edit: January 28, 2013, 05:27:28 pm by pito »
Logged
Offline
God Member
« Reply #11 on: February 01, 2013, 02:29:49 am » |
If you want to detect a magnet, you are probably better off using a "hall effect" sensor.
Logged
