Topic: 2560 bootlader mkii problem (Read 2835 times) previous topic - next topic
CrossRoads
Reset is supposed to hold the Reset pin high.
When its low, the uC is in reset.
The AVR ISP controls the reset pin during the bootloading.
It should go high when the bootload is done for normal operations.
Houser636
I see what you mean the programmer controls the line.  I tried using the uno as an isp, and coudnt get it to work either.   It works on a known good 2560, but not my board.  I just do not understand why it wored until i tried to bootload it and now nothing.
I guess i will order another chip and try again.
Any other ideas?
CrossRoads
NickGammon has the Uno as bootloader part worked out quite well, including bootloading a 2560 board from an Uno.
Have you tried that?
http://www.gammon.com.au/forum/?id=11635
Houser636
Yeah thats exactly what i tried.  It wouldn't get past the beginning of the program where it pulls the reset line low, and checks for clk.
I put my multi meter on reset and ground right at the pin.   It went to about. 02v. I did it with a known good board and ot went down to .005v. Do you think yhis is enough to cause the issue?
Houser636
#19
Aug 04, 2012, 06:11 am Last Edit: Aug 04, 2012, 06:15 am by Houser636 Reason: 1
Problem Solved!  Thought I'd let everyone know just in case they are having a similar problem. It was the reset line.  I made one on a breadboard going from 5v to a 10k resistter.  the resistor goes to the reset switch + side.  The other side straight to gnd.  right after the 10k resistor, I put a 22pf cap.  Everything works perfect.  Bootloader uploaded fine.
Thanks everyone that helped.
