Topic: nRF24L01 with MIRF Libary often Timeouts (Read 1 time) previous topic - next topic
erf2012
Hello,
I am new in Wifiprogramming. I have an issue that I cannot unterstand. I have to Unos with a connected nRF24L01, using the MIRF Libary.
My Problem is that the connection is working and the Server Shows a connection result, but it works usally only 5 to 15 times and then the connection is impossible. If I restart the server all fine up to the disconnection. The Client has no effect if I restart them.
Here is my code:
Server:
Code: [Select]
* An Mirf example which copies back the data it recives.
* Pins:
* Hardware SPI:
* MISO -> 12
* MOSI -> 11
* SCK -> 13
* Configurable:
* CE -> 8
* CSN -> 7
#include <SPI.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
void setup(){
   * Set the SPI Driver.
  Mirf.spi = &MirfHardwareSpi;
   * Setup pins / SPI.
  Mirf.init();
   * Configure reciving address.
  Mirf.setRADDR((byte *)"serv1");
   * Set the payload length to sizeof(unsigned long) the
   * return type of millis().
   * NB: payload on client and server must be the same.
  Mirf.payload = sizeof(unsigned long);
   * Write channel and payload config then power up reciver.
  Mirf.config();
  Serial.println("Listening...");
int i = 0;
void loop(){
   * A buffer to store the data.
  byte data[Mirf.payload];
   * If a packet has been recived.
   * isSending also restores listening mode when it
   * transitions from true to false.
  if(!Mirf.isSending() && Mirf.dataReady()){
    Serial.println("Got packet");
     * Get load the packet into the buffer.
    Mirf.getData(data);
     * Set the send address.
    Mirf.setTADDR((byte *)"clie1");
     * Send the data back to the client.
    Mirf.send(data);
     * Wait untill sending has finished
     * NB: isSending returns the chip to receving after returning true.
    Serial.print("Reply sent: ");
    Serial.print(i);
    i++;
    Serial.print(".");
Here is the Client
Code: [Select]
* A Mirf example to test the latency between two Ardunio.
* Pins:
* Hardware SPI:
* MISO -> 12
* MOSI -> 11
* SCK -> 13
* Configurable:
* CE -> 8
* CSN -> 7
* Note: To see best case latency comment out all Serial.println
* statements not displaying the result and load
* 'ping_server_interupt' on the server.
#include <SPI.h>
#include <Mirf.h>
void setup(){
   * Setup pins / SPI.
  /* To change CE / CSN Pins:
   * Mirf.csnPin = 9;
   * Mirf.cePin = 7;
  Mirf.cePin = 7;
  Mirf.csnPin = 8;
  Mirf.init();
  Mirf.setRADDR((byte *)"clie1");
   * To change channel:
   * Mirf.channel = 10;
   * NB: Make sure channel is legal in your area.
  Mirf.config();
  Serial.println("Beginning ... ");
void loop(){
  unsigned long time = millis();
  Mirf.setTADDR((byte *)"serv1");
  Mirf.send((byte *)&time);
  while(Mirf.isSending()){
  Serial.println("Finished sending");
  delay(10);
  while(!Mirf.dataReady()){
    //Serial.println("Waiting");
    if ( ( millis() - time ) > 1000 ) {
      Serial.println("Timeout on response from server!");
      return;
  Mirf.getData((byte *) &time);
  Serial.print("Ping: ");
  Serial.println((millis() - time));
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
