Loading...
Pages: 1 [2]   Go Down
Author Topic: I2C slave reply  (Read 1206 times)
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
I used
Where? I need to see where you used that.
In the loop() method on the slave, print the position of the stepper.
In the requestEvent callback, print when the callback is entered and when it is ended.
It may be that requestEvent needs to behave like an interrupt service request handler, in that it can not block. If that is the case, then I don't know what you will have to do. Perhaps you could just connect two other pins between the two Arduinos. On the "master" poll the pin of interest. On the "slave", set the pin LOW when the stepper is running. Set it HIGH when the stepper is done.
Logged
Offline Offline
Newbie
View Profile
Hi Paul
Please check if this slave code is what you are looking for :
Basically ,
for delay of 100   - the current position of motor (when it stopped) is 7 and the request is called when the motor is at position 7 .
for delay of 4000 - the current position of motor is 2547 and the request is called when the motor is at position 2547 .
So is the request being called after the motor stops ? or is the delay interfering in some way ?
Code:
// I2C communication  1 Master- 1 Slave
// program for slave 4
#include <Wire.h>
#include <AccelStepper.h>
int incomingByte = 0;
// timer variables
long millisec = 0;
long microsec = 0;
// stepper motor pins: STEP, DIRECTION, STEPPER ON/OFF
AccelStepper Stepper1(1,2,3);
  Wire.begin(4);
  Wire.onReceive(receiveEvent);
  Wire.onRequest(requestEvent);
 //Start Serial for debuging purposes
  Serial.begin(115200); // USB comm with PC
for(int i = 0;i <54;i++) {
    pinMode(i,OUTPUT);
    digitalWrite(i,LOW);
// switch stepper chips off
  digitalWrite(4,HIGH);
Stepper1.setMaxSpeed(1000);
void receiveEvent(int howMany)
     if (Wire.available() > 0) {
     incomingByte = Wire.receive();
void requestEvent()
   Serial.println(" Request is called when the motor is at position");
   Serial.println(Stepper1.currentPosition());
   while(Stepper1.currentPosition() != Stepper1.targetPosition())
   { //do nothing
   Wire.send("Action complete");
  Serial.println("Request send when motor is at position");
   Stepper1.run();
        //Serial.print("  Selection:");Serial.println(incomingByte);
        switch(incomingByte) {
          case 1: digitalWrite(4,LOW); digitalWrite(3,HIGH); digitalWrite(2,HIGH); //Serial.println("Stepper1: forward");
                  Serial.println("forward");
                  Stepper1.setCurrentPosition(0);
                  Stepper1.setAcceleration(500.0);
                  Stepper1.moveTo(4000);
     // switch loop
     incomingByte = 0;
} // main loop
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Please SHOW me the serial output.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
@anishh2003 - please post your output. Don't just interpret it, or comment on it. Post it. For example, does the stuff below appear?
Code:
void requestEvent()
   { //do nothing
Doing serial prints inside an ISR (which effectively is what requestEvent is) is a very bad idea. It is likely to block and hang. Does your code hang?
Quote
... it is just stuck.
Looks like it does.
Logged
Offline Offline
Newbie
View Profile
Hi
Here is my output for a delay of 100
Code:
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
forward
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
4
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
6
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7 Request is called when the motor is at position
7
@Nick :
The code hangs irrespective of whether the serial.println statments are there in the requestEvent() for me .
Logged
Offline Offline
Newbie
View Profile
Hi
Just did some further tests ...
i am able to get the motor running if I remove
Code:
while(Stepper1.currentPosition()!=Stepper1.targetPosition())
{ // do nothing
I think this code blocks the slave operation . Any idea what else I can replace this with .
Thanks
« Last Edit: July 25, 2012, 11:27:57 am by anishh2003 » Logged
Pages: 1 [2]   Go Up
Print
Jump to:
