Topic: Counter EMF Protection (Read 2126 times) previous topic - next topic
TeslaIaint
Jul 23, 2012, 03:50 am Last Edit: Jul 23, 2012, 04:27 am by TeslaIaint Reason: 1
I'm interested in improving my small robot to drive two motors with this motor driver. It looks simple enough to wire, program, and use.
My questions:
1. Do I need counter emf diodes in my circuit in addition to my motor driver board?
2. If so, what do you suggest?
3. Towards the bottom of the page on the Polulu link it says that temperature can be lowered and current improved by adding a heat sink. How do I do that? Is it as simple as using thermal tape with a small heat sink such as this?
http://www.sparkfun.com/products/10746
Polulu TB6612FNG Dual Motor Driver:
http://www.pololu.com/catalog/product/713
It's also the same as Sparkfun's:
http://www.sparkfun.com/products/9457
For my motors:
http://www.pololu.com/catalog/product/1117
For my Gearbox:
http://www.pololu.com/catalog/product/114
Motor Supply Battery:
9v rechargeable Ni-MH battery
Arduino Supply Battery:
9v alkaline or possibly another rechargeable 9v Ni-MH battery
Thanks in advance
Docedison
Everything sounds do-able EXCEPT the 9V battery, That simply WONT DRIVE A MOTOR unless it be a pager vibrator motor and that not for long. As to Sparkfun I really don't care for their prices or in a lot of cases the quality of the equipment and parts they sell BUT that is STRICTLY My opinion and that is the reason I don't buy anything from them, So I am not the one to make a call there. Pololu on the other hand has an Excellent Reputation and as far as I have seen excellent quality equipment or at least I very rarely hear anything wonky about them here in this forum. If you are contemplating motors and servo's you WILL need a separate power supply for the motors/servo's as they are too high current and FAR too noisy to share anything but a common ground for the control signal return path. Never share power as It is usually if not always more work to make both work well from a common power source than it is to provide separate power for them. IMO
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
TeslaIaint
Thanks, Doc.
Any ideas on the specific questions that I asked?
kd7eir
I see no need for diodes if you plan to use this driver as designed.
You will definitely get better performance with a heat sink.
Your heat sink should be sized at a minimum to match the
size of the chip itself.
As for a battery, check the the Ah rating of your proposed battery
compared to what your motors will draw.  It looks like they are
70mA no load, and 800mA stall current.
TeslaIaint
Thanks kd,
You are correct about the flyback diodes and tech support at Polulu agrees.
I'll definately put on the heatsink with the thermal tape that I ordered. I hope it fits.
For power to my motors I'll probably use 6 rechargeable or alkaline batteries. I might use a 7805 to regulate to 5 v, but I don't think I need it. I'll play with it and see what works best. Thanks again.
spcomputing
I would recommend a thermal "paste" (for notebook heat sinks and high power graphic card heat sinks).  The tape will not make the best contact between the two planes (heatsink and device flange).  If sparkfun does not have it, your local computershop will.  Just look for the stuff with "silver" in it.
TeslaIaint
#6
Jul 25, 2012, 05:37 am Last Edit: Jul 25, 2012, 05:48 am by TeslaIaint Reason: 1
Does it act as the "glue" as well?
If not, what do you suggest?
edit: from a small town. no computer shop haha
radio shack maybe? but radio shack can .... .. ....
spcomputing
No, you will need a nut a bolt.  It very, very slowly dries out (good thing).  You would still need a nut and bolt to make the tape work.  The important thing is to make good thermal contact with the most surface.
Radioshack has this online which I repaired an overheating Mac with:
http://www.radioshack.com/product/index.jsp?productId=11300878
Same stuff that gets an extra amp or two out of my full bridge drivers.
TeslaIaint
that's the thing.....
no nut and bolt possible or else too easy...
just a small surface mount chip
Docedison
#9
Jul 25, 2012, 06:25 am Last Edit: Jul 25, 2012, 06:46 am by Docedison Reason: 1
Two things... the thermal tape will work as well as anything else... as the plastic case wasn't designed for heatsinking and has a very high thermal resistance. There is another type of motor driver that uses a big IC with a metal tab on top, that device is capable of a great deal more current. I built a valve controller that 'Worked' a three wire solenoid "Pilot Valve" about 10 12 years ago. I used one of these parts An L298 and it was directly heatsinkable... A minute of searching found these Items (There were several of them,, all shields)...< http://compare.ebay.com/like/150765336052?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar for $7.25 and the Spec sheet says it is good for 4 amps PEAK and 2.5 A @ 80% duty cycle. I scrapped the Ic in favor of a relay and an NPN transistor as the area in which my application was used was Agricultural and nearby lightening strikes took out the IC as frequently there could be 50 meters of wire between the solenoid and the controller. The issue was 'Transverse fields" or the way the energy from the strike literally electrified the earth around the device. I've measures several KV of induced voltage... lost a couple of small strip chart recorders before I totally realized the potentials involved. USE your 'browser and don't be afraid to look around. I've found that the people who make the biggest noise (Big Ad's All over the place) are the absolute WORST for prices. It should be an easy task to develop a 20 A reversible motor driver with a relay and a power Mosfet... Braking too, even to be able to use the stored kinetic energy to charge the battery for braking. It is a driver I designed many years ago for bi-polar or Latching Solenoids... I don't think I ever had one fail from anything beyond the occasional defective relay. It was a 20A Omron DPDT relay and a D44H11 transistor (Mosfets would have been my first choice but they weren't as reliable or as inexpensive as the relay/transistor combination... At that time power Mosfet's cost about 4 times what the D44H11 cost. Very reliable for my application, I made several thousand of them (not me directly but my crew did) and ALL worked without fail. Use the L298, NOT the L293... unless you are good enough to add power transistors or Mosfet's to handle the real power. Easy and Simple.
Doc
--> WA7EMS <--
spcomputing
Okay, I understand now.  This Toshiba chip is oddly robust for how ridiculously small it is.  Just as Doc has suggested, your mileage may vary.
Since this chip has no thermal protection other than the package and 175C overtemp circuit, the "paste" or "tape" is irrelevant.  All you want to do is protect the MCU from the "EMF" or current backlash (AC) from the motor(s).  Doc may have some suggestions better than my 1N4001 diode on your PWM output, but I do believe you are on your own on such a small device (298s or 293s have much more built into the device).  Maybe somebody can suggest where to put the diode to get your reverse back ;)
Docedison
a small Tranzorb of the appropriate voltage might work well for 'back emf' but I have another real 'old school idea that I will develop and share in the next few days might just work better... I don't have a good spice model for a motor, have to go with my experience first. Real tired now and not thinking as clearly as I might like. For the follower idea use the PIR device as a distance controller and the beacon for required movement...
I'm going to bed shortly. I do however need my hour with the 2 books I am reading. A Book on C and the C++ Primer. Electronics is easy and fun, C is difficult...
Doc
--> WA7EMS <--
TeslaIaint
cool. I would like to hear it. Like I said this small robot is just a prototype for my bigger robot that I will build. For that one I don't think I need an h-bridge, but they will be much bigger motors. about 200w.
