Topic: My first custom Arduino board (Read 9540 times) previous topic - next topic
0miker0
Jul 25, 2012, 03:25 pm Last Edit: Jul 25, 2012, 09:33 pm by 0miker0 Reason: 1
I'm just finishing up my first custom Arduino board. Once the bootloader is on I plan on connecting the smaller mono OLED display found on ebay or the larger color 4DSystems type. It features a 1A LDO regulator and two pushbuttons. Not much else since it's onlt 1.1" X 1.0" in size. Feel free to let me know if I missed something on the schematic. I tried to figure out what pins go where from the official arduino board schematics. Either OLED will push onto the front and the GPS will have to be sticky taped to the rear. On top of the regulator. The idea and code I used is at: http://karman.cc/blog/archives/746
Working Prototype:
Front:
Back:
Schematic:
[Mike
KaR]V[aN
Hello!
Just saw the photos. Nice build up!
What I miss is the LiPo power source with it's charger :P
Regards
http://karman.cc
0miker0
True. I stripped out all of the good stuff! This is just a starting point so it it works so far I may add the charger and booster on the next go.
Mike
RudiAhlers
Nice project! I'd love to see how it evolves
0miker0
It's been about a year since this first post and i'm still working on the project! Since then pretty much everything has changed except the size of the display. I like the 32u4 microcontroller with built in USB, liPo battery charger and navigation button i'm using now. Check out the latest version at: https://sites.google.com/site/0miker0/arduino-sensor-board
Mike
aarondc
That is awesome and inspirational.
graynomad
Quote
It started off the same size as the display and over time with the discovery of new components it grew in size.
Oh how well I can relate to that :)
Nice project.
I'll grab the Altium files and have a sticky beak.
_____
Rob
Rob Gray aka the GRAYnomad www.robgray.com
graynomad
The ICSP pads do not plate through, will you be using pogo pins for a one-off bootloader programming?
______
Rob
0miker0
The ICSP pads did originally plate though but as the board got more and more parts I realized that it took up way too much space on the opposite side of the board. I'm trying out pogo pins soon but for now I solder on a 6X2 header, program the bootloader and then de-solder it. It's a pain but frees up the entire backside of the board for tracks and components.
This link: https://sites.google.com/site/0miker0/ shows two boards i'm working on that are fairly similar. One is a GPS board and the other is packed full of sensors. I'm no good at programming so the sensor board gives me lots of things to work with. My previous setup was an uno connected to a breadboard with a ton of jumper wires. This packs everything into something that fits in the palm of your hand.
KirAsh4
#9
Jun 19, 2013, 07:10 pm Last Edit: Jun 19, 2013, 07:50 pm by KirAsh4 Reason: 1
What about putting the ICSP pins as pads along one edge, three pads on one side and three pads on the other side.  Then you can use a regular 2x3 header and shove it onto the edge, program, and remove.  No soldering needed.  Someone wrote a piece on that:
http://mcumix.blogspot.com/2011/05/conway-life-redesign-of-ladyadas-board.html
This is another option, although it requires you to make a custom header:
http://www.daniel-spilker.com/blog/2011/04/25/isptouch-for-avr-microcontrollers/
nayma
0miker0
An ICSP header on the board edge is an excellent idea! I've done something similar by soldering a DB9 connector onto a board edge. The spacing between pins 1-5 and 6-9 feels like around 50 mil so once pushed onto the board edge and soldered into place was very rugged.
KirAsh4
Re-read my message.  Added some links for you.
makervier
good job,thank you for your good ideal
