Topic: GBOARD and library (Read 2263 times) previous topic - next topic
echelon75
I bought a GBoard and downloaded library:
http://iteadstudio.com/store/index.php?main_page=product_info&products_id=537
http://iteadstudio.com/store/images/produce/Shield/IComSat/GSM_Shield2.zip
I am using a MAC
Arduino IDE folder :/Users/admin/Documents/Arduino/
Library folder : /Users/admin/Documents/Arduino/libraries/GSM_Shield/
sample code folder : /Users/admin/Documents/Arduino/libraries/GSM_Shield/examples/GSM_Shield_Call
I am using Arduino IDE 1.0.1 and I load GSM_Shield_Call and when I click on VERIFY IDE display a long list of error Message:
In file included from GSM_Shield_Call.cpp:13:
/Users/admin/Documents/Arduino/libraries/GSM_Shield/GSM_Shield.h:10:22: error: WProgram.h: No such file or directory
In file included from /Users/admin/Documents/Arduino/libraries/GSM_Shield/GSM_Shield.h:11,
/Users/admin/Documents/Arduino/libraries/GSM_Shield/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
/Users/admin/Documents/Arduino/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
/Users/admin/Documents/Arduino/libraries/GSM_Shield/GSM_Shield.h:152: error: 'byte' does not name a type
/Users/admin/Documents/Arduino/libraries/GSM_Shield/GSM_Shield.h:161: error: 'byte' has not been declared
/Users/admin/Documents/Arduino/libraries/GSM_Shield/GSM_Shield.h:163: error: 'byte' does not name a type
/Users/admin/Documents/Arduino/libraries/GSM_Shield/GSM_Shield.h:169: error: 'byte' has not been declared
/Users/admin/Documents/Arduino/libraries/GSM_Shield/GSM_Shield.h:175: error: 'byte' has not been declared
/Users/admin/Documents/Arduino/libraries/GSM_Shield/GSM_Shield.h:178: error: 'byte' does not name a type
/Users/admin/Documents/Arduino/libraries/GSM_Shield/GSM_Shield.h:180: error: 'byte' does not name a type
/Users/admin/Documents/Arduino/libraries/GSM_Shield/GSM_Shield.h:182: error: 'byte' does not name a type
ETC ....
What is wrong ?
Regards
Richard
dxw00d
#1
Jul 22, 2012, 01:58 pm Last Edit: Jul 22, 2012, 02:00 pm by dxw00d Reason: 1
You are using a library that hasn't been updated for IDE 1.0. Point 2 here - http://arduino.cc/forum/index.php/topic,97455.0.html. Or read the release notes here - http://arduino.cc/en/Main/ReleaseNotes.
hqbeyers
Hi all,
I am stuck at the first step:
Uploading the Blink example to my new iteadstudio gboard.
The problem is that I have no idea which Board to select from "Tools->Board->" in the Arduino IDE.
So I keep getting the error:
avrdude: stk500_getsync(): not in sync: resp=0x00
I am using a Foca FT232RL Tiny Breakout to connect USB to the Gboard. The Foca is running at 3.3V
Help would be HIGHLY appreciated!!!
Hec
eisemann
Try setting:
Board -> Arduino Duemilanove w/ ATmega328
Your serial port will be something like:
/dev/tty.usbserial-[something]
Can't say for certain on the serial port.  I am using an FTDI friend from AdaFruit and am able to upload and run sketches.  Haven't got the GSM figured out yet though.
If you do go the FTDI friend route, make sure to reroute the pins.  As the assignments are slightly different between the G-Board and the FTDI friend.
Hope this helps.
- Ben T. Eisemann
Hi all,
Hec
