Loading...
Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: MENWIZ: una libreria per creare menu su LCD  (Read 4774 times)
Roma
Offline Offline
Jr. Member
Mechmate #70
View Profile
Allora, mi è arrivato il display LCD da 20x4 WOW ! bellisimo ! ... e ho potuto progredire nel progetto.
Ecco cosa ho combinato:
Code:
 //------ Sega Squadratrice ---------
s1=menu.addMenu(MW_SUBMENU,r,F("SAW"));                    //add a submenu node 2 to the root menu (control the heigh of my Planner)
  s2=menu.addMenu(MW_SUBMENU,s1,F("Altezza Sega"));                         //add a terminal node in the menu tree (that is "variable"); (should move at a certain mm height)
    s3=menu.addMenu(MW_VAR,s2,F("Altezza Assoluta"));
      s3->addVar(MW_AUTO_INT,&Height2,0,100,1);     //int type, fd binded variable, rage 0-100, step 1
        s3=menu.addMenu(MW_VAR,s2,F("moveMOTOR2"));
        s3->addVar(MW_ACTION,moveMOTOR2);
  s2=menu.addMenu(MW_SUBMENU,s1,F("Spostamento Sega"));                         //add a terminal node in the menu tree (that is "variable"); (should move at a certain mm height)
    s3=menu.addMenu(MW_VAR,s2,F("Movimento Relativo"));
     s3->addVar(MW_AUTO_INT,&Height1,-100,100,1);                   //int type, fd binded variable, rage 0-100, step 1
        s3=menu.addMenu(MW_VAR,s2,F("moveMOTOR"));
        s3->addVar(MW_ACTION,moveMOTOR);
  s2=menu.addMenu(MW_VAR,s1,F("Zero"));                         //add a terminal node in the menu tree (that is "variable"); (should set the zero)
  s2=menu.addMenu(MW_VAR,s1,F("Setup"));                        //add a terminal node in the menu tree (that is "variable");  (set the parameters)
  //------- Pialla --------
s1=menu.addMenu(MW_SUBMENU,r,F("PLANNER"));                    //add a submenu node 2 to the root menu (control the heigh of my Planner)
  //------- Toupie --------
  s1=menu.addMenu(MW_SUBMENU,r,F("Toupie"));                    //add a submenu node 2 to the root menu (control the heigh of my Planner)
E queste sono le funzioni (provvisorie) chiamate:
Code:
void moveMOTOR(){
stepper1.moveTo(Height1 * 50); // move Height1 mm's
lcd.print ("Sposto di ");
lcd.print (Height1);
lcd.print (" mm");
delay (5000);
void moveMOTOR2(){
stepper1.moveTo(Height2 * 50); // move Height1 mm's
lcd.print ("Altezza Segaa: mm ");
lcd.print (Height2);
delay (5000);
In pratica ora il menu fa esattamente quello che volevo (bhè è da finire un poco e da mettere in ordine)
Però ora le funzioni vengono chiamate internamente al ramo scelto, ovvero:
Menu Principale.
   SAW > Altezza Sega > Altezza Assoluta > Variabile 0 (X) 100
                                                       > Esecuzione
         > Spostamento sega > Movimento Relativo > Variabile -100 (X) +100
        > Esecuzione
E oltretutto riesco anche a far vedere ciò che succede dul display:
Code:
lcd.print (" mm");
ovvero mi appare sul LCD "Sposto di X mm""
Fantastico !
Grazie !
Penso che con il menù ho quasi fatto ... ora devo lavorare sul motore passo passo e le relative funzioni.
Ciao
P.S. allego lo sketch completo.
« Last Edit: February 03, 2013, 05:23:27 pm by Silverdog63 » Logged
Offline Offline
Newbie
View Profile
Ciao,
ho provato la libreria per i menù di un controller di un acquario che sto realizzando.
Grazie per il magnifico lavoro che hai fatto.
Molto semplice da usare anche per me che conosco solo le basi del linguaggio C (e neanche bene).
A me sono state molto utili anche le opzioni di salvataggio in eprom e la possibilità di usare un altra "funzione" per la gestione dei pulsanti.
Ciao
Marco
Logged
Offline Offline
Jr. Member
View Profile
Ciao Brunialti bel lavoro, senti per caso mi potresti aiutare ad adattare questa libreria per l' IDE 23, poiche ho scritto già un pde in quella versione e mi verrebbe più semplice adattare la tua alla 23 che il mio pde con tutte le librerie incluse alla 1.0
Logged
rome
Offline Offline
Sr. Member
View Profile
grazie al lavoro di Alessandro Raffaele che ha tradotto il manuale della libreria chi è interessato lo può prendere dall'allegato.
Purtroppo non sono riuscito a verificarlo, ma sono convinto che è perfetto :-)
Grazie Alessandro
Logged
0
Offline Offline
Faraday Member
Arduino rocks
View Profile
Grazie del manuale, credo sia meglio un PDF, questo DOC non si apre sul mio tablet
Logged
- [GUIDA] IDE1.x - Nuove Funzioni - Sketch Standalone - Bootloader - VirtualBoard
http://arduino.cc/forum/index.php/topic,88546.0.html
- [LIBRERIA] ST7032i LCD I2C Controller Library
http://arduino.cc/forum/index.php/topic,96163.0.html
Forum Moderator
Italy
Offline Offline
Brattain Member
Don't know what I do
View Profile
Aprendolo su Linux da LibreOffice mi trovo un documento di più di 400 pagine di caratteri senza senso e pagine vuote.
Logged
Switzerland
Online Online
God Member
View Profile
@Leo : L'ho convertito in pdf ma ... NON riesco ad allegarlo ... il forum mi corrompe l'Attach sia se lo metto come pdf, sia se lo racchiudo in uno zip ... smiley-sad smiley-sad smiley-sad
Guglielmo
Logged
Forum Moderator
Italy
Offline Offline
Brattain Member
View Profile
Il forum ha dei problemi con gli allegati da diversi giorni, pare proprio nel gestire ZIP e PDF, che vengono allegati ma poi salvati in remoto in forma corrotta.
Prova a comprimere il file in un formato tipo RAR oppure TAR.GZ, per vedere se cambia qualcosa.
Logged
Switzerland
Online Online
God Member
View Profile
... eccolo in RAR ... vediamo ...
Guglielmo
Edit : Sembra che in RAR vada bene smiley-wink
Logged
ivrea (to)
Offline Offline
God Member
View Profile
Io ho scaricato con Chrome ma il rar mi risulta corrotto
Logged
Forum Moderator
Italy
Offline Offline
Brattain Member
View Profile
Aprendo l'archivio mi viene detto che il file è corrotto però me lo estrae e poi il PDF è giusto  smiley-eek
Uso Linux con Chromium.
Logged
Switzerland
Online Online
God Member
View Profile
... a questo ho aggiunto anche una parte di "recovery record" (opzione -rr di RAR) ... vediamo se riusciamo ad avere una cosa non corrotta ...  smiley-cry
Guglielmo
Edit: Mi sembra vada ... scaricato con Chrome ed estratto senza errori ...  smiley-roll
« Last Edit: April 29, 2013, 04:08:22 am by gpb01 » Logged
ivrea (to)
Offline Offline
God Member
View Profile
A me winrar dice fine imprevista nel file. Però estraggo il pdf e sembra corretto. L'ultima pagina è la 19 ?
Logged
Forum Moderator
Italy
Offline Offline
Brattain Member
View Profile
L'ultimo RAR a me non ha dato nessun errore.
Logged
Switzerland
Online Online
God Member
View Profile
Si, è la 19 ! ... comunque stà diventando sempre più problematico allegare files ... smiley-sad
@Leo : .... moderatore, due domandine ...
  1. come mai viene usato ancora la versione 1.1.18 di SMF e non una nuova (versione 2.x) ?
  2. come mai viene usato SMF invece di qualche cosa di più robusto, sicuro ed affidabile come IPS o vB ?
Guglielmo
Logged
Pages: 1 2 3 [4] 5 6   Go Up
Print
Jump to:
