Offline
Jr. Member
Write befitting for a 13 year old!!
« on: July 25, 2012, 07:31:41 pm » |
I understood until now, that electronics, when it uses GND (ground), it means " - " (minus). On a motor I've got, it has a + (plus), - (minus), and GND (ground). What does the GND do?
Logged
I'm 13 and I'll frequently be wordy, not writing to the point. But don't worry, I know somethings about electronics.
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #1 on: July 25, 2012, 08:36:25 pm » |
GND is really the reference point. If you are standing at street level, the first floor is one level above ground (so you might call it plus) and the basement is one level below ground (so you might call it minus).
As for your motor, what type is it?
Logged
UK
Offline
Full Member
mini mini mini
« Reply #2 on: July 25, 2012, 09:29:44 pm » |
Wouldn't surprise me of the GND tab on the motor goes to the can, so assuming it's brushed you can easily add some caps for suppression.
Logged
Offline
Edison Member
« Reply #3 on: July 25, 2012, 09:42:11 pm » |
In a house you would call it the hot,neutral and earth ground You would never use a ground as a neutral although it technically would work ground is more for protection(from say shock or noise) in a circuit you assume - means gnd when it really doesn't, most circuits are simple so people say ground but it is truly negative on a battery you say its the positive and negative terminal, there is no ground terminal maybe only a ground connection on the motor the ground is a connection to the chassis, this would protect you from shock if say the positive wire was touching the chassis and potentially could electrocute you, instead it hits the ground and would trip the overload or watever protection device implemented now gnd in a dual polarity circuit means the common connection point and has no relation to the actual earth ground, so it does get a little confusing in that case it refers to like said before the common reference point, but in this case with a motor it refers to earth ground used for protection that should(but isn't always) at the same potential as the negative leg of the supply
Logged
Offline
Jr. Member
« Reply #4 on: July 26, 2012, 06:51:01 am » |
As to Nick Gammon, I have a 1000kv 400xt brushless motor. www.hobbypartz.com/40tyoubrmo.html
Logged
UK
Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
« Reply #5 on: July 26, 2012, 07:11:03 am » |
The "ground" doesn't actually exist.
It is merely a term used for the point in a circuit at which all voltages are measured with reference to. It is entirely arbetrary what that point is.
Normally the "ground" node of a circuit is that node to which the majority of components are connected to. If there is no such node, then 9 times out of 10 it is taken to be the point of lowest potential in the circuit - for instance the negative terminal of a battery. Other circuits may take that point to be a place where the other voltages in the circuit cancel each other out.
The Arduino (and the Atmel datasheets) actually label things wrongly. They talk of Vcc and GND as pins, which is entirely wrong in every respect. What they should actually be talking about is Vss and Vdd - the source and drain voltages - and all voltages in the data sheet are measured with respect to Vss (Max Vdd above Vss = 5.5V for example). The "GND" pin may not be connected to the same node as you have taken a GND in the rest of the circuit. Vcc itself means "Collector voltage", and is as relevant to a CMOS system (which uses MOSFETs, not BJTs) as the ants crawling up the wall are to the current value of the Dow Jones index.
As far as motors are concerned, the "GROUND" could be many things. For instance:
* It may be a connection to the metal exterior of the motor, to be used for noise reduction and/or safety. * It may be a reference point for applying the voltages to the + and - pins - the motor might be inteligent, and you apply voltage to + and GND for spinning one way, and - and GND for spinning the other way.
Logged
Anaheim CA.
Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
« Reply #6 on: July 26, 2012, 05:04:40 pm » |
Vcc and GROUND are pins... designated places where these Sources are found and connected to. As to VCC most all the people learning here don't realize that Mosfets are relatively New parts... ALL Logic less than 30 years ago WAS Transistors at that time Cmos was the New kid on the block 40 years ago the Vast majority od electronics produced was still vacuum tubes. Power mosfets were very rare (N Ch) and P Ch were impossible smalll low current devices that were difficult to use as they were most fragile and had Rdson values it the 10's to 100's of ohms. I can clearly remember CD4017's that cost $12.00+ each, a CD4022 was 8 dollars in 1972 and a CD4011 was $2.31 and I was making 7.25/hr I got a raise to 9.00/hr and thought I could buy the world (It's a bit over $30.00/hr now)... and pop bottles were worth $.02 Ea refund value and a guy could collect 5 of them and buy enough candy to last all afternoon. There were also a great surprising number of people that believed the moon was made of Green Cheese. Luddites were coming into their own... sometimes I wonder if they hadn't the right of it. <BG>
Doc
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
0
Offline
Tesla Member
Arduino rocks
« Reply #7 on: July 26, 2012, 06:21:18 pm » |
That motor doesn't have +/-/gnd, it has red/black/yellow phases - its a 3-phase sensorless brushless motor.
Logged
Offline
Jr. Member
« Reply #8 on: July 27, 2012, 01:53:31 pm » |
I do actually need more info on the motor
Logged
Offline
Edison Member
« Reply #9 on: July 28, 2012, 01:20:02 pm » |
Idk without a datasheet its hard to say exactly what that motor needs just says 12v,
Logged
Offline
Jr. Member
« Reply #10 on: July 30, 2012, 04:15:03 pm » |
That motor doesn't have +/-/gnd, it has red/black/yellow phases - its a 3-phase sensorless brushless motor. What is a 3-phase sensorless brushless motor??
Logged
Manchester (England England)
Online
Brattain Member
Solder is electric glue
« Reply #11 on: July 30, 2012, 04:41:05 pm » |
What is a 3-phase sensorless brushless motor?? See:- www.atmel.com/images/doc8012.pdf
Logged
Offline
Jr. Member
« Reply #12 on: August 03, 2012, 05:29:04 pm » |
the document is WAY too long and complicated! In a nutshell please...
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #13 on: August 04, 2012, 04:21:19 am » |
Wikipedia it
Logged
UK
Offline
Edison Member
« Reply #14 on: August 04, 2012, 04:34:10 am » |
Wikipedia it
Makes a change from "JFGI" I suppose...
Logged
