Topic: [Solved]LED Matrix, can't make it bright enought (Read 4202 times) previous topic - next topic
swat3d
It's good then!
I'll do a recap of all I've learned along the investigation and post it. I came across some contradictory and wrong information while looking online for a solution.
Thanks a lot for the help man! It's very very appreciated. You definitely brought some light in here!! Hope
To be able to help you some day!
Grumpy_Mike
Quote
I don't know why you got any light at all, either.  I don't know why the transistor still works
Because an NPN transistor with its collector and emitter swapped over is still an NPN junction and still works as a transistor but the gain is very much reduced.
Quote
Quote
"LED's pulsed for say 200% of their 'normal' current at a 50% duty cycle appear brighter than 100% current for 100% duty cycle even though the maths says that it's all the same average current"
That is wrong although it is a common myth. Do your own experiments.
Quote
Which one is right?
They both are, it is just they are calculating diffrent things. Having too much base current, even several hundred percent more has no effect on turning a transistor on, it has a slight effect on the time it takes to turn off however.
