Topic: Problem using a voltage divider to input a voltage to a low impedance line (Read 7604 times) previous topic - next topic
Grumpy_Mike
You need a circuit like this, it will smooth the PWM and then give it a boost with the FET. Just replace your load where it says FAN.
If you don't want a smooth voltage and PWM will do then use this circuit:-
Daanii
Thanks, Grumpy Mike. That did the trick! I wired up the second circuit, and it looks like it will work. Unfortunately, I cannot test the circuit on the device itself for a couple of weeks. I'll post back then with final results.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
